Ensuring Power Meter Accuracy
I recently had installed a Stages 105, L crank-arm paired with Wahoo Elemnt Bolt and the readings I am receiving during climbs are consistently 50 watts higher than my riding partners, who are running Dura Ace dual-sided power meters. As they average 280 watts, I am putting out 330+. Including bike weight, I am 12-15 lbs heavier than them, they're identical in weight. We calibrated our power meters together through our head units and all received similar torque-offset numbers and are using 5sec avg Power to read our wattage on the head unit. Am I mistaken in thinking that the difference in weight is too slight to account for the discrepant power readings?
Quoted: 1067 Post(s)
Liked 259 Times
Either your Stages is reading wrong or you have a significantly stronger left leg.
If one of their bikes is close to yours in set up you could swap for a short time to compare readings.
Likes For Dean V:
Quoted: 18883 Post(s)
Liked 10,646 Times
Your system takes three reading from your left leg and doubles it. If both legs always put out exactly the same power, this will give you accurate data. If your left leg puts out 10% more power than your right, your PM will be 20% too high. That's my guess as to what's going on. Does your Stages have a calibration procedure? It would be different from zeroing it before a ride, with pedals you can hang a known weight and check the torque reading.
(A 10% difference between legs is a lot, I picked that for easy math.)
Liked 10,646 Times
Also, you can't really compare 5s averages in the moment to know if your PM works. Look at the second by second power chart for your last ride, it's real choppy, almost random. That's why we use rolling averages. 30s would give you a better idea. People also get different speed out of the same power. You mentioned weight, tires and aerodynamics can make a lot of difference in how many watts you need to go X mph.
Fat n slow
Quoted: 3259 Post(s)
Liked 2,085 Times
You’re 15 pounds heavier, climbing at the same speed and putting out 50w more? Doesn’t seem that far off, especially since some folks have reported that dual sided hollowtech II crank based PMs show too low of a power number at times (I think it was gplama)
Likes For phrantic09:
I like bike
Bikes: Roubaix Comp 2020
Quoted: 267 Post(s)
Liked 283 Times
For what its worth I have the same Stages power meter and it has aligned reasonably well with my Wahoo Kickr power numbers.
Along with the left side issue and the weight issue there is also the efficiency issue (tires, aero, etc). I agree swapping bikes on a climb would be the best way to diagnose it.
Likes For scottfsmith:
Bikes: SL8 Pro, TCR beater
Quoted: 989 Post(s)
Liked 586 Times
I don't believe you should be expecting a similar reading to your friends' power meters given that you have a single sided PM and they have dual sided.
Also, that fact that ou are 15lbs heavier probably makes a difference when you get out of the saddle and start climbing. I would definitively swap out bikes and see what you get in terms of number.
Quoted: 741 Post(s)
Liked 412 Times
There are a lot of variables to consider before coming to the conclusion you have. Some have already been mentioned. I would add position in the bike to the list. 15lb. Difference is considerable on a steep climb. You will be producing a lot more wattage to go the same speed as your riding partners.
Likes For colnago62:
Thread Killer
Quoted: 3148 Post(s)
Liked 1,713 Times
Yeah, that’s not a reliable comparison methodology, and comparing different riders on different bikes will never be a way to validate— or challenge— power meter accuracy. Saying those folks put out about 300w during that 5sec is all you can say about that.
Further complicating this are the known issues with 3rd party, dual sided powermeters on DuraAce R9100 cranksets. Are the friends running those?
Quoted: 1461 Post(s)
Liked 1,486 Times
Ride your friends bike up the same climb and compare? I would look at the average numbers over the entire climb, not just 5 second snips.
Also, 15lb weight difference should be considered in terms of percentage. The difference between 135lbs and 150lbs will be bigger than the difference between 215lbs and 230lbs, for example.
Watts per kilo is a better way to compare between riders than just comparing power output.
Likes For msu2001la:
Quoted: 389 Post(s)
Liked 255 Times
GCN+ did a very interesting lab test about power needed vs weight added on a climb. They added 10 kilos to the body, then 2 kilos to the bike. Measured from 1 to 8 percent on a climb. It was on the end of the "Building the lightest bike" documentary.
Perceptual Dullard
Quoted: 919 Post(s)
Liked 1,156 Times
This post makes me sad.
Power meters are expensive, and we buy them to help answer questions, not raise a new one: "Is my power meter off?"
The good news is that those Dura Ace power meters can be off, too, and they paid more.
Likes For RChung:
Weren't you the one who was arguing that the average person doesn’t need accurate power meters in the other thread?
Advocatus Diaboli
Quoted: 4737 Post(s)
Liked 1,533 Times
FWIW, my Stages L pm is about 10% higher than what my Direto trainer tells me. Which one is correct, I dunno for sure. I suspect the trainer's PM should be more accurate.
Is it just climbs where the difference is read, but on flats you're all about the same? If you all upload to eg. Strava after a ride, it might be more informative to select the same portion of a ride (eg. a 1/2 mile segment) within Strava's "Analysis" section and then read the left-side returned results for the average and Max power for the selected portion.
Quoted: 1814 Post(s)
Liked 923 Times
Re left/right power balance,
absent injury, short or missing limb, etc., has anyone seen any significant, consistent difference in power between left & right legs?
Quoted: 6196 Post(s)
Liked 4,811 Times
Almost the same discussion we used to have with Calories burned on a ride over 10 years ago with our simple HR/GPS cyclometers. Then they said power meters will end this type of thing.
Thread Killer
Liked 1,713 Times
Liked 10,646 Times
Likes For Seattle Forrest:
Liked 10,646 Times
I do. Guess it depends how you define consistent, it goes away when I'm sprinting or going up a steep hill, but at the end of every ride it's always L dominant and always within a particular range of imbalance.
Quoted: 3956 Post(s)
Liked 7,304 Times
Liked 923 Times
Beyond the margin of error for the PM for starters. The couple of times that I looked, My PM registered 51/49, or possibly 52/48. This was not significant enough for me to check again.
I checked youtube before spouting off here, & the guys on Trainerroad seemed to agree that even if recovering from a broken leg, focusing on L/R balance is likely counterproductive,
but maybe somebody consistently puts out >5% more with one leg than the other- that would be interesting.
