Moisture's Unique Frame Fit
#51
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
Well, that should be good for another couple of pages
Genesis 49:16-17
Genesis 49:16-17
Likes For Darth Lefty:
#52
I am potato.
Quoted: 1790 Post(s)
Liked 1,631 Times
What you say is all good IMO except for the embolded section. One moves one's saddle to get correct balance, though even this assumes that one's upper body is somewhere near its final position. One takes their weight off their hands by moving their saddle, not their bars. One should be able to briefly take both hands off the bars, while pedaling normally, without sliding forward on the saddle. After one has that balance, one worries about reach. If one's position is way out of whack, there might be some back and forth adjusting to do, first one thing, then the other, then back to the first thing, etc.
#53
just another gosling
Quoted: 3890 Post(s)
Liked 1,939 Times
Moisture, as mentioned above, you obviously did not take your measurements correctly and got a screwy result. One can't do that alone, one needs a helper to measure and one muse follow the directions precisely to get a correct result.
Be that as it may, there's a much more direct route to look at correct bike sizing and that's to measure with your body. I set saddle height by measuring with my leg, the "heel on pedal" method. I determine correct reach by measuring with my torso and arms. I was talking about your top tube seeming much too short just eyeballing it. We could take another look at that fairly simply:
1) Take a photo of yourself leaning forward with your elbows on your handlebars.
2) See if you can lean forward far enough that your back is almost level. You'll probably wind up resting your chest on your bars. Hang your upper arms so that those upper arms are at about a 90° angle to your torso. Then bend your elbows so that your forearms are horizontal. Take a photo of that position. It may take a few tries to get that position just so.
3) Post the photos.
Thanks.
3) Post the photos.
Thanks.
Results matter
Results matter
#54
Liked 1,939 Times
#55
I can safely assume that you're the only person in this thread who modifies and rides a 'racing bike' to become some kind of 'shopping' bike or town bike while I also make the assumption that everyone else on this thread including me has a position more akin to the person you're calling mr. arched banana back.
Yet you've said that you can only ride for an hour and half before you get a sore butt (not that that surprises me at all as you clearly have far too much weight on it) whereas I, and no doubt all those who adopt the same position as mr. arched banana back can ride 6, 7 or 8 hours in a day without any butt soreness at all.
I don't think we've got much chance of 'seeing' your set up in action but maybe you can publish some garmin stats or show us some strava screenshots and we can see the phenomenal power you're able to produce with this 'optimal' position....
Likes For aniki:
#57
I am potato.
Liked 1,631 Times
Just edited to add "individual proportions" to above post.
I have long monkey arms for example. At 6 foot tall and a 31.5 inseam, I am all torso & arms. All my bikes are 58's The proper saddle placement for balance for you, on your bike would obliterate my wrists & shoulders/neck in short order.
In isolation, moving the saddle back, or moving the bars away effect the same result: Less weight bourne on the hands/wrists/shoulders/neck muscles.
Here is my nearest equivalent fit to the OP that I owned & built before I donated it to a local bike co-op charity for auction. I used to ride it on the Lake Washington loop & do 30 mile trips to Ballard for craft beer inspection & testing.
20190330_180742 by Richard Mozzarella, on Flickr
You'll notice how far the bars are away, in comparison to how much the OP's arms are holding up his torso in the photo he provides in post number 1. One of us will be way more comfortable on much longer rides.
#59
Quoted: 6972 Post(s)
Liked 10,970 Times
#60
Drip, Drip.
Bikes: Trek Verve E bike, Felt Doctrine 4 XC, Opus Horizon Apex 1
Quoted: 1034 Post(s)
Liked 193 Times
Quite frankly it's very difficult not to make fun of your fit when by inference, you're making fun of everyone else's.
With the exception of cube wheels, I haven't made fun of one single persons fit on this forum. Even in his case, I was being very constructive and understanding that his choices are limited and he is making due based on what he has and his proportions, respectively.
