Can't get enough setback - Are my femurs really as long as they seem to be?
Bikes: Bianchi Volpe, ANT 3-speed roadster, New Albion Privateer singlespeed, Raleigh One Way singlespeed, Raleigh Professional "retro roadie" rebuild, 198? Fuji(?) franken-5-speed, 1937 Raleigh Tourist, 1952 Raleigh Sports, 1966 Raleigh Sports step-through
Quoted: 248 Post(s)
Liked 27 Times
I always struggle to get my saddle back far enough. I'm about 5'6", so I'm mostly on smaller frames with steeper seat tube angles, and I like leather saddles. I recently picked up an old SR MTE-100 seatpost with adjustable setback, and put it on one of my bikes yesterday to play around with it. The bike is a 53cm Bianchi Sport SX. It has a 74° seat tube angle, and is currently equipped with a 165mm crankset. I usually use 170mm cranks, but this is a temporary build using parts from a scrapped bike to see if I like this frame enough to keep it and put some money into really building it up.
Anyway, while I was out test-riding it with the adjustable seatpost, I ran into a photographer friend and had him get a couple pictures of me on the bike. I'm slightly surprised that it took as much setback as it did to even get to what appears to be approximately KOPS position. Are my femurs really that disproportionately long?
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
And I thought I had trouble getting my Brookses back far enough!
Just shooting from the hip before the experts get here... your feet look like they're well back on the pedals. Are the balls of your feet over the pedal spindles?
What is your standover clearance? If you have room to move up to the 55cm frame, the seat tube angle would go to 73° and that would certainly help a little.
The whole KOPS thing is a decent starting point, but I wouldn't be afraid to let the knee end up ahead of the pedal spindle if it doesn't cause pain or get in the way of your riding otherwise.
Quoted: 248 Post(s)
Liked 27 Times
I tried to find pictures of myself on one of my more typically-set-up bikes, but there's nothing recent from the right kind of angle.
Surf Bum
Bikes: Lapierre Pulsium 500 FdJ, Ritchey breakaway cyclocross, vintage trek mtb.
Quoted: 13 Post(s)
Liked 5 Times
It’s hard to tell exactly in those photos but it sure looks to me like that’s way behind KOPS. I would expect much more of an angle at the ankle for the bump below the knee to be over the ball of your foot. You can always tape a piece of string to your knee with a weight on the bottom and let it fall so it passes to the inside of your foot and then sit on the bike leaning against the wall a bit (or heck, ride around carefully) and see where the string is when you have the cranks level. Is it really the pedal spindle or is it way back behind your arch even?
Of course it doesn’t really matter as long as you are comfortable and injury free.
Thirst is stronger than the rules. - Stars and Watercarriers, 1974
Quoted: 65 Post(s)
Hello,
Best of luck with your bike fit.
I had a friend who thought he had to set up a bike like that and it was pretty spectacular when the seat post broke. If an adjustment range is maxed out, it is never a good thing. I vote pass on it.
Quoted: 3450 Post(s)
Liked 420 Times
To my eye you look like you are already behind KOPS. A 74 degree seat tube angle is pretty steep anyway so I'm not surprised that you need a radical seatpost to get the saddle back far enough. I have a custom frame with a 70 degree seat tube angle which I had built to get the saddle back far enough.
What is the outright saddle setback measurement? Measure from the tip of the saddle to the line running vertical from the centre of the bottom bracket.
A saddle setback of 50-70mm is kind of normal. If its in that range then its just that a seat tube angle of 74 degrees is just too steep for you.
just another gosling
Quoted: 3890 Post(s)
Liked 1,939 Times
KOPS is just a first approximation. Basically, ignore it. Go by balance, i.e. the weight on your hands. If you feel like you have adequate weight on the front wheel, but not so much that it bothers your hands, you're fine. The fit you have looks good. Nice find on that seatpost.
Results matter
Results matter
Your femurs don't look that long, and a 3rd vote for 'you look like you're behind KOPS.'
Quoted: 248 Post(s)
Liked 27 Times
I took some time last night to play around with the saddle position, and something I was able to use as a makeshift plumb bob. Those suggesting I'm behind KOPS in the pictures above are correct - I found myself moving the saddle forward significantly. However, to be able to get to that point (recognizing that it's only a starting point), it does take me about 55-60mm of setback beyond a 74º STA to get me there, with the clamp on the center of the saddle rails.
Quoted: 514 Post(s)
Liked 450 Times
My opinion is that setback is more about placing the hips where you feel balanced over your feet. If your center of gravity falls forward of your feet, you will have to support the upper body with your arms to keep your chin off the handlebar. If your're too far back, you sacrifice power and the bike handles funny.
Quoted: 51 Post(s)
Liked 6 Times
Quoted: 41 Post(s)
Liked 11 Times
Hey, know if I can get a seatpost like that anywhere?!?! With an inseam of 92cm/36+in., I need the saddle pretty far rearward. And I'm always messing around with my fit . . . that quick-release on the clamp would make things sooooo much easier for me!
Keep calm, Cycle on
Bikes: Pinarello F8, Bianchi ∞, Colnago SS, Niner MTB
Quoted: 117 Post(s)
Another vote for you look like you're riding behind your KOPS.
Instead, move your seat Forward and Higher.
I'm guessing this is why fit starts with a provisional saddle height. Then KOPS for a provisional fore/aft. Then balance to refine fore/aft, dropping the height as the saddle is pushed aft.
Quoted: 6196 Post(s)
Liked 4,811 Times
I'd worry about that seatpost breaking from the load moment being so far back. I suppose it was designed with that in mind. But I hate to think what will be ripped off my body if it fails.
I too think you look too far back. Frame looks tiny.
Keep calm, Cycle on
Quoted: 117 Post(s)
Edit: you have a quill stem and these are hard to find longer stems for... but they are out there.
Bikes: Fitz randonneuse, Trek Superfly/AL, Tsunami SS, Bacchetta, HPV Speed Machine, Rans Screamer
Quoted: 100 Post(s)
The 74 degree seat angle would amount to about .5” less offset compared to a more common 73 degree.
The shorter crank about .2”. So that is an extra 18mm of seatpost offset required. If a common 25mm offset post is already needed, that makes for a lot of offset.
I have 37” inseam and recently switched to a 200mm crank. Besides a huge improvement in comfort, power and endurance, it also shifted my seat forward. 20mm on one bike that had 180mm cranks, and 25mm on one with 175. I have always used 73 degree seat tubes, offset seatpost, and slammed the saddle rearward. Now they are mid rail and forward.
Quoted: 248 Post(s)
Liked 27 Times
The reason you need so much setback is because your bars are too high. Slam the stem. Lower bars will redistribute weight more evenly between the front and back, the bike will handle much better, and you'll be more comfortable. The pain in your shoulders and neck is caused by the strain and compression of having the handlebar WAAAAY too high. You're compensating for that with saddle setback but that isn't the best response to it. That will only makes things worse elsewhere, for example creating numbness in your hands. Instead you try to put your bars as low as possible, perhaps even trying deep drop bars or vintage classical bars that drop sharply at an angle from the stem like track bars. You could also try a Nitto Jaguar stem to achieve more drop. I know you won't believe a word I said because bike fit is counter-intuitive and almost everyone initially has a fervent belief that high bars will make them more comfortable but the opposite is usually true. Some people never achieve a comfortable fit because they don't go low enough. Grant Peterson is delusional about this fit issue. Every professional successful racing cyclist in the world counters his claims by example. One way to force yourself into a better riding posture is by using clip-in pedals and installing the cleats all the way back. That will force you to sit forward on the saddle and you'll naturally desire lower bars. Experiment with a radical bar drop posture. It's also possible that your handlebar reach is too great. Those vintage handlebars sometimes have enormous reach like 120mm, and if they're too far away there's a tendency to compensate by moving the saddle backwards for balance, like a triangle. You can decrease the handlebar reach by pivoting the bar forward until the lowers are parallel to the ground and installing the brakes lower. Those vintage bars don't really lend themselves to the modern compact-bar setup of flat ramps prior to the hoods. I've noticed you can buy compact bars now that fit vintage stems though. I think Uno makes some.
Liked 420 Times
Handlebar height has NOTHING to do with KOPS, of positioning your legs properly.
Nowadays its a fashion to have the handlebars low compared to the saddle yet years ago elite cyclists won the TDF with handlebars kind of level with the seat. There's nothing that unusual with the handlebar height on his bike.
What's out of whack is the 74 degree seat tube angle which is WAY too steep for small bikes. I've RANTED about this before so I won't do it again here suffice to say the 74 degree seat tube angle is more about putting a short top tube length on a spec sheet than it is about positioning the legs properly.
Keep calm, Cycle on
Quoted: 117 Post(s)
It was an add on to my former post.
If you move your seat forward by 2-3 inches and up by 1-2 inches, you bike will have less reach and it may feel short.
This could be why you keep searching for more and more room off the rear of the bike rather than the front.
Quoted: 248 Post(s)
Liked 27 Times
Again, it's not a reach issue. If I can't get the saddle back far enough, I have too much weight on my hands, and the bike is only "comfortable" if I'm riding HARD...but guess what? I'm not a racer and have no aspirations to be one, so that's not how I prefer to ride.
Quoted: 248 Post(s)
Liked 27 Times
Have I mentioned, by the way, that this bike is an experiment? I have multiple drop bar bikes, and I have this problem on all of them. I've been able to work out, multiple times with multiple bikes, that to get the saddle clamp in the center of the rails of a typical leather saddle with a standard seatpost and have myself feeling reasonably well balanced in terms of weight distribution, I need something like a 71º seat tube angle.
Liked 2,568 Times
Also, LOL @ the "slam your stem" advice above. Umm, right.
Quoted: 18378 Post(s)
Liked 4,512 Times
Larger frames often have an slacker seat tube angle, so that is always a possibility. You don't have to have a lot of clearance.
That is a pretty short stem. If you think reach is a problem, then you could try a longer stem. 110mm or 120mm?
How much weight are you putting on your hands? Perhaps try gripping the bars in other positions like leaning forward, gripping the tops of the levers, and letting your forearms rest on the handlebars.
