Why is braking so much better on a new rim?
Quoted: 128 Post(s)
Liked 12 Times
I just replaced my 12-year-old front wheel with Sun M13II rim, with a newly-built wheel with H+Son TB14 rim, because I wanted a wider rim.
It's striking how much the braking is strengthened by the new rim. I wouldn't expect such a difference. Same brakes and pads. Only factors I can think of:
- machined braking surface of the TB14
- different aluminum alloy and coefficient of friction with the pads
- old rim surface may have gunk on it (but I'd cleaned it with acetone and scoured it recently)
- angle of contact might be slightly better on the wider rim, although with a single-pivot sidepull brake I don't think the angle would be meaningfully changed
Quoted: 11 Post(s)
I guess with use the brake surface get's polished so the friction coefficient gets lower. When trial cyclist used rim brakes, they sandpapered it.
Maybe your new wheel's rim is more rigid so less braking force is lost by flexion when the brakes press it
Quoted: 128 Post(s)
Liked 12 Times
I highly doubt that either double-walled rim is flexing inward enough under braking force be create a noticeable difference. Maybe this happens with some single-wall rims, but I suspect that mechanism is rare in recent decades.
Actually my Mavic SSC, CD treated rim (A Hard Anodizing) braked better
once I Scoured the anodized surface off and exposed the base aluminum
[EX 721, 559 size FWIW]
Quoted: 128 Post(s)
Liked 12 Times
So I'm comparing bare aluminum to bare grooved aluminum and wondering what is so different.
groove? if only 1, when it's gone replace the rim,
you wore it down to the level of wear indicator..
Quoted: 128 Post(s)
Liked 12 Times
Turns out there's more gunk on the old narrower rim than I'd expected - I cleaned it off with an acetone rag tonight, and I got plenty of aluminum/rubber dust, the residue of braking.
Plus the narrower brake pads, which had worn in for a wider rim, didn't have much contact area on the narrower rim
So maybe there's no real difference here after all.
Bikes: 2 many
Quoted: 1266 Post(s)
Liked 323 Times
The wider rim makes the brake pads hit sooner when you put on the brakes. This changes the point in the brake lever travel. This means you probably get more power with your hands in that position. In other words the pads hit the rim when the lever is father away from the handlebars. This gives you more to squeeze against.
Quoted: 128 Post(s)
Liked 12 Times
