Sanwa 700 road bike, Tange #2 - anyone have more info?
Hi Bargainguy,
Adding to the old thread here.
Great job in cleaning it up. And thanks for post pics. I pulled a Sanwa 215 small bike out of a yard sale a couple years ago circle 2018. It is missing all the components; breaks and shifters; It only has a rusty chain and cranks. Your photos show how it would been outfitted. Thanks!
The statement must be looked at in the context of the era. While Tange #2 is roughly the equivalent of SL or 531, in 1984 it was Tange's 3rd ranked tubeset, behind Prestige and Tange #1 . Almost all the high end Japanese bicycles with Superbe Pro or Dura-Ace were using Prestige or Tange #1 . Since Tange #2 was less expensive than SL and 531, it could be marketed on bicycles at a lower price point. Typically, during this era, Tange #2 was spec'd on 105, Cyclone and New 600EX equipped bicycles. As such, they were typically under $500 US, which I would consider mid-range for the era.
I've chewed this over and still can't understand why well documented empirical data should be looked at in any particular context. Metallurgy is science not religion or politics or marketing. Tange 2 is just as good as 531.
Quoted: 4722 Post(s)
Liked 3,036 Times
Also, when you're comparing it to Reynolds 531, to which version are you referring? 531 was a steel alloy. During the period in question, there were several versions of 531 tubesets. I'll assume you're talking about 531C, which was the standard/most common set. If you wanted lighter, there was 531 Professional. If you wanted lighter and stronger there was 753R. So, even in the Reynolds hierarchy, 531C wasn't the top end tubeset. Due to Reynolds pricing policies, it didn't filter quite as far down the bicycle product lines as Tange #2 , but it still wasn't being relegated to the top models. 531C would progressively get knocked further down the ladder by newer tubesets such as 653 and 853.
The same thing happened at Columbus. Through the mid 1970s, SL was the top tubeset. Then it got nudged out of top spot by KL. It got shoved down another step with the introduction of SLX/SPX Then Columbus gave us Max, TSX and MS, so that by 1988 SL was 5th in the product line.
The fact of the matter is, as time rolls on better products are introduced and the surviving products get bumped further the product line. The product itself may not have changed but ensuing advancements have reduced its stature and it is offered at progressively lower price points.
