Finished up the Masi
I never finish anyth
Bikes: 2008 Merckx LXM, 2003 Giant XTC mtb, 2001 Lemond Alpe d'Huez, 1997 Lemond Zurich, 1989 Cannondale ST, 1988 Masi Nuovo Strada, 1983 Pinarello Turismo
Quoted: 294 Post(s)
Liked 137 Times
The Masi is finished, almost a year and a half after I actually bought the bike. The paint was touched up by Duane at chestercycles.com. You'll notice the Roadlink, which lets the RD clear a 30t cog.
Build info:
1988 52cm Masi Nuovo Strada - got some additional info so I'm going with 1988, unless someone has better info
Tange Falcon cartridge bearing headset
10sp Chorus levers
Comp Triple FD
Chorus medium cage RD
Campy 115mm Italian BB
Chorus 12-30 cassette
Comp Triple 52-42-32 (was originally a 30t small ring but I replaced that with a 32t to help the chain wrap a bit)
Wippermann Connex 10s chain
Chorus dual-pivot calipers
Campy cable set
Chorus hubs, Mavic tubular rims, DT Swiss spokes, laced by me
Vittoria Corsa Speed G+ tubulars
no-name 27.2 seatpost (for now)
Fabric Scoop Race saddle - TI rails
Cinelli 1A stem
Cinelli 64-40 handlebars
Bontrager Grippytack bar tape
Xpedo M-Force 3 SPD pedals
Thanks to @RobbieTunes for some of the parts and help getting the shifting dialed in.
Here's some photos:
Build info:
10sp Chorus levers
Comp Triple FD
Campy cable set
Cinelli 1A stem
Here's some photos:
Dale, NL4T
Dale, NL4T
Last edited by speedevil; 10-02-19 at 08:03 AM. Reason: added build info, updated photos
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,180 Times
SD,
You've done an incredible job on the build, I have been looking for one of these for quite a while....Just Super!
Ben
Ben
Voltaire
Voltaire
Hi,
congratulations, the overall effect is very harmonious.
The combination of rims and tires is particularly pleasing. Real vintage feeling. What kind of tires are they? To what extent did the painting need to be improved?
Quoted: 294 Post(s)
Liked 137 Times
The tubulars are Yellow Jersey tubs, and will be replaced by some Vittoria Corsa tubs very soon. The paint touch-up was not extensive, mainly some scratches on the seatstays and the top tube. All of the decals were perfect and weren't touched. After the touch-up the frame was clearcoated. Duane does very nice work.
Dale, NL4T
Dale, NL4T
Hump, what hump?
Bikes: See signature
Quoted: 337 Post(s)
Liked 227 Times
Beauty! Nicely done.
Bikes: Masi CXR, Trek Crossrip 3, Trek 5500 OCLV, 1982 Bianchi SS, Civia Kingfield Belt-Drive Commuter, Cannondale T700, Cannondale R600, Cannondale R800, Centurion Dave Scott Ironman Expert, 1988 Peugeot Nice, Marin Bobcat Trail 3 29er MTB.
Quoted: 51 Post(s)
Liked 54 Times
Wow! I wish it was finished and you were bringing to it with you for our Peoria ride on Saturday! See you soon.
Quoted: 3241 Post(s)
Liked 2,512 Times
That's purdy!
Quoted: 1163 Post(s)
Liked 442 Times
I concur! Very nice! That is quite a wide range of gearing!
Any issues with the Road Link such as a sacrifice in shifting precision over the smaller cogs in order to have the capability to access that low 30 tooth cog?
I suspect that better braking performance is the reason behind the Kool Stop pads but couldn't you get similar stopping power from some more original Campy pad holders with Kool Stop inserts? Those long universal/V-brake/canti posts look a little too garish to my eye.
Quoted: 294 Post(s)
Liked 137 Times
@masi61, I have Campy brake pads enroute, and they will go into the original Campy holders. The the Koolstops will be gone, from this bike anyway.
The first set of Campy pads I bought didn't fit the holders properly, so I used what I had to get the bike on the road. The original Campy holders and pads will look much better.
Shifting is pretty good across the range, better than I thought it would be. If only there was a long cage Campy Chorus rear derailleur... But I've never seen one. The medium cage I bought for this build was pricey enough.
Dale, NL4T
Dale, NL4T
Edumacator
Quoted: 2436 Post(s)
Liked 3,119 Times
Gorgeous. Paint looks pristine.
Bikes: '8? Ciocc Mockba 80, '82 Ron Cooper, '84 Allez, '86 Tommasini Racing, '86? Klein Quantum, '87 Ciocc Designer 84, '95 Trek 5500, '98 Litespeed Classic, '98 S-Works Mtb
Quoted: 226 Post(s)
Liked 309 Times
I like it, then I'm a sucker for Italian's
Dean
Dean
Roll Me Up and Smoke Me When I Die
Likes For Dean51:
Quoted: 378 Post(s)
Liked 1,409 Times
A long and deservedly painstaking build. Dale is just enough OCD (OK, a lot OCD) with his builds, and they show it. His Masi and Lemonds are showroom stuff. He has another that I like even better, but I'm not going to out that one.
