Which side do you ride on?
Bikes: Brompton M6R, mountain bikes, Circe Omnis+ tandem
Quoted: 146 Post(s)
Liked 6 Times
Gentlemen, which side of the saddle do you ride on?
In the interest of avoiding damage to the nether regions, should this delicate question not be asked by fitters of bicycles, just as a similar query is often posed by tailors? Ought a saddle be mounted a few millimetres off to the left or right, depending on one's preferences?
Quoted: 3370 Post(s)
Liked 5,491 Times
I ride on *both* sides of the saddle.
Quoted: 1854 Post(s)
Liked 661 Times
Your equipment needs to be up and out of the way. If some part of it gets caught between the saddle and your thigh, you might feel something a bit unpleasant.
It's one reason to wear the little elastic shorts and to get the correct size.
Bikes: 61 Bianchi Specialissima 71 Peugeot G50 7? P'geot PX10 74 Raleigh GranSport 75 P'geot UO8 78? Raleigh Team Pro 82 P'geot PSV 86 P'geot PX 91 Bridgestone MB0 92 B'stone XO1 97 Rans VRex 92 Cannondale R1000 94 B'stone MB5 97 Vitus 997
Quoted: 392 Post(s)
Liked 49 Times
I ride center and I think most people do.
Bikes: We love all bikes
I do believe most people ride slightly to one side or the other. Sometimes it is OBVIOUS and most of the time it is very subtle.
Keep in mind the pelvis is usually rotated on most humans to the left so sitting perfectly centered is probably not a reality for most.
Here is an obvious one
Prefers Cicero
It depends on your seating position, clothing and saddle. If you are wearing bike shorts and on a narrow racing saddle, the stuff rides high and central. You may have to do some adjusting and discrete tugging from time to time to keep it in place. The central member may be pointing straight ahead or tucked off to one side.
If you are wearing loose clothes and sitting more upright on a cruiser or Dutch style commuter, there might be a bit more draping to one side or other (or a little of both) but you don't want any crushing between thigh and saddle nose, so you still want the stuff to ride a bit high.
I find it all stays in place as long as I stay seated, but if I stand on the pedals for a bit, I may have to reach down and grab the stuff through my pants and pull it all up a bit when I sit, so it's back where it should be. I try to be unnoticed when i do it, but you can't always.
I do find I point the saddle a tiny bit to one side, but that is more to make my butt comfortable
Quoted: 955 Post(s)
Liked 1,619 Times
Left knee hurting left side - Right knee hurting Right side - Hands going numb back side...
Quoted: 392 Post(s)
Liked 49 Times
As you descend toward the saddle, do a snappy little pelvic thrust, the stuff flies up and as you settle onto the saddle it all comes down and drapes nicely into place. It helps to be a transsexual transylvanian and wear a french maid's dress.
Liked 5,491 Times
And bring your knees in tight.
Bikes: 20" Folder, Road Bike
That is more about very badly fitting clothing and has no technical basis at all.
rgds, sreten.
No. The position of your bits on a saddle has nothing to do with which side
your bits hang dressing, just as much as tailors only ask to avoid the hanging
side when measuring your inseam, it makes no difference to the tailoring.
rgds, sreten.
FWIW I always dress to the right, being a lefty, apparently most
righties go for the left, which makes sense if you think about it.
Liked 5,491 Times
Hi,
rgds, sreten.
rgds, sreten.
Liked 661 Times
Hi,
rgds, sreten.
rgds, sreten.
briankari
Are you sure? Badly fitting clothing? Not a leg length issue forcing one leg to reach? or as the post indicates, a rotated pelvis. badly fitting clothing seems a bit short-sighted...
Short sighted ? In looking for the technical your missing the bleeding obvious.
Said chaps pants are clearly rotated anticlockwise ; Why ? Don't ask me.
Perhaps he dresses to the right and needs to twist his pants like that.
rgds, sreten.
I'm not saying the chap doesn't have issues, I am saying the poor
clothing fit for whatever reason makes things look much worse,
and very hard to judge if there are real issues, its not obvious.
Why his pants are like that could be quite a few reasons, but the
photo does not show someone riding on one side of the saddle.
I guess I too have a hard time seeing the "bleeding obvious" here. Are you saying his bibs are way too big for him? That might cause bunching and twisting- and then I'd see your point (thought the clothing looks tight to me). If they are too tight, I can't believe his shorts would twist so much. What I see, to be honest, is this chap has more of his glutes leaning to the right side and less leaning to the left.
Hi,
rgds, sreten.
photo does not show someone riding one one side of the saddle.
rgds, sreten.
Passista
Quoted: 866 Post(s)
Liked 720 Times
I think I ride on center, but my saddles tend to wear more on the left side.
Lost Again
Just ride one of these and tuck your junk in the slot.
Believe me, you'll remember to unclip your shoes every time you stop.
The midseam of his shorts is nowhere near his arsecrack.
You are missing the obvious, his clothing is out of kilter,
to such an extent its impossible to judge any real issues.
rgds, sreten.
Again not saying no issues, just hard to judge.
The clothing fit makes things look much worse.
