Eking out rear end compliance
Quoted: 850 Post(s)
Liked 344 Times
I have a very non-compliant bike and am quite light. I’d like (a lot) more rear end compliance but am unsure about where to start. I have a very supple 28mm (measures 30) rear tire and I usually run it between 50-65psi. I have an aero post so a suspension post is a no-go.
I’m looking at the Selle Italia SP-01 Boost saddle. Does anyone know if this would be significantly more comfortable than a specialized power (steel rail) saddle?
Quoted: 4845 Post(s)
Liked 3,974 Times
Ben
Quoted: 850 Post(s)
Liked 344 Times
I ride steel railed Specialized seats on a couple of bikes. They are quite firm. I'd expect most Selle Italias to be more forgiving, this seat quite a bit more. (I've ridden Selle Italias since the dark ages, both under their name and under other brand names.) If you go with the titanium railed version that would be yet another step more forgiving. I ride ti railed seats on most of my bikes for the comfort. (The carbon railed version might be also. No experience there.)
Ben
Ben
I tried looking it up and I can’t see any evidence that carbon rails are more comfortable than any Ti rails. So I’ll stick to the Ti for sure.
Quoted: 850 Post(s)
Liked 344 Times
I’m quite hesitant to try a saddle so different in shape from the power (the boost is quite similar) because it suits my aggressive riding style quite well. I don’t think I’d get on very well without a wide cutout.
Quoted: 1067 Post(s)
Liked 259 Times
Any normal sort of saddle is not going to make a significant difference in compliance.
I also have an Allez Sprint but I have no issues with the comfort/compliance (25mm tyres).
Maybe you just need to get used to it.
Quoted: 850 Post(s)
Liked 344 Times
But I appreciate your input about saddles contributing to comfort. I know there is a very low ceiling on how much comfort can be eked out of this bike given my constraints but it’s either that or getting a new bike way earlier than I’d like to.
Quoted: 3253 Post(s)
Liked 2,541 Times
You could try a Selle Turbo. People have been riding that design for many years.
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
The flexible base on some of the Fabric saddles really smoothes out rough surfaces. I use it for gravel.
The "Line" model has a cutout. I'm not sure if it has a flexible base.
-Tim-
I run the Turbo saddle on my daily riders, and they are not soft by any stretch. They fit my sit bones perfectly so I use them. A bike with 30mm tires inflated to 65psi should be fairly soft in rear. A suspension post may help, but is the problem on the sit bones or in the back?
Quoted: 850 Post(s)
Liked 344 Times
You might want to take another look at your tire inflation. The numbers you list are what works well for me on the same size tire and I'm considerably heavier than you. Have you tried 5 psi less than what you have there?
J.
J.
Quoted: 14 Post(s)
You could try going tubeless and running even lower pressure....though 50-65 PSI in a 28mm tire seems pretty low already.
Quoted: 850 Post(s)
Liked 344 Times
I was hoping someone would point to something like an elastomer saddle mount that connects to the seat post, and then has the saddle attached above it. Basically ghetto isospeed. I guess if it hasn't popped up by now I'll have to resort to trying out other saddles (my butt and wallet get nervous around the concept of random trial) or possibly jerry-rigging my own one day...
I have gone as low as 45psi in technical, wet races. By that point, however, hard accelerations start feeling quite draggy despite using P Zero tires (which are very supple). I plan to go tubeless with vittoria corsas next, which should allow me to run that kind of pressure in less demanding circumstances, but if I can have comfort without sacrificing as much RR or responsiveness, I'd like to do that.
When I went to 30c tires from 25c that made a big difference - giant in comparison to each of the changes I had made before. When I went from tubes to tubeless that made another big difference (together with lower tire inflation) and my average speed on that bike was the same with the larger tires and plush ride as with the 25c tires and harsh ride. I was able to take my 30c tires down to around 55psi and I weight just over 200. That's why I thought that you could take yours down a bit more given you weigh less and you're tires are coming out around 30c.
In some of the reading I've done on this topic, it seems that the tires are about 10X the effect of the other things you can do to increase compliance. My experience supports that pretty closely, I think. Biggest impact on vertical compliance is tires and inflation. Only caveat to that would be this presumes you have a saddle you like and can do long miles in. Otherwise, an ass hatchet saddle is going to be a problem no matter what.
So, if it were me, I'd go tubeless and try that out. Presuming your rims are tubeless ready (maybe not a good assumption), that is the easiest and cheapest fix. Then ride a loop taking the tire pressure down 5psi at a time and seeing what happens. One source suggested that you keep doing this until you lose the high frequency road "feel" and feels smooth instead. When you do that, you've apparently optimized inflation. I'll try that as soon as the snow melts here (another 2' to go).