The Roadlink was not supposed to work, or at least is not claimed to work, on Campy. It did in this case, and on a triple. So now, it's Italian, it's marvelous, and it climbs.
His builds have convinced me to use Duane at chestercycles.com for my touchups, too.
Now, about that all Campy thing....
Likes For RobbieTunes:
Semper Fi
Quoted: 1172 Post(s)
Liked 358 Times
Turned out right nice, well done sir, very well done.
Bill
Bill
Semper Fi, USMC, 1975-1977
Likes For qcpmsame:
Liked 442 Times
The idea of using a road link with vintage Campy is such a cool idea. I have an 8 speed Ergopower Record shifter set and an 8 speed era (Athena or Chorus) short cage rear derailleur, both in good condition that I bought with the intention of trying this combo with a Shimano 7 speed rear cassette application.
I heard that Shimano 7 speed cog spacing is the same as Campy 8 speed cog spacing so by setting the low limit screw on the 7 speed you can have a properly indexed 7 speed Shimano/Campy index cassette. Since I like racing triples I wanted to see if I could do a Shimano Dura Ace 7703 triple crank (for one example) with a Uniglide 12/23 7-speed close ratio Dura Ace 7400 cassette shifted with the mentioned Campy parts.
I guess one one just has to try out some of these ideas to see how they work. This is why vintage bikes are a hobby. We try things, sometimes they work swimmingly, other times they get mothballed as a learning experience. For my build mentioned above I’m really not sure if the Road Link would do anything for me since I’m not trying to run a 30 tooth cassette cog, what I really need is that longer cage to maintain good chain tension through the 3 triple chainrings.
One comment about your Masi frame color: Is that the original paint? It has a really great high gloss red but with a milky white undertone that is really classy. Did you buff it out yourself? What kind of polish/wax do you use to to bring up that excellent shine?
Quoted: 294 Post(s)
Liked 137 Times
@masi61 - almost all of the paint is original, just some touch-ups on the seatstays and the top tube. Then Duane clearcoated over all of it. I didn't buff it at all, just used some Mothers carnuba(sp) wax after applying 3M paint film on the underside of the downtube and the top of the DS chainstay. I do this (and on the sides of lugless headtubes) on all of my builds. The 3M paint film is practically invisible and will prevent cable rub and almost all of the paint chips on the downtube. I have leftovers from when I had paint film installed on my Corvette.
I used the roadlink to clear the 30t cog, but if my RD would clear the largest cog I'm using then it's not needed. My chainwrap exceeds the maximum recommended, that's one reason I swapped the 30t small chainring for a 32t - to try and help out a little. The chain is long enough for big-big, as I didn't want to risk ruining the RD or the frame. I do have some sag in small-small but I don't use that combination so it's not a real problem. With the front triple, small-small is pretty severely cross-chained anyway.
I added the build info to the first post. When the new pads get here I'll install them into the original Campy holders and replace the Koolstops. I'll probably replace the seatpost with a Ritchey Classic, but I'm not in a hurry to do that. The main thing I need to do is to tape on the Vittoria Corsa tubulars.
Dale, NL4T
Dale, NL4T
Senior Citizen
Bikes: Trek Emonda SLR7 Disc, Lemond Poprad, 1980 Colnago Super, '88 Specialized Rockhopper
Quoted: 69 Post(s)
Liked 576 Times
Beautiful bike! The frame looks exactly like the one I bought new in '89, although mine was 60cm... stolen from a gf's garage back in 2003.
Liked 2,512 Times
Hopefully it didn't start life as a Trek.
Likes For seypat:
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,831 Times
Nice work on a nice bike.
I run Campy 10 triple on my 'go everywhere' bike, but with CompTriple RD.
My favorite brifters, too!
Quoted: 1856 Post(s)
Liked 664 Times
@speedevil, I see you are using a Campy 12/30 with a 52/42/32 Comp triple chainset. I'm a little surprised at the Roadlink was needed with the medium cage Campagnolo derailleur, but I guess it's consistent with my experience. The Campy Racing T rear mech is medium cage (74 mm).
I put a 13/29 with 50/34 on a bike with a medium cage Veloce and it worked well. I also have a 12/30 with a 50/34 on another bike with a long-cage 89 mm Campy Chorus derailleur, and it works well but I needed help to size the chain. But it's good. I guess with your 12/30 it was a tradeoff between a Roadlink or seeking out a long-cage Campy rear mech. I know Campy long-cage are not easy to find!
