What size would you choose for a guy this tall?
Hi guys,
I'm looking for a comfortable riding position on the Fuji Touring bike (here is their sizing chart)
imgur (dot) com/clcvR7I).
My numbers are:
inseam: 86
trunk: 67
forearm: 35,5
arm: 69
tight: 62
lower leg: 57
sternal notch: 152
total height: 187
(in centimeters)
Should I choose the 58 or the 64 size?
Thank you
My numbers are:
inseam: 86
trunk: 67
forearm: 35,5
arm: 69
tight: 62
lower leg: 57
sternal notch: 152
total height: 187
(in centimeters)
Thank you
Quoted: 18373 Post(s)
Liked 4,509 Times
Ok, so you are about 6'1.6".
A 60cm frame would likely be a good fit.
Here is your chart:
https://i.imgur.com/clcvR7I.jpg
Fuji Bikes | LIFESTYLE | URBAN | TOURING
The bike appears to have a sloping top tube, but apparently they are measuring the actual seat tube length (plus or minus a short mast). So, effectively the standover height will be shorter than expected (or like a larger non-sloping frame). But, it does raise the headtube/handlebars slightly.
The answer may be in the standover height.
L:831
XXL: 865
You listed your inseam as 86.
So, you could probably fit over the XXL frame, but it will be tight.
Most people seem to be most comfortable starting with a slightly small frame, and adjusting the seat higher (seattube angle is the same on both bikes), and adding a longer stem, taller steer tube as needed.
Fuji doesn't list the steer tube length, but let's assume it is adequate. Your shop or vendor should be able to measure.
Is it possible for you to test-ride the bike, or a similar bike?
If it was me, I'd get the L (58cm), or hunt for a similar 60cm bike.
Here is your chart:
L:831
XXL: 865
Thank you for your response. I've came to a similar conclusion and pulled the trigger. I've ordered the 58. Will post the results.
