Heel replacement for Specialized Ember road shoe?
TeeOhPea 2tha DeeOhGee
Specialized says they no longer support or have parts for their Specialized Ember women's road shoe.
Does anyone know where I might get a pair of heel replacement for this shoe sized EUR 38 / US 7.5
I hate to think these otherwise good Specialized shoes are disposable due to simple and predictable heel wear. !?!?!
Then...assuming I get the part...how would you replace it? Do I have to drill out the white plug remains highlighted and just press a new heel in?
(Before anyone gives me grief for not replacing these sooner...they are my girlfriend's shoes. I wear Sidi and have never had trouble replacing their heels with the screw system they employ.)
Quoted: 4806 Post(s)
Liked 3,932 Times
Have you considered taking them to a cobbler? Should be not too difficult to cut a piece of rubber sole in the shape of that piece and glue it on. (I have cycling shoes a local cobbler has modified a lot that have lots of walking on them and have help up for years. Compared to what he has done, this is a piece of cake.)
Likes For 79pmooney:
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
Liked 3,932 Times
What do you use for glue? I've had excellent results with 3M 5200 but it is very expensive, messy to use, requires vary aggressive solvents and the container gives you about 3 days before it hardens after opening. (Line up a lot of projects.)
climber has-been
Liked 3,567 Times
Likes For terrymorse:
Thanks to you and the other 3-4 posts here suggesting DIY fix. It crossed my mind, but wasn't sure I could do something durable.
She loves the shoes, and you know how it is when you get something you've gotten comfortable with over a long time.
I have a good shoe guy and will try this.
Thanks you. As mentioned in the other post, I thought about DIY, but dismissed it. With everyone saying it can be successfully done, we're going to try it.
Clark W. Griswold
Quoted: 4358 Post(s)
Liked 3,998 Times
Probably the worst that will happen with DIY is you are back to square one and the best is you have a new heal. I bet one of these folks with the 3D printers could make a heal for it with some dimensions. Potentially make a nice tracing and then figure out the thickness and badaboom you have a heel!
Likes For veganbikes:
The most simple and easy solution is using Shoe Goo. I put down 3 layers over 3 days and it works just fine. Shoe Goo can also be used as an adhesive to glue down a rubber heel as suggested above.
Quoted: 6972 Post(s)
Liked 10,970 Times
After looking at this thread, I went out to the garage to look at my road shoes. One heel is completely missing, and the carbon fiber sole is worn through. Huh.
The heel pads on my ancient but perfectly serviceable SPD shoes had disintegrated and one carbon heel was being abraded away. I used a $3 block of "modeling clay" to build up molds on each heel, then filled them with JB Weld. After the epoxy set up, I peeled away the clay and had new heel pads. Sealed the edges with some more JB Weld. A bit noisy/slippery on tiled floors, but otherwise very hardwearing. Should last the remaining life of the shoes.
Wow. Those look great. Nice work.
I'm not particularly handy, and I have a good shoe guy. I'm going to pop the remains of her current heel off so he has a relatively flat surface to work with. I'm sure he has the right sized heel and proper glue to put something on that will work. Might even be better than the original.
Damn!... Gonna show that to my girlfriend. She felt bad she let her level of wear sneak up on her un-noticed. She'll feel less bad when she sees the grind down job you've done.
climber has-been
Liked 3,567 Times
Shoe Goo has about the same hardness as shoe heel rubber. I used to use Shoe Goo to fix worn heels, but now I use glued rubber sheet, which lasts longer, is less messy, and dries more quickly.
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
+1 @79pmooney; take them to a cobbler. They can do it right. E.g.:
