Chain fell off mid pack
Quoted: 2700 Post(s)
Liked 486 Times
Hey guys, my chain on my single speed had been falling off recently, so I reduced the slack by moving my back wheel a bit. Today I was in the middle of the pack on a group ride, and my chain fell off, I went over to the side and started yelling "stopping, stopping." Pretty darn embarrassed, I'm trying not to get a reputation for a sketchy rider and this doesn't help my case. Should I take the bike to a bike shop before riding it in the group again? Should I apologize on the facebook group for the mechanical? Have any of you dealt with people who have mechanicals like this, how sketchy is it/how do I build my rep back besides just not having it happen again. Sorry for the blog post lol
Quoted: 9656 Post(s)
Liked 6,366 Times
Gold chain or silver?
Klaatu..Verata..Necktie?
Quoted: 10442 Post(s)
Liked 11,915 Times
Advocatus Diaboli
Quoted: 4739 Post(s)
Liked 1,533 Times
Did any cars drive over the chain after it fell off? Or could you put it back on?
Likes For Sy Reene:
Quoted: 8287 Post(s)
Liked 9,062 Times
The fact that you got out of the way and warned everybody should help your cred. Bikes have problems sometimes and if you're trying to get it sorted, that's all others can ask. That said, it's pretty unusual for a ss to drop the chain, no?
Just don't be that guy who always has problems.
Likes For LarrySellerz:
Expired Member
Quoted: 3675 Post(s)
Liked 5,441 Times
Sup Larry! Did anyone stop while you fixed the chain? If they did you may be OK at least until the next incident. Your chain shouldn't be falling off.
Last edited by shelbyfv; 11-15-21 at 09:33 PM. Reason: Removed incorrect suggestion
Habitual User
Quoted: 4957 Post(s)
Liked 8,099 Times
If your chain is falling off on any kind of regular basis, there's something really wrong with your setup. I ride a singlespeed MTB on some pretty technical terrain, and things get banged around a lot. I have had my chain drop zero times. Proper chain tension and good chainring-cog alignment are highly important details in proper SS setup.
Likes For Eric F:
just another gosling
Quoted: 3891 Post(s)
Liked 1,940 Times
Single speed, not a fixed hub? If you don't know how to fix it, yes absolutely take it to a shop. Stuff can happen on group rides, which is the reason that our group has admission standards. One can't just show up and ride. If you're worried about rep, get your bike fixed and explain/show what happened and the fix to the ride leader. Don't worry about the rest of the group - they'll be OK after a a few perfect rides. Mechanicals happen.
Results matter
Results matter
Liked 486 Times
Guess i'm taking it to the shop, don't like putting money into such a cheap bike (150$) but this can't keep happening. This is a self policing drop ride with no leader, but I don't wanna grind peoples gears too much you feel? Especially because showing up on a single speed is kinda clownish
Likes For msu2001la:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Sup Larry! Did anyone stop while you fixed the chain? If they did you may be OK at least until the next incident. Your chain shouldn't be falling off. Is this a single speed you kludged or a proper bike? If it's cobbled, check your chain line and be sure you are using a "narrow wide" chain ring.
Expired Member
Liked 5,441 Times
Bikes: lots
Liked 2,932 Times
Likes For cxwrench:
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4393 Post(s)
Liked 3,017 Times
This is some kind of wayward harmonic convergence.
Likes For MinnMan:
Sunshine
Quoted: 10970 Post(s)
Liked 7,496 Times
Likes For mstateglfr:
Sunshine
Liked 7,496 Times
Worst thing that could happen in SS, the chain comes off the rear cog and lodge itself between the cog and the dropout, it can lock the rear wheel and take out the rider(s) behind you.
Happened to me twice with the same bike, I managed to fix the problem but can't remember what caused the problem in the first place, it was very long time ago.
Impossible to happen in geared drivetrain due to L and H adjustment
Half way there
Quoted: 987 Post(s)
Liked 880 Times
In a single speed setup, a properly tensioned chain should not be falling off. I'd check these: 1) Chain condition - replace it if stretched, 2) Chain rings and cog for any anomalies like bent teeth. Some chainrings have "features" for better shifting; however it's not likely that they would cause a chain drop. 3) proper alignment - is your rear wheel co-planer with the frame centerline? This is done by properly mounting your wheel. Is the chainline right? This may require a different bottom bracket spindle, though respacing the hub may do the trick (but this may require re-dishing the wheel) 4) Frame alignment - If your rear triangle is offset you'll have problems. Check with either an alignment gauge or use the string test. 5)Frame flex - if your chain drops occur when applying a lot of pedal pressure it may mean that your frame is flexing to the point that mis-alignment occurs.
Good luck, mate. I hope you figure it out.
Likes For Moe Zhoost:
Quoted: 850 Post(s)
Liked 344 Times
A video is worth a million words. Show us how much chain slack you have. It's possible that your rear wheel is slipping as you tighten the nut. In that case, you need better nuts and possibly chain tensioners.
Or better yet, a video of this group riding by. Sounds like a real mixed bag!
