Twitchy bike
Twitchy bike
I just recently purchased a used bianchi sl argentin bicycle which I test rode and found to be very twitchy and unstable and almost unridable. It also appears that the headset is very gritty and possibly pitted. Is the headset the cause of this problem or are the frame angles so steep as to cause it to be unstable?
Quoted: 5224 Post(s)
Liked 3,581 Times
can't answer your questions but if you've pumped your tire to their max pressure you might try the front tire 5-10 lbs lower. it carries less weight than the rear so it doesn't have to be as hard. a softer front tire will make it less twitchy. but have that grit checked out
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
Quoted: 714 Post(s)
Liked 800 Times
If the headset does not move freely, that is the problem. When we pedal, the front wheel turns slightly from side to side. It happens naturally and you don't even notice it happens unless your tires get wet and you can see the curvy line left by the front tire. When the headset doen't move freely, the front wheel isn't able to center itself an you find yourself having to manually correct it when you are pedaling. It is a very disconcerting feeling of not really having control of the bike.
Likes For dsaul:
Quoted: 18411 Post(s)
Liked 15,531 Times
You bought a bike after test riding it and finding it to be almost un-rideable?
Likes For indyfabz:
SE Wis
Quoted: 2746 Post(s)
Liked 3,390 Times
Has it been in a crash and the fork is bent?
Quoted: 1743 Post(s)
Liked 1,281 Times
Sounds like this bike needs a total and thorough inspection by a professional.
Likes For bruce19:
Quoted: 365 Post(s)
Liked 419 Times
What kind of bike did you ride previously? If I've ridden my touring bike for a while, and then switch to my "race" bike, the "race" bike does feel twitchy, it takes a few miles before I feel comfortable on it.
Not saying that's your problem, it's just something to consider. Also, if the headset doesn't feel right, it's possible that someone put in a new fork and didn't install the headset properly, which also means that it's possible that they installed a fork that isn't appropriate for the frame geometry. Can you tell if the bike has the original fork?
Cycleway town
A stiff or sticky headset makes a bike horrible to ride.
Quoted: 2482 Post(s)
Liked 2,952 Times
Embarrassing story: I hated the handling of one of my bikes, blaming the frame geometry, and rode it only occasionally for 5 years. Then it occurred to me that the (Allen-bolt-secured) cable hanger for the front brake might have been interfering with the headset adjustment. Loosened the Allen bolt, adjusted the headset, tightened the Allen bolt, and suddenly the bike handled like a dream.
Quoted: 1572 Post(s)
Liked 643 Times
The frame geometry doesn't look crazy .
...or the opposite. I rode with a loose headset once. Man, I had a heck of a time trying to keep it in my lane!
Sunshine
Quoted: 10955 Post(s)
Liked 7,485 Times
And nobody here would know why you bought a bike you can barely ride.
I purchased this bike on Ebay and test rode it after I bought it. I have purchased many bikes on eBay without problem and the headset problem was not mentioned. I just took my headset apart and it is somewhat pitted and I will replace it. I may not have been explicit enough.
Quoted: 850 Post(s)
Liked 344 Times
Are all the spokes tight and wheels straight and true? I would definitely go all though the bike and check everything.
Quoted: 451 Post(s)
Liked 364 Times
I suspect you will find the cause of this once you've had it properly checked out by a competent mechanic. Well worth the cash outlay. That said, some bikes are just known for being a bit on the twitchy side. I bought one of those,a nice Wilier, and I did not like the ride initially, coming from an Orca. But you can learn to manage it and then, after some practice, it really isn't bothersome anymore. So, just keep that in mind. You can get accustomed to it with some practice and then, everything will be fine.
