Foot pain, platforms
Bikes: Trident Spike 2 recumbent trike w/ e-assist
Quoted: 1321 Post(s)
Liked 374 Times
I broke a bone in my foot a long time ago, on the outer edge. My bike fits me great and i love riding it, but lately I have noticed pain in the spot where the break occurred. I'm thinking I am pushing down and it is irritating the break point. Of course, then I try to ride with my foot angled a bit in to put less pressure there....and that's a bad idea. I ride in city traffic all the time so don't want to go to clipless (just not for me) but I wondering if there are maybe some insoles folks have used to reorient the foot position away from tender spots (I currently use SOL insoles) or have other solutions? TIA
Bikes: Road, mountain and track bikes and tandems.
Quoted: 282 Post(s)
Liked 18 Times
I bought some 99c store flip-flop, cut them down to fit in my shoes. I had to grind down the toe box area, so there is enough room for my toes, and I relieved the "pressure" area(s). There is nothing that comes close (in terms of comfort/ softness)
Liked 374 Times
I'm using Velo Orange touring pedals. I used to have Rivendell Grip Kings but I had a different issue with those (put my knees to far from the frame). The Q factor on the VO's works well for me. Wonder if they make inserts with cutouts. It doesn't bother me if I get my foot angled so the outside is on the raised pin, which raises my foot just enough to take the pressure off, but that's not the right position for my knee. I do it briefly sometimes to ease it, but it definitely feels wrong to pedal like that. Maybe there's something I can put on the pedal in the right place to raise it just a tiny bit on one side?
Quoted: 207 Post(s)
Liked 108 Times
What about their Sabot pedals combined with soft soled shoes? The pins hold soft soles in place very well, and then you have a large flat area to spread out the pressure. I would suspect that combo would be very hard to beat for foot comfort.
Liked 374 Times
I tend to put more pressure on the outside edge of my feet (I supinate when I walk, too). On the foot with no prior break, it's no problem. But it's just too much pressure on the old fracture - so I think I need to "correct" that supination on the one side somehow. But I don't want to do something that will mess with walking as I bike/walk for transport and daily usage. So I'm more interested in doing something to the pedal I think, if that's possible, so when I get off the bike the "solution" doesn't mess with me walking and create new problems.
Quoted: 1034 Post(s)
Liked 1,292 Times
Use a larger platform pedal. Wellgo makes some good ones. Here is an example: https://www.amazon.com/dp/B01IM2K2V4...ing=UTF8&psc=1
I know you say you like a narrower Q factor, but it sounds like a pedal extender might get the pedal under your foot. I think it will be diffiucult to find a wider pedal the the VO Touring pedal, but perhaps a long, wide pedal would solve your problem, if you hate the idea of an extender.
Also, could you have developed a 'tailor's bunyon'?
Liked 374 Times
just another gosling
Quoted: 3890 Post(s)
Liked 1,939 Times
One of the points of using clipless is that you don't push down as much, if at all. I used to commute in the city with clips and straps. Clipless would have been so much better, but the clips did help me keep up with traffic.
Results matter
Results matter
Liked 374 Times
I know a lot of people like clipless. I just don't want to invest in new shoes/pedals and then there's the fact that I do stop at every stop sign/light (unlike most of the clipless people I see). I rode with power grips for a while but even those got annoying for me. I saw some magnetic clipless on kickstarter which looked interesting but they are way expensive right now. The pushing down wouldn't be a problem if I didn't roll to the edge of my foot on the one side.
Liked 1,939 Times
That said, you want to get instinctive with clipping/unclipping before riding in traffic. A few residential solo rides should do it. Start in a parking lot, get comfortable. Practice panic stops, stopping while turning, that sort of thing. I always put my right foot down, the one away from traffic. Always using the same foot helps with the perfect reaction every time, I think. Set the pedals to minimum tension at first - you can just rip your foot out if you have a brain fade.
Results matter
Results matter
Quoted: 82 Post(s)
It's more likely a position and general fit issue. Your saddle might be too far forward to compensate for excessive reach. That would put extra pressure on your forefoot. You might need to move the saddle back and buy a shorter stem. If the foot breakage area continues to be a problem try SPD mtb pedals and dedicated cycling shoes with a rigid out-sole.
Liked 374 Times
Liked 1,939 Times
I had a professional bike fit on this bike and I'm pretty sure it's right on. For the first time in my life on a bike, I don't hurt anywhere.....except in this one place. And the problem only started recently and I've been riding this bike with the same fit since last year. It might go away, it's bothered me in the past (not cycling). From what I remember of the xrays and explanation, it's right on the very outside edge so I feel it when I go hiking, for example, if I step on a rock midfoot. It's not too much pressure on the forefoot in general, it's that I supinate and rotate at the ankle toward the outside. I do it when walking as well, but my insole manages to cushion sufficiently. I'm thinking now it's something I can train myself not to do if I really concentrate on how I pedal on that side; like it's a bad habit since I don't roll that much on the other side. Ideally *I need something temporary that will make me keep my foot-to-ankle straight instead of caved in.*
Results matter
Results matter
Liked 374 Times
Yeah....last resort. I want to try other options first because I don't want to have to wear specific biking shoes or go to the expense of replacing my pedals. Not to mention falling over, lol. I've also got knee issues so going clipless could be a long process of adjustment. But - if nothing else works, it's not off the table....just at the very end.
Liked 374 Times
Lol, no I got that part. I'm guessing you meant pedaling in a circle? It's a bit hard to do if you aren't clipped in, although I do try to do that. the issue is that I still put the weight (however much there is from circling or pumping) on the outer edge. A friend is going to loan me his half toe clips - it might be enough to keep me from lifting the inside of my foot and shifting to the outside.
Quoted: 82 Post(s)