FWIW, the tires I used for tubeless rode like truck tires with tubes in them and were night and day different when I mounted them tubeless. Those were the Schwalbe G-1 speeds in 30c. Imagine my surprise when I discovered that my average speed was the same, I was riding heavier tires and the ride was plush. Palm hits forehead moment.
J.
Tires are 90% of what is being called compliance. Or comfort. Unless you are truly a featherweight 50psi in a 30mm tire should take care of it. If it doesn't, you have a lot more analysis to do.
Most mass market products are made to survive Clydes. They have to be made stout or they get absolutely trashed in fora like this one. And then there is the fear of litigation.
If the problem is the frame then replace the frame. You could try twenty saddles and ten springy seatposts and not get there. Sounds to me like what you want is not a mass market frame and not a niche frame. You want a custom. That or explore antique frames from when racers did weigh 120 and 140 pounds.
Yea, I'd go for a suspension seat post ... Cane Creek eeSilk is their new light ,gravel market, seatpost ..
Ti frame with an elastomer Monostay insert ... ?
Quoted: 850 Post(s)
Liked 344 Times
For reference: the pro category of the race that triggered this thread in the first place was won on the same bike that I have. The guy is obviously harder (he crashed twice the day before) than I am but doesn’t weigh too much more from what I can tell. Perhaps this gives more weight to the “HTFU” arguments but I’m always going to be looking to improve my experience on the bike, because I’m doing this for fun, not as a chore.
Anyway, road.cc released a very timely review: https://road.cc/content/review/25780...onio-superflow
Both bikeradar and road.cc agree that the SP-01 saddles are noticeably more comfortable than average. however, Im not sure whether this is just parroting of Selle Italia’a marketing (most professional reviews seem like that) or it’s actually true. Which is why I was hoping for some real world reviews.
Quoted: 20810 Post(s)
Liked 9,456 Times
I don’t think I want to go for an antique frame and give up the responsiveness/weight/handling of my bike just yet. I am considering custom but for now, several thousands is a bit too much for me to spend.
Here's why tires matter so much and why frame is second. Tires contact the road first. They are furthest away from your body. They have leverage. The distance from contact patch of tire to your butt is the length of the leverage. Next is the frame. Many parts to a frame and the length of lever is variable. Still, the difference in leverage between a frame and a saddle is substantial. Most current frames are just rocks, no compliance worth mentioning. But there are some with substantial compliance. Titanium moves just as much as steel if designed properly and then throw in something like a MootsYBB rear end. Of course there are gizmos like Spec Diverge and Trek Domane. Most of these are love it or hate it. All work to some extent. Try them. You do not know what you are talking about if you don't try.
The other part of leverage. Your 30mm tires have a safe 20mm of suspension travel and a possible 29-1/2mm. Spec Diverge moves 20mm. An old school steel fork built from Reynolds Super Resilient forkblades has 20mm travel. How much does a saddle move? How much could it move? If it were moving how long would it last? My ancient Selle Italia Tubomatics with elastomers between shell and rails might have had 2mm of travel and I loved them. Lasted a couple thousand and done. Still a good saddle but no more travel. More movement than that and the leverage you, the rider, create to control the bike is getting lost.
There are not easy answers. Experiment. Try to think through the problem. Don't buy product at random. The more different stuff you experience the more you know. Doing it at random takes a lifetime and then some.
Quoted: 850 Post(s)
Liked 344 Times
Your current saddle is apparently working 90% of the time. That's pretty good. Saddles are intensely personal. No one else's experience or recommendation means much. It is the case that most who ride much have a collection of saddles going. Some would rather not admit it, they have the saddles. Borrow someone else's and try before you buy.
While compliance will probably be the #1 factor in my next frame purchase, that is out of the scope of purchases I am willing to make as of right now. I have given it quite some thought though.
Tires could give me 29.5mm of give (much less considering sag), but at that point I’d be running the tires too low to be fast. The question isn’t “how can I get more comfortable?”, the question is “how can I get faster by finding gains in comfort?”. As far as I know, dropping my pressure any lower would not be an answer to the second question. So let’s say the tires give me 8mm (this number is a complete guess, correct me if I’m off) of suspension beyond the sag point for medium bumps (as opposed to hard square hits). A saddle designed to give me even 2mm (I imagine it may be more for hard hits) would be a 25% gain over my tires. So I don’t need much. Carbon doesn’t fatigue too much over time so I’m not worried about that, and the nose of the saddle theoretically should provide a stable pedaling platform when putting down power.
I’m going to call my dealer and see if I can get a trial going or if anyone online has one nearby that I can borrow. Thanks for your input.
