Raleigh Experts, what is this?
Quoted: 39 Post(s)
Liked 31 Times
Is this anything special, seller listed it as a Sprite, is he correct? I have never seen a Raleigh with Dot Decals on the seat tube. For 30.00 i am sure it is good to ride around the neighborhood, or is it worth putting time and effort to clean up?
Thanks for any input
Ruben in So Cal
Ruben in So Cal
Señor Member
Quoted: 1491 Post(s)
Liked 1,090 Times
Are those dots, or drillings? Drillings would be a deal-breaker for me. No reason to think it isn't what's advertised. It doesn't have the Sports/Superbe fork, so Sprite sounds right.
If the bike fits you, and you have a use for it, and the wheels are true, it's $30 better spent than on almost anyone else's comparable machine. Also make sure the stem and seatpost aren't stuck. That saddle ...
Likes For USAZorro:
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
Tell us what tune the flute plays as you ride when you test ride it!
Quoted: 1088 Post(s)
Liked 1,205 Times
There is just something about how those dots don't shine in the same way the green paint does in the same light that bothers me. This is one needs to be seen in person.
The dropped
Liked 1,014 Times
(The edges of a couple hint at an edge, and the reflection on the tube is distorted in a few spots.
Liked 1,205 Times
They were very obviously holes, when I looked at the larger image. My biggest questions are if it's the original tube that was drilled, or a 'convenient' replacement, and if they were drilled, what the reason was.
Sure looks like a Holy Sprite. Somebody went and ruined a perfectly good $5 frame. Looks like the front tire might need some air, too.
My wife has a 1974 Sprite 10speed and likes it quite a bit. They weren't bad inexpensive bikes for tooling around though the Huret mechs were other than "crisp". Same ones as used on the Schwinn Suburban, I think.
I've read that the frames were the same ones as used on the Record
The dropped
Liked 1,014 Times
Quoted: 964 Post(s)
Liked 1,451 Times
Ehh, it's probably fine. Those were made of pretty thick tubing and the metal is soft so it'll bend more than it would crack. Just listen for creaks when you ride it, and maybe put a cork in the seat tube so water doesn't get into the bottom bracket bearings.
The rims being rusty would be a bigger deterrent for me. If they're too far gone and the rust is too rough-surfaced and can't be corrected, the rust will grind down the brake blocks in a hurry.
Likes For francophile:
Quoted: 39 Post(s)
Liked 31 Times
Yes those are holes
I never even thought of the possibility the seat tube was swiss cheese, but i just spoke to the seller and yes 'for some reason someone drilled a bunch of holes'
I'll pass.
Ruben
I'll pass.
Ruben
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
You probably need to buy it because of the holes, and definitely for the "most corroded Pletscher rack."
PM me your cotters
Quoted: 1137 Post(s)
Liked 590 Times
It looks like a Raleigh Record I flipped not long ago, down to the color and drivetrain. What's the difference between the Record and Sprite, realistically?
Never ceases to amaze me what some folks will do! Although it almost has a cool aesthetic.
The dropped
Liked 1,014 Times
Surprisingly, not far off! Miyata first manufactured rifles before they were asked to build a bike, using their knowledge of manufacturing steel tube...
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 531 Post(s)
Liked 1,004 Times
Mossberg and Browning have made bikes too. And don't forget Birmingham Small Arms.
Quoted: 796 Post(s)
Liked 522 Times
And Royal Enfield ....
Quoted: 457 Post(s)
Liked 462 Times
You would have to ride that bike so hard for the holes in the seat tube to actually be of concern.
I'm not saying those holes are desirable, but, uhhh, somebody actually got off the couch and placed those holes there, they deserve a tiny bit of credit for that. They are pretty straight/symmetrical.
verktyg
Quoted: 1036 Post(s)
Liked 1,238 Times
57mm "Reckless Rifle"
verktyg
Chas. ;-)
Chas. ;-)
Likes For verktyg:
Should your seatpost ever become stuck, you have great access for spraying your favorite penetrating oil. Or cross drill the seat post and be the first in your neighborhood to use a clevis pin instead of a pinch bolt.
I.C.
I.C.
Likes For Insidious C.:
Blamester
Looks like the seat tube is bent at the FD.
Where they built with that tight clearance?
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,395 Times
Quoted: 767 Post(s)
Liked 1,898 Times
Rare and obscure Raleigh Sprite Lawn Boy Special. Pay off the purchase by earning money watering lawns with the built in high-volume sprinkler system.
Trailer and water buffalo sold separately.
Likes For BFisher:
