Rear brake makes a "thump" 1x per revolution
So I got this new wheel. When braking if the rim is cold it seems fine.
If I'm on a descent and using the brake after some time (100ft+) of braking, I start feeling this "thump" every time the wheel goes around. I assume the rim is heating up, and causing some deformation, does that sound correct? It's sort of hard to find since on the work stand it seems perfectly smooth.
Any ideas?
-john
Any ideas?
-john
Bikes: All 70s and 80s, only steel.
Make sure the pads are low enough to be ONLY in contact with the rim--if one is impinging some very small amount on the tire, a warmer tire could be bulging out just enough and touching the rim for you to be feeling it. As Kwoodbury mentioned above, check both surfaces of the rim. Try running your finger over the surfaces, and also, shine a light down from above; look to see if the rim isn't reflecting light back with the same shine in some spot.
Quoted: 5793 Post(s)
Liked 2,585 Times
You'll also probably see some rubber transfer on one side or the other of whatever is causing the thump. Look for the Telltale black (or salmon) transfer and feel that area for any distortion.
You might also wait until it happens, then get off the bike and spin the wheel with the brakes closed just enough to work as feeler gauges, and possibly see the exact cause.
FB
Chain-L site
FB
Chain-L site