From a postural perspective, an arched lower back is terrifyingly bad news. Unfortunately it would be wise to compromise your racy leaning forward position somewhat so you can keep your back in a more or less natural posture.
I am not here to argue whether such a leaning position is or isn't effective. I am certainly not here to judge other people's fit or criticize them directly because their opinion does not directly coincide with my own ideas. Shame on you for not doing the same.
When you ride your bike, assuming your stabilizer muscles are all engaged properly and keeping everything tight, you should feel like you are bang on centre. You should be able to easily weigh your front OR rear axle effortlessly, at any given moment of your ride, without ever feeling like there is too much weight positioned back or forth.
If you can measure your knee bend angle from straight at the 6 or 5 o'clock position, it should be within 25 and 35 degrees at your preferred feet position on the pedals and your preferred toes down or up angle. YOu can take picture of yourself on bike and measure the angle on the picture.
Mine is 30 degrees in toe up feet (heel dropped) position. 30 degree knee bend is very common setting. But how it affects your pedaling efficiency is the final verdict. Bouncing at high cadence (~100rpm) is definitely not good.
According to the heel to pedal method of measuring leg extension, I am bang on perfect. (note, my inseam is about 34.8 inches and I ride with 175mm cranks) . I digress.
Try a frame your size.
Therefore, your body is not balanced or positioned identically in either circumstance;
Not the same thing .
#62
Liked 10,970 Times
#64
I am potato.
Liked 1,631 Times
Again, its not exactly the same thing. Moving your saddle back will bias more weight towards the rear of the bike. Moving the bars away from you will bias more weight toward the front of the bike.
Hey Base2, Base2 here. Look, I know you wanna help an' all...& you know a thing or two about a thing or two, but this guy doesn't want your help & he isn't interested in listening. You see Base2, he doesn't share a common reality or have the experience with which to share a common understanding of what the words mean that you are using.
Just leave him alone, my friend. Just let it be. He'll come to understand in his own time.
Peace be with you, brother.
Base2
Car dependency is a tax.
#65
n00b
Bikes: Surly Karate Monkey, Twin Six Standard Rando
Quoted: 428 Post(s)
Liked 466 Times
everything about your fit is stupid. I tried to help, but I don't have time for sheer willful ignorance. I will continue to contradict all the ignorant crap you post on this forum whenever appropriate, lest you lead other riders astray and end up hurting themselves. your "advice" is just plain irresponsible.
Likes For mack_turtle:
#66
Quoted: 2487 Post(s)
Liked 2,956 Times
Threads such as this one remind me of the 1960s folk and pop singer Donovan boasting in an interview that he had mastered the sitar in 6 months. Ravi Shankar, told of Donovan's statement, said "I've studied the sitar for 35 years, and I have yet to master it."
#68
Seat height is correct. Leg's too short. ETT and stem extension are correct. Upper body and arms are too long.
I don't mean to be nasty. My own way of handling a weak core is to avoid exercise and accept the pain of too much weight on my hands, arms, and associated joints. But my seat height is correct - no knee pain riding, but I get knee pain while walking and dancing. (I avoid running, too, whenever possible.) No back or butt pain, either, while on the bike, because the bike's length is about right, and my butt takes only part of my weight.
Moisture, You need to run some more experiments and check out more variables. You closed your mind prematurely, sort of like Donovan did.
#69
Drip, Drip.
Liked 193 Times
I'm going to begin gradually lowering my stem height in small increments as I get used to using my core more. So far, I'm definetly noticing an improvement due to extra mindfulness as well as increased core training.
My inseam is almost 35 inches. I actually thought it was my torso that was proportionally short. I do know that my arms are pretty long though. I think that these factors are the main reason why I wanted such a weird fit (flat bars on a drop bar bike)
Id be very eager to play around with some different road bikes and find a different riding position for reference. I am defintly keeping my options open here. I have been searching the classifieds nearly every single day for a 60-62cm or so frame to play around with i obviously want a more leaning forward position, but so far I haven't managed to make that possible in a way which works well for me.
As for poor core strength, like i was saying, its more a combination of nearly every muscle in your entire body which plays an important role. There's always something you can do about that. They say that even the wisest and most accomplished is never accepting of their achievements. It's always a work in progress. Why should you accept anything less when you can do more?
#70
Drip, Drip.
Liked 193 Times
its hard to get a picture on my own using just a 10 sexond timer lol. I will get around to doing so today.
Totally agree. But my proportions make it difficult to comfortably achieve what you consider "aggressive"
I've experimented enough with different stem lengths and heights to get a good understanding of what works for me. You told me that the only way to learn from this point onwards is by trying new frames. I 100% agree with you. I don't have ready access to that.
I think that by the point you're just being inconsiderate. I mean, what sort of advice have I ever offered, (which didn't come from you, or someone else on here directly) that you don't agree with? By all means,.show me even one valid example.
All I see on here is a couple of trolls mixed in with the rest of the friendly commenters on here. But at least everyone has made themselves useful and taught me a thing or two about bikes.
Youre delusional, and horrifyingly hypocritical.
Worse is he thinks everything that doesn't look like his riding posture is stupid despite hard proofs contradicting him on the matter.
What he need is professional help (not professional fitting). I've seen such behavior a lot among narcissists, they only care about what they think is right or what they think is the truth even if it contradicts reality or other people's experiences.
#71
As long as your seat height is as far wrong as it is, you cannot know what works for you. My bet is that your hips rock all through your pedaling motion. That is bad for your muscles. It's bad for your most tender skin.
You don't need a different bike to check out stem lengths. All you need is a longer stem and perhaps a Technomic stem to get the height you'll want.. That will force you to bend to each the 'bars, and I hope you bend at your hips, and keep your arms bent at the elbow. .Start with you 'bars as close to level with your saddle as possible. Make your 'bars go forward of the stem so you have to stretch a bit.
You'll solve your butt soreness by taking weight off your butt. You'll open your chest and probably be able breathe better. Your arms will hurt at first, but you'll probably develop core strength, and they'll stop hurting. (I say that because I'm overweight, and my upper body is weak, but my core gets strong enough by the end of the season if I focus on decent form.) You'll find riding easier and more enjoyable.
Some time conventional wisdom is conventional because it works well. Try it - it may work for you.
#72
https://www.bikeforums.net/fitting-y...ll-fit-me.html
https://www.bikeforums.net/fitting-y...ke-sizing.html
https://www.bikeforums.net/fitting-y...oportions.html
https://www.bikeforums.net/fitting-y...g-cramped.html
#74
n00b
Quoted: 428 Post(s)
Liked 466 Times
https://www.bikeforums.net/21905453-post34.html
https://www.bikeforums.net/21903224-post26.html
diet advice nonsense, contradicting an author's dietician https://www.bikeforums.net/21905175-post15.html
more bike fit/ physio gobbledygook https://www.bikeforums.net/21905453-post34.html
unqualified nonsense https://www.bikeforums.net/21903214-post11.html
Dr. Moisture telling people to scald themselves in the shower https://www.bikeforums.net/21902661-post12.html
where did you go to medical school?
The Cannondale Badboy was designed for a flat bar. someone should remind Cannondale! https://www.bikeforums.net/21902647-post7.html
so vague https://www.bikeforums.net/21901837-post48.html
someone told you that your saddle is too low, and you agreed. then in this thread, you say it's fine and setting up a camera to get a second opinion is too hard. https://www.bikeforums.net/21901170-post5.html
#75
Space Ghost
Bikes: Bridgestone, Fuji, Iro, Jamis, Gary Fisher, GT, Scott, Specialized and more
Quoted: 292 Post(s)
Liked 412 Times
Boy, at first I thought he was just an overly enthusiastic newbie with a buncha goofy ideas but now I’m not so sure hahaha!
Likes For Rage:
