Road/ touring/ commuting bike recommendations
I'm currently riding a 77? Raleigh Record and have been for the past 12 or so years and have decided to upgrade. I've tried to find a replacement a couple times but I keep coming back to my Raleigh so I wanted to ask you all for recommendations.
Most of my riding is city riding under 20 miles or so per outting. What I like about my Raleigh which I haven't seemed to find in other road bikes or touring bikes is the geometry. I'm not sure if that's exactly the issue but I tried a "commuter" style bike and it seemed too laid back, like I was peddling a lot without much payoff. I guess I like to be more over the bike but I dislike how road bike tires are so skinny and fragile. Not sure exactly what kind of rims or tires I have on my Raleigh but know they're 27" not 700cc and feel much wider than most road bikes I've tried. I also prefer flat bars over drop bars. I know this is all over the place but I'm not exactly sure what I should be looking for or where to start. Interested in the REI 1.1 bike but not into the drop bars! Any guidance is appreciated
Quoted: 451 Post(s)
Liked 364 Times
What about this sort of geometry? https://www.rei.com/product/122465/c...es-cty-13-bike
Quoted: 212 Post(s)
Liked 83 Times
Tire width is not insurmountable; you buy a bike with a frame that can accommodate wider tires. If a typical road bike has 25mm or possibly 28mm, you might look for a frame that could accommodate 32mm, 38mm, even 40ish. Many hybrid style bikes can accommodate wider tires.
You seem to want a flat bar road bike with wider tires and a slightly more aggressive geometry. Flat-bar road bikes come in a lot of varieties. For my commuter I have a Cannondale Quick CX3. I would have preferred a Cannondale Quick 3, but CX is all I was able to find on the used market at the price range I was willing to put into the bike. Anyway, aluminum frame, flat bar, takes tires up to 43mm (but I run 32mm, and often with mudguards). In 1100 miles on this bike last year I had no flats, not one. I was riding on Conti GP4Season tires. As a commuter, I've fitted it with mudguards, lights, and a good rear rack for mounting panniers. I've ridden it up to about 30 miles, though I do prefer a dedicated road bike for rides over 20. But it's been a good bike; ideal for the purposes I have for it.
Quoted: 18411 Post(s)
Liked 15,531 Times
Are you planning to actually tour? A true touring bike meant to carry full loads (think Surly LHT) is going to be somewhat sluggish and heavy for around town riding. It's also likely to have drop bars unless you modify it or build from the frame up, which probably wouldn't be worth the cost. With that said, I commute (and tour) on my LHT.
Quoted: 212 Post(s)
Liked 83 Times
I can say that the bike has very good accommodations for mounting a rear rack, and for mounting mudguards. It's a nice platform for a commuter. And not too heavy for leisure riding either. But my nightly exercise rides (20-22 miles) and my weekend distance rides (40-60 miles) are done on my road bike instead.
Likes For daoswald:
Sunshine
Quoted: 10955 Post(s)
Liked 7,484 Times
wider tires than a road bike
geometry that isnt too laid back but not aggressive
So a fitness hybrid. Trek FX for example. There are tons of models with varying frame and component options. Its basically exactly what you describe.
Also, it pays to know what you like about your bike. You say you like the geometry, but you dont know what that geometry is. Finding that out will be good if you really want to get a bike with similar handling.
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
flat bar
I have a Trek FX 3. It is a complete blast on the road, much faster than I expected, and would make a great commute bike. On gravel, however, it is absolutely no fun at all except on the hardest and flattest of dirt roads. It's really a flat bar road bike with a lean forward posture that's really not good for dirt.
Likes For livedarklions:
Sunshine
Liked 7,484 Times
- An FX is a 'lean forward posture'? Really? I help maintain a fleet of 30 FX1 bikes each year and cant say I have ever considered it a 'lean forward posture'.
- A 'lean forward posture' is bad for gravel roads and dirt trails? Why? Most gravel raod bikes are drop bar(lean forward) because gravel roads are simply roads that are unpaved.
