Front wheel touching pedal
Hi,
newbie here.
i just purchased a used fixie and noticed that when I turn my front wheel you around 45 degrees, the wheel touches my left pedal.
i know a little of toe overlap but not sure if it’s supposed to be this over. It gets quite difficult when I try turning. I either skid my shoes or completely stop and get caught in the pedal.
It happens more frequent when I’m going slow since I have to turn the wheels but happens occasionally when going in moderate speeds.
my tire is 700x28cc. I would post photos but won’t let me..
do I need to change tire size?
change forks?
or just deal with it since it’s normal?
Any advice would help.
thanks in advance!
newbie here.
change forks?
thanks in advance!
Tortoise Wins by a Hare!
Quoted: 1549 Post(s)
Liked 942 Times
Toe overlap is just that... only your toe touches. If the pedal is hitting the tire, that's NOT normal, even on a bike with toe overlap.
Likes For TejanoTrackie:
Likes For Magicpaul:
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1337 Post(s)
Liked 765 Times
The fork rake should face forward, such that the wheel axle should be in front of a line parallel to the fork steerer tube and frame head tube. If it's backwards, remove the front wheel, loosen the stem bolts that clamp it to the fork steerer tube and rotate the fork 180 degrees. If it has a front brake, you will also need to remove and remount it.
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
Fork
Red line through axle should be in front of yellow line through headset.
Barry
Barry
Likes For Scrodzilla:
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
No point in pretty if it's all going to change.
Barry
Quoted: 4806 Post(s)
Liked 3,932 Times
Edit: And I am a huge fan of riding new setups bare to make the brake and handlebar setup easy. I even go a step further, First bar tape is cloth wrapped from the bottom so I can unwrap it halfway, tweak brake position and re-wrap,even several times.
bill nyecycles
Quoted: 789 Post(s)
Liked 350 Times
Hi,
newbie here.
change forks?
thanks in advance!
newbie here.
change forks?
thanks in advance!
My Surly Cross Check had toe overlap. It annoyed the hell out of me when I made tight turns during my commute - this was on paths as well as navigating traffic and waiting at lights, etc. That was a 2016 model. THe 1999 Cannondale I just rebuilt and sold also had bad toe overlap - its the reason I sold it. Couldn't deal with it.
but my 2 vintage Raleighs don't have any overlap, nor did my carbon fiber Specialized Roubaix.
If you can deal with it and be mindful of it, then you're fine. If you can't, as far as I know there is little you can do about it because the angle of the headtube and fork is static. I think going down to a 650b wheel size might help, but not always, and only if your frame can accommodate them.
Quoted: 99 Post(s)
Liked 115 Times
A little bit of toe overlap is easily ridden around. At high speed, you steer with only small movements of the bars. At low speed, you turn the bars further but can time it with the pedal stroke.
If the actual pedals are overlapping the wheel, that sounds like a fault. I came across something like this once where a bike had run into a stationary vehicle at high speed. The forks looked OK at first glance but were pushed back.
Liked 3,932 Times
A thought - fix gear. Is there a front brake? If not - the stem could have been taken off and it or a new one installed backwards. Now the fork is backwards, Front wheel is now about 4 inches further back than it should be (and also quite close to the down tube). The fork will also funk Barry2's test.
There are people who ride with no front brake and straight handlebars so the can pull wheelies and then spin the handlebars, fork and wheel in circles. Then land either fork forward or backwards.
Ben
Ben
Petal overlap
Hi,
newbie here.
change forks?
thanks in advance!
newbie here.
change forks?
thanks in advance!
I have the same issue with slow, tight turns on my track frame. You will get used to it and be mindful to position the pedals at 6/12 for these turns.
Wait a minute, is the petal or your foot striking the wheel? If it's the petal, then that's an issue. If that's the case, I do wonder if someone changed the fork and it's not compatible with your frame. Can't imagine a manufacturer designing a bike like that.
What bike do you have?
Perhaps crank arms too long?
