how to plug unused braze-on holes
Bikes: 2016 Masi strada vita due, 2019 Kona Dew Plus
Quoted: 268 Post(s)
Liked 80 Times
Those little threaded holes in the frame so you can mount water bottle cage, pump, etc.
You can use short screws, plastic screws or leave them open.
Any other better ideas?
Sunshine
Quoted: 10964 Post(s)
Liked 7,491 Times
I can't think of a better way to plug the holes than to use m5 bolts that were made to go into the holes.
Buy stainless steel bolts that have a buttonhead. They are a lower profile to eliminate snags/scraps and they won't rust.
Likes For mstateglfr:
Quoted: 18420 Post(s)
Liked 15,564 Times
Attach racks and/or fenders?
Likes For indyfabz:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
I always use plastic screws for the bottle cage bolt holes on my cx bikes. Discrete and they won't get stuck.
Likes For cxwrench:
Stainless steel hex-head screws and grease the threads.
Likes For drlogik:
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Anodized bolts to match or complement the frame color.
Likes For Rolla:
Quoted: 6196 Post(s)
Liked 4,810 Times
I can't imagine that you aren't using them. But sure put a screw in them. Plastic, stainless, zinc plated or any other coating that resists rust and corrosion. Cheap stainless might corrode as easy as steel if the threads get wet and stay wet, so put a little anti-seize or lube on whatever you use.
If you want to be quirky, get some sealing wax and put a blob on it with your signet stamped on it.
Likes For gringomojado:
Quoted: 4227 Post(s)
Liked 2,488 Times
Weld them.
Quoted: 1944 Post(s)
Liked 2,164 Times
Bikes: '38 Schwinn New World, ’69 Peugeot PX-10, '72 Peugeot PX-10, ‘7? Valgan, '78 Raleigh Comp GS, ’79 Holdsworth Pro, ’80 Peugeot TH-8 tandem, '87 Trek 400T, ‘7? Raleigh Sports, ‘7? Raleigh Superbe, ‘6? Hercules
Quoted: 761 Post(s)
Liked 1,563 Times
Stainless hex button-head cap screws. Lowe's/Home Depot/Ace Hardware have an aisle with lots of drawers with various screws/washers/odds-&-ends where you'll find them. 5mm with .8 thread are what most are I think. If you think you may someday mount a bottle cage/fender/whatever, get ones that are long enough- if not, get the shortest and save the .001 gr of weight...
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
What is wrong with you fellows? Titanium weighs less than steel. FTW
I assume that by hex-head you mean a set screw.
Like one of these only a little shorter:
Likes For drlogik:
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Likes For ThermionicScott:
I admit to wanting a set of Velo Orange 'punk bolts' to plug the ones on my front fork- they are spike decorative M5s. Everything else gets a water bottle cage though. Cant have too many in Texas.
Likes For mikedk13:
Likes For Bald Paul:
ಠ_ಠ
Galvanic corrosion between aluminum and stainless is a well-documented problem, so don't use a stainless fastener in an aluminum frame/rivnut. Titanium is also sub optimal for the same reason, although not as bad as stainless. Anodizing Ti is for appearance only and does not help with corrosion. The oxide layer is at most about 0.2 micron thick. Anodized aluminum with greased threads, a plastic washer, and low tension would be my choice. Chrome-plated steel for a steel frame.
Other options would be a 5mm rubber hole plug, some colored electrical tape, or decal material over the holes.
It also weighs about 30% more than aluminum. Steel > titanium > aluminum > plastic > tape > nothing.
Liked 2,568 Times
Even if 10-32 weren't almost exactly the same threading as M5x0.8, the soft nylon would safely deform as needed to plug the holes.
ಠ_ಠ
Perhaps, but if someone doesn't have either size on hand, they might as well buy the right one.
Likes For Dirty Dude:
Advocatus Diaboli
Quoted: 4736 Post(s)
Liked 1,533 Times
fill with metal compatible silicon caulk or flex seal?
Likes For CrimsonEclipse:
nylon M5x0.8mm are easy to get.
https://www.mcmaster.com/nylon-screw...d-type~socket/
Likes For son_of_clyde:
2-Wheeled Fool
Bikes: Surly Ogre, Brompton
Quoted: 1385 Post(s)
Liked 677 Times
This is precisely what I do, but I use stainless steel button-head hex screws and coat the threads with beeswax. I searched forever to find some suitable 5mm screws made from BLACK nylon, but could only find them in the color white, which looked kind of weird. The other problem with the white nylon screws were that they were a very tight fit in the threads. I broke one as I was unscrewing it and I barely got it out. I ran one through a 5mmx.08 threading die, and that cleaned it up and was then able to thread it in nicely. I didn't use them though. The white screws just looked like crap.
So I now use the button-head hex screw in the shortest I can find, which is 8mm in length. I also get them in the Torx version, which guarantees that I'll get the screws out comfortably, and since they wont be holding anything onto the frame, I don't need to reef down on them to get them to stay tight. I used to do a lot of leatherworking along with knifemaking, and while I was into that, I discovered the many uses and applications for beeswax. I fell in love with it. Essentially its a nice, pliable, non-hardening thread sealant, that also acts like a low-strength threadlocker.
Likes For J.Higgins:
