Go Back  Bike Forums > Bike Forums > Fitting Your Bike
Can't get enough setback - Are my femurs really as long as they seem to be?
Fitting Your Bike Are you confused about how you should fit a bike to your particular body dimensions? Have you been reading, found the terms Merxx or French Fit, and don’t know what you need? Every style of riding is different- in how you fit the bike to you, and the sizing of the bike itself. It’s more than just measuring your height, reach and inseam. With the help of Bike Fitting, you’ll be able to find the right fit for your frame size, style of riding, and your particular dimensions. Here ya’ go…..the location for everything fit related.
Old 10-20-17, 12:29 AM
  #51
woodcraft
woodcraft's Avatar
Quoted: 1814 Post(s)
Liked 923 Times in 569 Posts
Originally Posted by AnthonyG
For the record, ANY bike with a 74 degree seat tube angle has the seat pushed too far forwards and ANY rider will need a rearset seatpost to get a proper position. The OP is not a freak.
If you guys have pictures of someone who IS a FREAK and fits on a bike with a 74 degree seat tube angle, that ISN'T a TT bike, then I would like to see it.
74-75 degree seat tube angles should be for TT bikes ONLY.
I ride a Tarmac with a 74˚ seat tube angle, a 20mm setback seatpost and 85mm saddle setback- not exactly freakish.
Also looked at dozens of pics of OP's bike online & didn't see anything out of the ordinary.
You might be OVERSTATING things a bit.
woodcraft is offline
Old 10-20-17, 02:00 AM
  #52
AnthonyG
AnthonyG's Avatar
Quoted: 3450 Post(s)
Liked 420 Times in 289 Posts
85mm of saddle setback at 74 degrees!!!!!!
Really? Do you have pictures?
Your saddle must be REALLY high and its usual for really BIG frames to have more relaxed seat tube angles.
Are you riding a small frame with a REALLY long seatpost?
EDIT: OK, where are you measuring the saddle setback from? I'm talking about measuring it from the tip of the saddle. Where are you measuring from?
AnthonyG is offline
Old 10-20-17, 09:45 AM
  #53
woodcraft
woodcraft's Avatar
Here is the bike, 56cm, 73cm saddle height, saddle setback from BB to saddle tip.
Pretty NORMAL set up, IMO.
File Type: jpg
Old 10-20-17, 03:53 PM
  #54
AnthonyG
AnthonyG's Avatar
OK, I had a quick look for specifications. From what I can find that model has a 73.5 degree seat tube angle, its a large frame and you have a LOT of seatpost exposed, so yes, you could get that much saddle setback to the nose.
What I'm saying though is to get anything like that much saddle setback at say 2/3 the inseam length would require a more relaxed seat tube angle and at 1/2 the inseam length you would need a MUCH more relaxed seat tube angle.
That's just how the geometry works out. Your example doesn't really compare to the OPs example.
AnthonyG is offline
Old 10-20-17, 07:32 PM
  #55
woodcraft
woodcraft's Avatar
The OP claims 31" or 32" inseam. I have 32" inseam. I took the angle from specs for this years Tarmac.
My GF's 49cm Roubaix appears to have a 74˚ seat tube angle. She's about 5'1". Not sure of setback.
Are you seriously making an argument for the saddle setback of someone with 16" legs?
Old 10-20-17, 08:03 PM
  #56
CliffordK
CliffordK's Avatar
Quoted: 18378 Post(s)
Liked 4,512 Times in 3,354 Posts
Are the Brooks rails really that short?
Drawing an imaginary line up the seatpost through the seat on the OP's bike, and looking at woodcraft's bike, both would hit more or less in the middle of the seat.
So, perhaps part of the issue is that the OP's saddle has a lack of adjustment.
CliffordK is offline
Old 10-20-17, 08:42 PM
  #57
AnthonyG
AnthonyG's Avatar
OK, hard numbers would be good. The OP has a 53cm frame with a short amount of seatpost exposed. Woodcraft has a 56cm frame with a LOT of seatpost exposed.
I know its a traditional frame vs a compact frame but still I find it hard to believe that the OP and Woodcraft have the same inseam.
My inseam is approx. 24" A child's inseam could be 16" although yes it is a little short.
It would be interesting to check your girlfriends saddle setback. I'm guessing 20mm or thereabouts at best. It may even be zero.
AnthonyG is offline
Old 10-21-17, 11:34 AM
  #58
woodcraft
woodcraft's Avatar
OK, well played.
I think I found a pic of you on your bike.
File Type: jpg
Old 10-21-17, 12:20 PM
  #59
Iride01
Iride01's Avatar
Quoted: 6196 Post(s)
Liked 4,811 Times in 3,319 Posts
I guess the big question to the OP....
Was moving the seat back just to stay in KOP's? Or was he experiencing discomfort or pain when the seat was in a more normal position.
I'm not a big KOP's supporter. It's just a reference that works for some.
As for the discussion of seat tube angles, there is only about one cm of movement per degree of change from 74 to less on a seat that sets 60 cm from the crank center.
Iride01 is offline
Old 10-21-17, 04:22 PM
  #60
AnthonyG
AnthonyG's Avatar
OK, well played.
Don't laugh. I DO ride bikes that size (24" wheels). A bit more seatpost exposed than that but basically that size. I own a completely custom Road bike built around 650c wheels and a 70 degree seat tube angle.
AnthonyG is offline
Old 10-23-17, 11:57 AM
  #61
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Originally Posted by agmetal
Just to reiterate: I'm not a racer, and I'm not looking for a racing bike. Short chainstays are overrated.
the first Stumpjumpers* took frame design of the repack cruiser bombers and got someone in japan to produce them in the many hundreds
First hand made, but Tom Richey had to go overseas to get the numbers up too..
I found on gravel roads they climbed poorly, But now I have Bodged together one, from a Frame
found with a broken dropout and for street use its fine..
seat tube is a 68 I think.. maybe 70.
fietsbob is offline
Old 10-23-17, 12:17 PM
  #62
fietsbob
Bikes: 8
Rare and auctioning at top dollar Brooks Team Pro had a 20mm rail spacing, 100mm long version..
Campagnolo made a variation of their seat post to suit that narrower rail track
more common and typical is 36mm wide, 60 long..
Ref <C>catalog 16
fietsbob is offline
1949 Raleigh
Fitting Your Bike
4
06-17-17 02:12 PM
prasaanth07
Fitting Your Bike
2
02-09-16 06:29 PM
RandomExeter
General Cycling Discussion
4
08-31-10 11:06 AM
hannahmontana
11
03-10-10 06:35 AM
