Recommendations For Rear Rack for stays lacking eyelets
Observational Theorist
Quoted: 26 Post(s)
Liked 20 Times
I've seen these before in passing but now having trouble finding any in my searches. Trying to mount a rack to a bike with no eyelets or braze one.
Edit: I'm specifically looking for the non seat post clamp style.
Product links would be greatly appreciated.
Thanks!
Thanks!
Bikes: Vilano Urbana, DownTube FS9, Montaque paratrooper, Nano mini-velo, Motobecane CX, Raleigh 20, MIFA folder, ROG Pony, Iverson Grand Touring folder, Exclusiv German folder
Quoted: 168 Post(s)
Liked 191 Times
Quoted: 26 Post(s)
Liked 20 Times
Quoted: 3455 Post(s)
Liked 1,454 Times
Or these, you will need to know the size you want. I think they are the same as previously noted, just one more supplier.
https://www.homedepot.com/p/0-75-in-...1575/202875639
Some racks are designed to attach at the brake bridge between the stays where you can mount a fender. Tubus Fly is an example.
Randomhead
Liked 3,687 Times
What are you going to do with a rack on a long distance ride? Are you looking for the touring forum?
On the kind of ride that fits in this forum, a front rack and handlebar bag works much better than any bag that works on a rear rack.
Bikes: A few
Liked 7 Times
Maybe this?
You can buy the side rails for panniers separately if you wish. It is really quite a nice rack. Easy on, easy off and works well on either front or rear of bike.
Quoted: 2333 Post(s)
Liked 2,097 Times
Rubber coated P clamps work fine, used them on an old bike for many years, but I have to second what Unterhausen said. Saddle bags are suboptimal on a rando or ultra endurance rig. I used P clamps for fenders on an old steel frame that I converted to 650B.
When I first started randonneuring I guess in the late 80's trying for PBP 1991, I used my touring bike with a blackburn rear rack and my "smaller" front panniers. These never caused me to not finish but they are slow and very inconvenient. I now personally prefer a smallish handlebar bag and some sort seat bag depending on conditions. Both are literally more than sufficient to carry enough gear to cross the country, including a down sleeping bag, bivvy, and small air pad. On a warmer 1200k, the HB bag is sufficient for me. The handlebar bag lets you access stuff while riding and this is very important.
mosquito rancher
Axiom and Tubus both make racks that use your quick-release skewer as the lower mounting point. I believe both have relatively low load limits. If you've got through axles, the Robert Axle Project makes a special through axle that you can bolt certain racks to.
Obviously dealing with flats would be an extra-special PITA in any of these cases.
Adam Rice
Adam Rice
Likes For adamrice:
Jedi Master
Randomhead
Liked 3,687 Times
The OP never did tell us what he was going to do with this rack
I like my Tailfin. I used to use a seat post bag, but I have minimal clearance between the seat and back tire. The bag eventually rubbed the tire at some point in time. And like you said, it is steady. No flopping side to side. I probably carry more than most Randonneurs, but my brevets have been more about training for longer rides than the brevet itself.
Randomhead
Liked 3,687 Times
not wanting a seat post mounted rack is what made me think he wasn't using it for randonneuring or similar lightweight long distance riding. But he never said.
Likes For unterhausen:
