USB Tail Light with Pulse (Not Blink) Mode and Wide Beam?
USB tail light with a mode where the light pulses gradually brighter and dimmer -- instead of blinking/flashing on-off?
With a wide beam?
Under $50.
With a wide beam?
Under $50.
Bikes: 2011 Felt Z85 (road/commuter), 2006 Marin Pine Mountain (utility/commuter E-bike), 1995 KHS Alite 1000 (gravel grinder)
Quoted: 676 Post(s)
Liked 13 Times
Light & Motion VIS 180 and 180 Micro do just that. The 180 Micro is $50 MSRP or about $41 from Amazon.
However the mounting system sucks. I just bought one today and did not like the rubber strap mounting instead of a bracket that lets you quickly take the light on and off. Also the USB port broke the first time I tried to plug it in. I'm taking it back for a refund tomorrow.
The quality of the light output itself if very good IMHO. It just that it has certain other issues associated with it.
Cateye TL 570 has a pulse setting amongst its set to choose from. It also has motion and light sensors - turns itself on when the bike is moving at night - turns itself off when still or in day. My kids' bikes have them because they often forget to turn lights on and off.
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
I've been using the Cygolite HotShot 2W USB for a few months. This thing gets plenty of respect from overtaking cars. I haven't seen a brighter tail light, and there are several modes to choose from.
$34.95 at our Cycling Center, as I recall.
Randomhead
Liked 3,699 Times
Radbot 1000 has a "throb" mode
Thanks for these suggestions.
The pulse of the L&M Vis Micro is still too rapid for me -- I want a "heartbeat" from medium bright to high:
https://www.youtube.com/watch?v=oAj1QAqrOEE
Also I see that they do have an optional rack-mount that the light can dock with, which I need. But it's $10... + $11 shipping. $21 and a hassle for the plastic mount that should come included.
https://www.lightandmotion.com/bike/vis180micro.html
click the "EXTRAS" link
The Cateye TL-LD570-R is very close to what I'm looking for. I definitely like that big "rear reflector" kind of design (I'll be mounting it on a rear rack), and it seems to have very wide visibility:
https://www.cateye.com/en/products/detail/TL-LD570-R/
But the pulse is still a bit too fast for me. Also it looks hideously jittery-while-pulsing here, though that might just be a video compression artifact:
https://www.youtube.com/watch?v=ycXfFdHnsDY
But the deal killer: it's not rechargeable.
The Cygolite HotShot 2W USB is the one I'm trying to find an alternative to.
It has a notoriously narrow/focused beam, and although the flash speed can be slowed down (not sure how far), I don't think it has a fading "pulse" option.
The Radbot 1000 has a mode that alternates a slow pulse with a flash cluster. Not rechargeable in any case.
Why does the universe, and its henchman the bike industry, make life a matter of tradeoffs with no actually good option?
The Hotshot does indeed have a mode that fades and is adjustable in speed. The beam pattern is narrow but can easily be widened by just putting a piece of scotch tape across the lens. Doing so though significantly lessens the intensity of the output.
Quoted: 659 Post(s)
Liked 7 Times
But I'd opt instead for the brighter HotShot as primary tail light and add one of these or something similar as a secondary and to provide a wider beam. Best to have at least two tail lights since you might not immediately notice if one fails for whatever reason while riding at night
Always two back lights - whatever you do. Batteries conk out completely quietly and sometimes with little warning.
fwiw I favour one of these attached to the back of my jersey as a second light. That way it follows me off the bike if I'm working on a flat or something. Also the magnetic switch is nice - it's always death of the switch that has killed off other lights I've owned and the little mag switch has soldiered on for ages.
https://www.yellowjersey.org/magswich.jpg
It's better than integrated rechargeable. Rechargeable batteries have a certain number of cycles in them - they're never a custom cell, so you could always get a replacement - but sometimes it's a very difficult job to remove the old one and replace it. Maybe you're an ace with a soldering iron in which case disregard.
Almost just gave in and bought Hotshot... but I'm NOT sticking tape on a shiny new fairly expensive high-tech device just to make it usable (for me). Did consider opening it up and buffing inside of lens with sandpaper. NOT.
Cateye rejected as I don't actually like its "pulse" -- but idea of (claiming I will eventually get) rechargeable batteries and charger, opens up general option of cheap blinkies.
This Serfas Stop Sign has a "rolling mode" that is pretty OK (see video), $15, AA batteries:
https://www.modernbike.com/itemgroup.asp?IGPK=2126175925
Oh... but there's a drawback. Is that possible? No QR rack mount available. But can screw it to rack (if holes match) and hope thieves don't bother.
This Planet Bike Rack Blinky 5 has a QR rack mount included, also $15, AAA batteries:
https://www.amazon.com/Planet-Bike-30...dp/B0015R1N76/
Guess what... no pulse mode.
And no, I'm not covering myself with a flock of blinkies and walking into places forgetting they're still strobing. Like Some People We Know.
'Kay so an Amazon review for the Serfas Stop Sign says it will fit on a "standard" rack tailight mount, which I hope this is ($5):
https://www.modernbike.com/itemgroup.asp?IGPK=2126174969
But now I see that a battery recharger costs $20.
So now I'm up to $40 for my "forget expensive USB taillights that don't actually have the features I want, and just get a cheap battery blinky". Which is the same price as the Hotshot (plus rack mount).
Which is 10x as bright, with an adjustable "pulse". Just not with a beam that can be seen if it's not aimed at your eyes... they say.
This is just getting easier and easier.
Thunder Whisperer
Bikes: '06 Kona Smoke
Quoted: 275 Post(s)
Liked 6 Times
Check out Serfas.com. Unlike PDW's product videos, Serfas has taken a video of each of their tail lights as seen by a car traveling at 55 mph as it approaches the bike from the rear. Don't think any of them have that particular 'pulse' pattern you're wanting, though.
One light I can think of that is visible from off axis as well as directly behind and has programmable flash patterns w/USB charging is basically 2x the budget- and that is if you can find one to be had. That light is the Nite Flux Red Zone 4.
Quoted: 659 Post(s)
Liked 7 Times
Not really. Here's one for less than $12 and includes both a couple AAA low self-discharge cells for your rear light and a couple bonus AA cells for whatever else you may have that takes that size cell:
https://www.amazon.com/Rayovac-Platin...dp/B003D7LHKY/
Stores like Target and WalMart also usually have decent prices on combo packs of chargers and AA/AAA cells. If you have anything else in your house that uses AA or AAA cells then it makes sense to switch over to rechargeable NiMH cells, so I wouldn't ascribe the cost of the charger to just your rear blinky.
Rocketship Underpants
Bikes: '94 RS Bikes Stampede (commuter), Scattante XRL Team road bike (formerly '05 Cannondale R5000), '05 Cannondale Prophet 1000
Have you considered the PDW DangerZone? I have one mounted on my helmet, and a PDW Red Planet on the rack. I turn the Red Planet to "steady" all the time, recharge the two AAA each weekend after about ten hours of use (it's still fine at that point, I can go two weeks or twenty hours on steady before it gets dimmer, just a habit I'm in though). The DangerZone has a mode that I think is what you're looking for, it flashes gradually, first the top LED, then the bottom, then both, repeat. The LEDs are not parallel, so if you mount it horizontally, I think you'd get a nice spread. Using this mode I can go two weeks easily (but still recharge every two weeks out of habit).
Edit: The DangerZone uses two AAAs, I know your original post says USB rechargeable, but later you were open to batteries, so.. yeh.
Randomhead
Liked 3,699 Times
I know I mistakenly posted a light that wasn't usb chargeable above, but there is something to be said for usb charging. I don't do it, but one of the guys in my lab has a whole array of lights charging off of his computer every day. I guess if you got in the habit of removing batteries and charging them up it would be similar. I keep intending on putting a thumbscrew on my PDW Radbot 1000, the screw is annoying
Quoted: 27 Post(s)
Quoted: 2338 Post(s)
Liked 2,827 Times
Out of curiosity....why the focus on the pulse bright to dim, repeat, feature?
This does not seem to be as noticable as a flash.....and that is the whole point of a rear blinky to be noticed.
Quoted: 676 Post(s)
Liked 13 Times
I think a good combo would be one light on a slow pulse, and another with a more staccato flash. People say a flashing light is harder to gauge distance to, and so you should run one steady and one flashing. But maybe that steady one could actually be pulsing between dim and bright.
Or maybe you should just run 3 lights.
Quoted: 659 Post(s)
Liked 7 Times
My view is that the function of my rear lights is to be noticed while the driver is still far away. That allows him to steer in a direction so he won't hit me and if he eventually gets close enough he'll be able to gauge the distance accurately based on seeing my various reflectors which will let him see the size of my bike and body.
Just a geek
Bikes: LHT, Pacer
Reading this thread made me remember to try out the scotch tape diffuser on my Hotshot. Covering the lower half of the lens with a piece of tape and leaving the upper portion original seems to work quite well for me.
FYI Use dime for a template to cut out a half circle of tape to apply. No air bubbles and it looks halfway professional.
I've tried the rechargeable AA/AAA route before for various things. After regularly burning the chargers up within a very short time (the just died, not actual fire) I gave up on them. Nothing but positive experiences with Li-ions so far.
Bikes: 2020 Masi Giramondo 700c; 2013 Lynskey Peloton; 1992 Giant Rincon; 1989 Dawes needs parts; 1985 Trek 660; 1985 Fuji Club; 1984 Schwinn Voyager; 1984 Miyata 612; 1977 Raleigh Competition GS
Quoted: 1126 Post(s)
Liked 253 Times
Serfas Shield is a great alternative, it's brighter then the Hotshot and has a wider beam. This chart will show you the superiority of the HotShot over others mentioned here: https://bicycles.blogoverflow.com/201...-light-review/
Here is small selection of beam shots: https://www.bikeforums.net/attachment...2&d=1335801807
Actually you could take any $50 headlight and buy some taillight repair reflective tape and cover the clear lens of the head light with it, and that "new" taillight will be brighter then almost all dedicated taillights till you get up around the $350 range! I did that with Cygolite ExpiliOn 350, ended up putting 3 layers of the tape on to get the red I wanted. That tape cost about $2 and can be found at any auto parts store.
In fact if you by chance have one of those to be seen taillights you could convert it to a taillight then instead of buying a new taillight spend that money for a better headlight.
I'm sorry, I'm thinking too much again.
I notice that cyclists feign ignorance that there could be anything offensive about using them... until the subject of pack riding comes up.
