Zipp hubs vs. Dt Swiss?
W.W.DZ.D?
I recently picked up a pair of race wheels- Zipp 360 tubular rims (used on 404's) laced to DT Swiss 240s hubs with Aerolite spokes.
I had heard some bad things about Zipp hubs (notably, durability issues), and the DT's were only 80 grams heavier for the set.
Will I notice an 80g difference in the hubs? Did I make the right choice by saving ~$200 and going with the DT's?
Here's a picture of my wheel-
Have bike. Will travel.
Bikes: '06 Orbea Orca, '03 Rocky Mountain Vertex 70, '05 Surly Steamroller, '06 Fetish Fixation
I doubt you will notice the 80g while riding, especially with the weight at the hubs and not the rim. DT makes fine hubs, and I too have heard some sketchy things about zipp hubs. You probably made a wise choice.
Bikes: 2007 Fuji Roubaix LTD, 2005 Bianchi Pista
Oh man, DT Swiss 240s hubs are spectacularly awesome. I LOVE mine. My LBS refers to them as "maybe the best hubs made today" (after I had bought a set elsewhere, not trying to sell me some).
Knowing's half the battle
Bikes: 2009 Cannondale CAAD9 BB30, SRAM Red, Fulcrum Racing 3s
I specifically built mine around DT Swiss hubs. Even Lightweight uses DT Swiss 240s hubs in one set of their wheels.
https://www.competitivecyclist.com/ro...366_FALSE.html
The Ventoux DT Tubular Wheelset - $4800
Good stuff!
Good stuff!
pan y agua
Quoted: 1447 Post(s)
Liked 728 Times
I doubt you will notice the 80g.
I've been riding Zipps on an everday basis since 2003. Only problem I've had with the hubs is that the finish on one of the front hubs started looking like crap from sweat hitting it. Haven't had that problem on the second set.
And haven't had any issues with the function of the hubs. YMMV.
-Mike
pan y agua
Liked 728 Times
And my point was in my experience, I haven't had abnormal wear. My 404's were bought in 04, and still have the original bearings, (although the rear hasn't seen much use since I started using a powertap)
The 303's that I used from 03-07, I replaced the rear bearings once, before the wheels were replaced under the crash replacement plan.
My current 303 tubulars are also doing fine, but have maybe 1,000 miles on them so I wouldn't expect an issue.
And as for designing the bearings to fail, I'm not sure that's accurate. They're designed where there's play in the bearing when they not loaded, and therefore feel sloppy when they're not weighted, but I don't think that necessarily causes excessive wear.
In fact Zipp claims it reduces wear:
https://www.zipp.com/portals/0/techno...Technology.pdf
Bravo Delta
Bikes: Felt F4C
I am riding a custom wheelset with DT 240s and so far they are awesome. The wheel builder swears that they are the best hubs money can buy. Everyone that I have talked to that has used them tends to agree.
Me Likey Bikey
I've put about 500 km on my DT Swiss 240's, they are the smoothest hubs I've ridden and no problems thus far.
Bikes: Surly Pacer, Hillbrick Pista, Avanti Sprint, Commencal Combi Deluxe
I love the DT 240s on my custom built wheels too, very smooth. The lbs owner who built them for me has the same hubs on his $5k custom frame too. I think you got an excellent deal. 80g is nothing you will notice.
Peloton Shelter Dog
Zipp hubs appear to be crappy. I've needed two rear bearings in about 2000 miles on my 404s.
In fact, I think the DT Aerolite spokes and 240s hubs would make [IMO] a better wheel combined with the Zipp rim. You got the best of all worlds. [That is unless the hubs were DT 190 ceramic hubs, but those are quite pricey.]
Über Member
Bikes: 2005 Trek 5000 (the last OCLV)
