Road quick release / QR / skewers, light vs 'normal'
Hey,
I've just found a crack on my QR from Roval wheels (probably I was using too much force), and I need ones (or at least one ), S-Works Tarmac SL6 frame.
Can you feel difference between 'standard' ones that weights >100g and light ones? (35-50g?) I'm not talking about the weight but clamping force (bike handling later etc.)
Or difference between ones with internal cam mechanism and the ones with 'external' (of course I'll avoid ones with plasticky parts).
internal cam
external:
and very light:
internal cam
external:
and very light:
Quoted: 5826 Post(s)
Liked 2,660 Times
The answer depends on your bike.
Very little clamping force is needed for front wheels, except those with disc brakes. Likewise for rear wheels if you have vertical dropouts.
Vertical dropouts have allowed QRs with poor clamping to succeed. However they often cannot keep wheels from slipping with horizontal dropouts. Likewise, poor performance of these newer QRs on disc brake bikes stimulated the change to through axle systems.
So, consider the specific needs of your bike and choose accordingly.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
ah, didn't add, S-Works Tarmac SL6 frame, rim brakes, so quite 'standard' open dropouts, full carbon at the front, at the back NDS dropout is carbon, DS has outer side metal (hanger).
but also I saw people commenting somewhere that with 'weak' clamping force, you can feel more flex (during turning)
Likes For razorjack:
ignominious poltroon
Quoted: 2254 Post(s)
Liked 3,469 Times
Get steel. Titanium slightly stretches.
Expired Member
Quoted: 3702 Post(s)
Liked 5,535 Times
You seem to be aware that internal cam design clamps better. Once you move to external cam, I don't think you can generalize based on weight.
Liked 2,660 Times
While I'm normally a strong believer in QRs and axles with hard serrated faces that can bite into the frame, your bike calls for the opposite. Look for relatively smooth faces that won't cut into those CF dropouts.
Likes For FBinNY:
Somehow wheel manufacturers, even with most expensive wheels and lightest wheels (roval, shimano etc.), provide quite standard skewers weighting >100g
and light ones with external cam 40-60g ...
And I believe that clamping force may affect how frame flexes... (I don't know how much however )
Quoted: 6243 Post(s)
Liked 4,845 Times
Just curious. Where on the QR was the crack?
Likes For Iride01:
Liked 2,660 Times
Of course, you're free to believe what you will, but in my world, a theory without an explanation of the underlying mechanism is just a bunch of words.
Likes For FBinNY:
as 2 surfaces - hub end cap surface and frame surface will stick more - creating stiffer interface
in case of a city bike, probably it doesn't matter...
Yep. I don't have to believe in your "even weakest QR will do" theory
Liked 2,660 Times
You came for advice. Nobody says you have to accept it.
FB
Chain-L site
FB
Chain-L site
Quoted: 441 Post(s)
Liked 469 Times
In my 20+ years of cycling I've had two instances of QR skewer failure. Both were of the external cam type and both had the nut end (not the lever end) unscrew itself. On one case, I'll take the blame as it was one of those ultralight Ti skewers from eBay (probably didn't pass QA and should have never been sold). The other is a stock Bontrager skewer that seemed really solid and robust but it was on a gravel bike and maybe I didn't tighten it enough before clamping. Possibility of user error there but I still don't trust it fully.
Apart from this, my opinion is that a skewer is a skewer. I like Shimano and Reynolds ones. Mavic skewers feel nice but I don't think they clamp as hard, but they've also never failed me, either.
Quoted: 7043 Post(s)
Liked 11,087 Times
Just buy a pair of Ultegra skewers (off Amazon, perhaps) and be done with it. They work as well as anything out there and the weight is a non-issue.
Likes For Koyote:
Liked 3,469 Times
My favorites are the Dura Ace (as pictured in the OP) and DT Swiss steel skewers that use the same ratchet-like mechanism as their thru-axle handles.
Expired Member
Liked 5,535 Times
Likes For shelbyfv:
Quoted: 557 Post(s)
Liked 419 Times
Good clear photo showing the crack in the QR housing.
The vintage Shimano ones were machined steel, this one in the photo looks like it was die casted.
All you can really do is replace it with a better one.
If you want to be precise on the force, get a nut and bolt skewer. Those gets tightened with 7nm.
I use these on my personal bikes. I never remove the wheels anyways as I transport with a platform carrier.
Besides, they are just very long M5 bolts that use the same 4mm hex tool.
Quoted: 3548 Post(s)
Liked 2,966 Times
Likes For smd4:
Quoted: 557 Post(s)
Liked 419 Times
As one of the top 10 bike cities in the world, are you aware wheelset theft in my hometown is common?
I'll keep my skewer bolts and my wheels. Thanks.
Liked 2,966 Times
My QR wheels would never get stolen no matter where I lived because I would never leave my bike unattended.
Quoted: 557 Post(s)
Liked 419 Times
What was I thinking with silly locknuts for my wheelset. I'm so dumb to leave my bike unattended.
I suppose about a hundred thousand daily commuters should just bring their bikes into their workplaces and classrooms.