- Why would the road need to only be flat? The gear range on many FX hybride is very wide which will allow for easier hill climbing when loaded down with gear(bikepacking).
- The geometry(in my size) is more relaxed than most paved road bikes and seems perfectly acceptable for bikepacking and unpaved road riding. 72deg STA, 72.5deg HTA, 445mm chainstay, 62mm trail - all seems quite reasonable and hardly aggressive. The only outlier for geometry is the 62mm BB drop, that is a surprise, really. Its a surprise, but hardly a deal breaker. Oh, and it can clear 40mm tires which is great for bikepacking/gravel riding.
Just not sure how this bike is considered 'lean forward' or inherently bad for gravel roads. To each their own though- there is a reason why 'gravel' covers so many varied styles of bike geometry.
Likes For mstateglfr:
Bikes: 2017 Co-op ADV 1.1; ~1991 Novara Arriba; 1990 Fuji Palisade; mid-90's Moots Tandem; 1985 Performance Superbe
Quoted: 390 Post(s)
Liked 572 Times
Trek 7.3 FX vs. Coop ADV 1.1
I don't normally weigh in on these discussions but since I have commuted with both the Trek 7.3FX and Coop ADV 1.1 I thought I'd share what I experienced. (Besides, this is a great way of procrastinating on doing my taxes...)
My commute is 16-20 miles round-trip, depending on how I go. There is gravel and dirt on a portion of some of the routes. The bulk of my cycling is utility (commute, stores, errands).
For about 12 years I ran on a Trek 7.3 FX as shown.
Aluminum Trek 7.3FX, about 2006 vintage (past commuter)
It was a flat bar but I added bar end extensions so I could get a bit lower profile.
About two years ago the frame cracked at the bottom bracket so I had to replace it. I wanted steel for durability and imagine that I will do some touring when I manage to retire, so I wrangled a close-out ADV 1.1:
REI Coop ADV 1.1, about 2018 vintage(Current commuter)
Here are my observations on the transition:
1. The bar end shifters and drop bars took some getting used to. There was not as much reach as I was used to. Maneuverability is much lower than the flat bars since rotation is limited to keep from hitting knees/frame. I ended up replacing the stem with as long a reach as I could get (140 mm, if I remember right). That helped a lot. The bike is now much less "twitchy" and I have more knee room when turning. Overall, I spend 90% of the time on the drops. I like the bar-end shifters as I can just press down with the heel of my hand and upshift.
2. Time will tell, but I hope the frame is more durable than the Trek aluminum. I run with a fairly heavy pannier load almost all the time, and I think that may have contributed to the early demise of the Trek.
3. I ran out of real estate on the drop bar for mounting lights (I mostly commute in the dark). Solved with a bar extension.
4. I was used to using a handlebar mirror mounted on the left bar end. I've looked and looked and looked and I can't find any handlebar-mounted mirror that works with drop bars and bar-end shifters. I've converted over to a helmet-mounted mirror (Take-a-Look) which takes a while to get used to. Fortunately, I'd been practicing with the helmet mirror for about 3-4 months before the Trek failed, so I was ready.
Since most of my riding is either road or trail with relatively few stops and turns, I'm happy with the touring bike style overall. However, if I was in more of an urban setting where I had to maneuver more (sidewalks, bike lanes, etc.) I'd rather have the flat bar.
Finally, in terms of frame geometry, I dunno. I got used to both.
YMMV.
YMMV.
Likes For flangehead:
Tragically Ignorant
Liked 9,098 Times
I dont understand any of this.
By "flat", I meant smooth. On the road, my FX 3 is absolutely great on hills. I've ridden many hilly century+ hills on it, and I often pass right by people on drop bar bikes on climbs like they were standing still.
It handles like crap on bumpy gravel, and it is a really unpleasant experience. I would prefer my crappy cheap cx bike in that context any day. We can argue about why all day, but I don't see the point.
flat bar
YMMV.
YMMV.
The 1.1 does seem like a great touring bike at the price but as you've mentioned, since I'm doing 95% city commuting, I think I should go with something more agile.
Thanks for all the info!
Liked 15,531 Times
Back in October I did a group overnight camping trip. Most people opted for the gear transport option, but I carried my own stuff. At one point we came to a relatively tight right turn on a steep grade. I instructed the people in our sub-group to hang back because I knew I would have to swing wide and cut back to the right in order to make it.
There are a lot of old, better, Ralieghs that show up on Craig's listor E-Bay, or yard sales, etc . There are also a lot of Japanese bikes from the early eighties available. These bikes probably have similar geometries to you Record. Why not just get a bike from that vintage that has a cro-mo frame and good components?
If you indicated your location, someone might point you to a co-op or something similar in your area where you might find a bike to upgrade to.
Tragically Ignorant
Liked 9,098 Times
Been looking more into the FX3. Glad to hear you've enjoyed it. I was wondering if the FX4 is worth the couple extra hundred dollars...https://www.trekbikes.com/us/en_US/compare/
I don't like the specs on the 2020 FX 3, I think they downgraded the drive train. If you can get a 2019 or earlier, it's a bargain: https://www.trekbikes.com/us/en_US/b...olorCode=black
FX 4 looks like a good bike for the money, but didn't you just double your budget?
Quoted: 2604 Post(s)
Liked 1,928 Times
Heh. I sometimes chuckle inside when I try to take my LHT up something like a ramp from a riverside trail up to street level. Lots of tight corners can make it tough. I need one of those warning like you see on semi-trailers: "This Vehicle Makes Wide Turns." The long wheelbase has its advantages when loaded and out in the open. In close quarters, not so much.
Have you ever considered a touring unicycle?
Sunshine
Liked 7,484 Times
Tragically Ignorant
Liked 9,098 Times
I'm embarrassed to admit I got this thread mixed up with the guy looking for a $500 do all bike.
For what it's worth, I recently rode my 2017 FX 3 round trip overnight from Nashua NH to Amherst MA and it was great.
No problem That's comforting to hear...I talked to someone today at a local shop who said the FX4 is better for longer distances but it's nice to hear the FX3 is as well!
Bikes: Historical: Schwinn Speedster; Schwinn Collegiate; 1981 Ross Gran Tour; 1981 Dawes Atlantis; 1991 Specialized Rockhopper. Current: 1987 Ritchey Ultra; 1987 Centurion Ironman Dave Scott Master; 1992 Specialized Stumpjumper FS
Quoted: 209 Post(s)
Liked 178 Times
It’s not a necro-post if the thread is less than six months old, right?!
Great thread, sorry I missed it the first time through. The OP could be me, except my ‘92 StumpJumper is only 2/3 as old as that bike. But every time I look at new bikes, yeah, I just end up thinking that I want the same bike, because it really does answer all my needs. I mountain-biked on it with knobbies and the shock, then put on a rigid fork and slicks and did a five-week road-gravel tour between the Sierras and Los Angeles. Had the knobbies and shock back on for a while, but now I’m back to rigid and slicks and I commute an average of fifty miles a week on it.
I can include some dirt on my commute, depending on the route, and I find that it handles OK with 1.5” slicks. I even take it up trails sometimes (buffed single-track that we have put here in Southern Cal, not like rock gardens!).
As I write this, it’s becoming apparent that I’m cheap! I used to have two sets of wheels, but one set is shot and I’ve never gotten around to buying another. And why have two or three bikes, when one is enough for what I do?
Then I rode up GMR/GRR last week. It was fine and fun, but I wasn’t as comfortable at certain points as I remember being in the past. And of course, all the road bikes kind of pointed up my less-than-efficient steed.
But now I’ve learned that there’s a nice dirt trail that goes down from GMR. And now I’m thinking of the kind of crazy ride I like to do - go up GMR on the road for 9 miles or whatever, and come down on the dirt. I wouldn’t hesitate for a moment to do that on my bike. Is it just a pipe-dream, or can I find a new bike that will do that?
Anyway, I should probably start my own thread, but thanks for all the good info in this one. Has given me ways to think about what I want in a bike.
