Santy/Gitane?
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1297 Post(s)
Liked 940 Times
Santy/Gitane?
In the mid-1970's brothers Elain and Guy Santy rode for team Gitane.
I would like to know if it was Gitane who made the frames with the Santy name on them.
Quoted: 3814 Post(s)
Liked 3,345 Times
in about 1970 MICMO was able to pull away from Urago the highly respected constructeur Brouquis (do not know spelling; have only heard name) for the creation of the true team cycles.
possible he may have been the maker. have no hard information.
yours is the sort of excellent question best posed to Norris. if you are on the CR list you could do it there as well...
Bikes: Since new: 86 Rodriguez Tandem, wife's 87 Gitane Team Pro, 92 Burley Rock-n-Roll, 85 Fisher Comp, 88 Puch Pro, two 92 Bridgestone X0-1s; later: 66/67 Gitane Champion du Monde, 70 Gitane Super Corsa, 70 Carre, 87 Gitane Team Pro, 77/78 Ritchey Tandem
Quoted: 149 Post(s)
Liked 366 Times
That certainly looks like a MICMO swagged and crimped seat stay finish as found on both Gitanes and Geminianis in first half of 1960s. This finish was found on bikes a tier or two down from top...your frame doesn't have the Nervex Pros seen here so yours is likely at least two or three tiers down from top. This seat stay finish doesn't appear to extend into 70s; however, replaced by the swagged finish that was just bent over and brazed shut (search for Chas' late 60s into early 70s Gitane seat stay cap posts). That all said, your Stronglight 93 suggests later 60s/70s.
Liked 3,345 Times
wrt seat stay treatment -
this seat stay design was employed by a number of french makers and is not in any way a MICMO signature item
two well known makers who used it extensively were Bertin and Urago
1989Pre -
the image you provided of the complete frame is too dimly lit for readers to be able to see much detail. you would likely get more meaningful response with a better photo...
1989Pre -
Likes For juvela:
Quoted: 149 Post(s)
Liked 366 Times
juvela, I'm going to respectively disagree. True that both Bertin and Urago used a swagged and crimped seat stay finish but their versions used a completely different crimp that resulted in a pinched ridge that runs down the center of the seat stay finish. Here are a couple of Uragos (navy blue and dark blue...two different frames) and a couple of Bertins (medium blue and orange) and you can see how the seat stay finish has this distinctive pinched ridge down center. On MICMOs a single crimp creates a valley in center of the swagged finish...that all said, in looking at the seat stay cap of the bike in question, what I was seeing as a "valley" may in fact be a "pinched ridge" … so maybe I don't disagree with you on this particular bike …. better pictures would help!!! and if that is a crimped ridge, I would not think this is a Gitane.
Standard Member
Liked 940 Times
Thanks, people. I'm asking for a friend, so I will ask him to send some better photos.
Liked 3,345 Times
Thanks so much for your patient & thorough response Markeologist!
Most excellent information.
My error in not being more careful; make far too many...
1989Pre -
thank you for the reply
in the initial post it is unclear to me if the frameset shown is thought to be one used by one of the Santy brothers in the course of their career or if it is an example of production bicycles done with the Santy name
MICMO certainly produced bicycles with names of past champions such as Roger Riviere and Raphael Geminiani, among others
asking about this as the Santy name is new for me
perhaps when you next communicate with your friend you could get some clarification
thank you again
1989Pre -
thank you again
Standard Member
Liked 940 Times
Yes, I have contacted him, Juvela, and he will reply shortly with better pics and some more info.
Quoted: 149 Post(s)
Liked 366 Times
1989Pre -
thank you again
1989Pre -
thank you again
Likes For Markeologist:
Santy bicycle
Thank you all for comments and information! A specially to member 1989Pre for helping me in my quest. I’ll post some additional photographs later on this evening but have already some remarks on the construction dates I’ve seen mentioned. Without knowing the provenance of the bike neater if the current headset, stem and crank are the original equipment but the frame and fork has Reynolds 531sl decals (launched in 1975! According to the Reynolds brochure of 78) ... to my opinion original (even disintegrated as the paint) yet possible applied many decades ago ... so I’m leaving this in to your hands what it should or could be, all information is welcome. Thank you all in advance. Greetings Dirk
Liked 3,345 Times
Hello Dirk,
Thank you very much for your post.
Minor note on chainset FWIW -
the Verot-Perrin model 93 was produced 1967-1977
it was revised in 1972 to add more material around the pedal hole so pre-'72 might be termed G1 or "early type" and '72 onward examples G2 or "late type"
in this image the drive side arm is early type and non-drive side arm is late type:
in 1977 it received a reworking to create what became the model 105
mention only in case it may be a dating aid...
thank you again for posting
Hello Dirk,
Likes For juvela:
Liked 3,345 Times
...two workarounds for the ten post requirement are to
a) post images to your member's album on your member's page
b) post images to a third party host and post the URL here in munged form (with a decoder text if you think it might be needed)
