1990-ish Raleigh 12 Speed to SS/Fixie?
I have this old bike out in the garage. I have been thinking about converting it into a single speed or a fixie. I have watched videos of people doing sim. work on youtube. I would need to buy the following: new tires and probably new rims, new 46T chainring, rear hub conversion kit, caliper brake for front tire, lock ring tightening/chain whip tool, etc. I have a basic set of wrenches & allen keys, but none of the bike-specific tools that may are required. I guess that I could get the local bike shop to help with some of the things that I don't have the proper tools for. It seems like it would be better to just buy a whole new bike from bikesdirect.com or similar online place. What do you think? Thanks.
Horizontal. The rims seem pretty true, so I may be able to re-use them. I was hoping that I could put some wider tires on it. It has the really narrow "English Racer" tires currently.
Tortoise Wins by a Hare!
Quoted: 1549 Post(s)
Liked 941 Times
Are you mechanically inclined? If you are an avid rider and excited about working on bikes then start getting the tools as you need them and go for it. It will pay off in the long run and it's fun!
Bikes: United Motocross BMX, Specialized Langster, Giant OCR, Marin Muirwoods, Globe Roll2, VROD:)
Quoted: 238 Post(s)
Liked 404 Times
coopman.....it depends on what kind of $$ and time you want to invest on the "old" Raleigh.
Like AlmostTrick "said".....if you enjoy wrenching on bikes then go for it and buy some tools. Otherwise, I'd get the LBS to do the specialty work but if it's too costly I'd be looking at the used market for one.
Either way everyone should have a SS in their bike stable.......
bill nyecycles
Quoted: 789 Post(s)
Liked 350 Times
can you post a pic of the bike so we can see the components and what it all looks like?
I converted a mid-80's Raleigh 10 speed into a single speed a number of years ago and it's still my daily commuter. It has horizontal dropouts so it was easy. It was my first ever "rebuild" and I did it with minimal bike related tools. I did have to take it to a shop to get the original crank & bottom bracket pulled - then a new BB put in. I also had the headset serviced but not replaced since it was still good (I have a new one now though). The rest I did myself.
Ordered new single/fixed wheels, and tires. Stem, bars, levers, freewheels, cables & housing, bar tape. Replaced the seatpost after a few years. Minor tweaks, etc.
It's doable if you get a shop to do some of the more intensive things that require really specific tools. But as far as putting new stuff on - that's mostly just hex wrenches.
Mine went from this:
to this
to this
to this
over the last 6 years.
to this
to this
to this
Likes For the sci guy:
Thanks Sci Guy. That is a beautiful bike. My LBS is closed today. I will take it over to them tomorrow and discuss the road ahead.
Quoted: 586 Post(s)
Liked 612 Times
Also, time to think about your gearing. I'm guessing you might have a 52/48 on your bike. You can go with the 48 up front or buy a smaller chain ring with the same BCD. Then you simply need to calculate the size you'll need for the rear cog. If you stay with the 3/8" chain, you won't need a perfect chain line. Just make sure that if you buy a new chain ring that it is 3/32" and not 1/8". Same for the cog or sprocket in the rear.
bill nyecycles
Quoted: 789 Post(s)
Liked 350 Times
For what it’s worth on my Sportif above the Sugino crank is 48t and I’ve got a 17t freewheel. Both are 3/32”.
(I’ve also ran 46t/18t and 46t/17t)
You’ll find a lot of SS cranks are 1/8” but if you can I’d try to find one that’s 3/32”. Be careful though because I’ve ordered stuff before and the package is mislabeled - twice I received a 1/8” when the package and listing said 3/32” - I had to measure with calipers.
in my experience 3/32 is smoother and more quiet. You can run 1/8 chain on 3/32 stuff so you have the option to mix and match components if needed (for the longest time I had a 1/8 crank and ran a 1/8 chain when the freewheel was 3/32), but you can’t put a 3/32 chain on 1/8. So just be mindful.
biggest thing is to make sure your bottom bracket spindle length is correct for a straight chainline. Currently mine is 107mm. The bike shop chose that though so I assume they based it on my rear spacing and whatnot. This far its been perfect but you’ll need to check yours.
It's the little things
Bikes: Too many, yet not enough
Quoted: 279 Post(s)
Liked 326 Times
You could also try out basics with a chain break tool and simply shorten the chain assuming your middle ring and somewhere in the middle back cassette is a good ratio. This can be done for super cheap and give you the flavour before investing a pile of money on tools. This way if you don't like it, easy to flip back with longer chain.
That is what I did here...same wheels, same dish, just shorter chain. Just sayin...
Likes For natloz:
I have ordered a few bike tools that, once received, will allow me to get started. The guy at my LBS was not too receptive to the SS conversion idea. I really wanted to get wider tires for it, but the existing rims will not allow that. I am proceeding with this as a learning experience. At best, I'll end up with another bike to ride - at worst, it'll end up on the trash heap anyways.
bill nyecycles
Quoted: 789 Post(s)
Liked 350 Times
Also why wasn't he receptive? Post more details and maybe we can help more.
