Optimum tire width (700c) for commuting and light touring on paved trails.
I'm building a bike (Handsome 'Devil") which I intend to use for commuting and some light touring. Any suggestions as to what tire width is a good balance between speed and comfort.
Thread Killer
Quoted: 3147 Post(s)
Liked 1,712 Times
It really depends on rider weight, but it’s probably 30c.
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,995 Times
My theory is as wide as you can go comfort and tire choice (not width but quality) I think is most important especially for speed.
Likes For veganbikes:
I am potato.
Quoted: 1789 Post(s)
Liked 1,629 Times
On paved trails, I don't really think tire width matters as much as orthodoxy suggests it should within reason, of course.
There is 2 schools of thought with commuting.
One school is: Indestructible flat proof tires like Gatorskin Hardshells or Marathon Supreme, or any other number of similar tires that air or not the sidewalls are stiff enough, you *could* ride to work even if you were fortunate enough to come across something that could make 'em flat.
The other school is: Decent rolling tires with supple sidewalls set up tubeless.
In either school, the proper width/pressure is usually a width that allows compression about 15% of the tire height when loaded & is somewhere near the middle/two-thirds/three-fourths of the tires pressure rating.
I commute on tubeless
Compass, 559x58's@35psi,
Gravelking, 700x38@50psi &
Grand Prix 5000 TL, 700x25@85psi, 19 miles one way, mostly road 30% bike trail. The lower pressure of tubeless also mitigates any puncture risk that would motivate a person to go to school one. Then the self-sealing nature seals the deal for reliability.
Any of the above rolls nicer & is faster than the tubed indestructible Gatorskin Hardshells 700x23@110psi or even decent Panaracer Gravelking SK 559x52@35-40psi, tubed.
My general recommendation based on my own personal experience & needs for an all-round nominal tire setup is 700x28-38 tubeless, Preferably a high quality tire made by Panaracer, regardless of what actual brand has their name printed on the side...but I have no idea what you weigh, where you ride, how far you commute, what your bike will accommodate, or what your local hazards are.
The absolute most miserable combinations I have come across all involved Mr. stuffy style liners &/or/in addition to thorn-proof tubes. Second to that, big low quality tires at high pressures.
Quoted: 2604 Post(s)
Liked 1,933 Times
Pavement may not be quite as variable as gravel (is that pea gravel, crushed gravel, 1" rocks, or a fire road that hasn't been repaired since that fire back in '53?). But it still isn't a single word descriptor.
My Fair City calls all of these paved:
- Fresh pavement in the last year
- Small potholes
- 9" wide potholes 6" deep (a killer on rims if you don't miss it!)
- Longitudinal cracks wide and deep enough to trap 25 mm wide bike tires
- Something allegedly paved that resembles the surface of the aforementioned fire road interrupted by patches of asphalt
Optimum tire width might vary from 20 mm wide (fresh pavement, 2 pounds of load on you back and you weigh 110 pounds when you get rained on) to a 60 mm wide 29er (that's still 700C!), the latter applying if you're riding the allegedly paved road and weight over 300 pounds.
TL/DR? It depends.
- Small potholes
TL/DR? It depends.
Am-a-tour
Bikes: 2020 New Albion Privateer, 1983 Schwinn Super Sport, 2022 Rivendell Atlantis
Quoted: 44 Post(s)
Liked 65 Times
I'm a big fan of wide slicks for paved riding. It looks like your new bike will handle 700c x 38, and that would be my recommendation. If you have concerns about punctures, maybe go with an armored offering, like the Soma Shikoro or Panaracer Gravelking+.
Quoted: 6972 Post(s)
Liked 10,968 Times
31.639mm.
Likes For Koyote:
Likes For blurcovenky:
- Small potholes
TL/DR? It depends.
- Small potholes
TL/DR? It depends.
Liked 10,968 Times
You're overthinking it. Put on some decent thirty-something millimeter wide tires and ride yer bike. Just make sure they fit in your frame and fork.
True that I might be 'over thinking it'. I'm also working on a budget and hoping to get it as close to right the first time, hopefully, with inputs from other people who have had similar experiences. Thanks anyway.
Friendship is Magic
Bikes: old ones
Quoted: 26425 Post(s)
Liked 10,381 Times
...I ride all over town here in Sacramento on 700x25 Vittoria Rubino Pro tyres. There is plenty of glass and crap in the bike lanes on public streets here. Youi do have to stay alert to it, and dodge around the worst of it. In wetter conditions, I usually end up on a bicycle set up with 700x28 Ruffy Tuffy tyres, or the more recent 700x33 Jack Brown's. I think the latest iteration of the Jack Brown tyre is 700x25, but they are rated at lower pressures than I prefer.
There's no one right answer to this that fits everyone, and the oly way you'll figure out your personal preference is by experimentation. But if you weigh 150 pounds, and itsounds like you will be riding mostly paved surfaces, 700x28 is plenty wide enough, and 700x25 in a decent tyre like the Vittoria's will probably work OK for you. I weigh considerably more than that.
Likes For 3alarmer:
Callipygian Connoisseur
Quoted: 564 Post(s)
Liked 350 Times
Your tires should be as wide (or wider) measured in millimeters.
Pay the money for quality tires.
Likes For Kedosto:
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,294 Times
One bike has 42's, another 44's, and the last 55's
Quoted: 4414 Post(s)
Liked 4,867 Times
28-32 mm is all good for me. But more important to choose a good tyre. Pirelli Cinturato Velos are a great all-round road tyre. Grippy in all conditions, very puncture resistant, comfortable and reasonably fast. Can run them tubed or tubeless too as you prefer. If your frame has clearance for 32 mm I would go for those. You give up very little, if any, speed for added comfort.
Quoted: 2333 Post(s)
Liked 2,097 Times
30 or 32mm GP5000 tubeless. Fast and reasonably long lasting. I would easily expect 4-5,000 miles on a 32mm
Liked 1,933 Times
If you ride enough, you'll wear out whatever you put on first and you'll have an opportunity to try a different tire.
Likes For pdlamb:
Likes For sloppy12:
Quoted: 5224 Post(s)
Liked 3,584 Times
when I commuted a lot, it was mostly on 28mm tires, w/ some kind of puncture resistance / protection. now-a-days ... my road bike is more of a "joy-rider" so when I do bike to work, 22 miles ea. way, I'm on 25mm tires. only ride stopping incident has been a rear broken spoke
Likes For rumrunn6:
Quoted: 338 Post(s)
Liked 408 Times
For commuting I use my gravel bike with 33mm gravel tires set up tubeless but I've also used my road bike with 25mm GP5000, also tubeless. At a reasonable pressure both are comfortable.
Gravel bike has flat pedals which is more convenient than changing shoes when I get where I'm going. For light touring I'd just put stuff in my backpack and use the road bike though.
Quoted: 3241 Post(s)
Liked 2,512 Times
It really depends on whether or not you'll be doing any CAT 6 racing. That's the most important factor.
Sunshine
Quoted: 10964 Post(s)
Liked 7,491 Times
But more important than width for speed is tire construction. A 35mm wide tire that is quality can roll faster than a 25mm cheap tire, for example.
Personally I would buy a 35-38mm quality tire. Itll roll fast with tires pumped up and give you comfort if you drop the pressure a bit.
Quoted: 6196 Post(s)
Liked 4,810 Times
Tires wear out if you ride often. You'll have all sorts of chances to get it right. However if you are happy with the suggested size of others and you to put that size on and never change them you'll never know whether there might be a better size that suits your preferences.
