Difference between Sugino 75 road and track cranks?
^that guy^
Like the title states, what's the difference?
^that guy^
The spider looks longer than 130 but guess not
Quoted: 5767 Post(s)
Liked 2,541 Times
The spiders on road cranks would be designed to carry 2 rings, while a track crank would only carry one.
I don't speak with authority on this, but companies that make both road and rack cranks often use the same forging, with the only difference being that they machine off the chainring support shoulder for the inner ring on the track version.
FB
Chain-L site
FB
Chain-L site
Your cog is slipping.
Bikes: steel track
Quoted: 235 Post(s)
Liked 2,541 Times
it's easy enough to check bolt circle diameter. measure on center between 2 adjacent bolt holes, then multiply by 1.7. (5 arms)
Ie. a 5 arm 130 BCD crank will measure 76.5mm bolt to bolt.
FB
Chain-L site
FB
Chain-L site
Bikes: steel track
Quoted: 235 Post(s)
I'm guessing he doesn't have them yet. Probably saw for a good price on eBay and is wondering if the road version is really a good bargain.
Liked 2,541 Times
I've done that job, and it goes very fast if you start with a very coarse file. Complete the job a half mill file for a smooth finish.
FB
Chain-L site
FB
Chain-L site
Bikes: steel track
Quoted: 235 Post(s)
Liked 2,541 Times
It depends on the frame and chain line. On my track bike, the inner support wouldn't clear the chainstay.
FB
Chain-L site
FB
Chain-L site
Bikes: steel track
Quoted: 235 Post(s)
Got it, thanks guys. In my mind's eye the chainring was hitting the chainstay before that shoulder would; guess I'll have to adjust my mental imaging.
Liked 2,541 Times
Don't sweat it until you see it together. As I said, it depends on the bike, so you may be OK, or may need to take out the file.
FB
Chain-L site
FB
Chain-L site
^that guy^
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1331 Post(s)
Liked 764 Times
AFAIK, The 75 series of Sugino cranksets are strictly a track version with a 144 bcd. They are currently available as either square taper or external BB with splined interface.
Edit - I did some research, and it appears that road versions of the Sugino 75 series were made in the 1980s, but are no longer being made.
What, Me Worry? - Alfred E. Neuman
I see the light at the end of the tunnel, but the tunnel keeps getting longer - me
THE STUFFED
Bikes: R. Sachs Road; EAI Bareknuckle; S-Works Enduro
Quoted: 361 Post(s)
Liked 20 Times
There actually is an entire sugino 75 road groupset. I learned of this when I ran into a partial group at a veloswap and later read up on the group at velobase. Apparently they had contracted out manufacturing of the non-crank bits to Suntour.
VeloBase.com - View Group
THE STUFFED
Quoted: 361 Post(s)
Liked 20 Times
75 road cranks can run a 1/8th chain and chainring without issue when set up as a single. Even with the chainring on the outside of the spider.
If anything you're just limited by your ability to find chainring sizes in 130 bcd and crankset lengths running them on the track.
Specialites TA makes really nice 1/8" 130bcd chainrings in sizes ranging from 44-52t and longer crank arms aren't an issue on the track considering one leans away from the banked corners.
What ever young contrarian, my old Campag road are 144 BCD, track crank spiders are machined to only have an outer chainring..
Veteran Racer
Liked 764 Times
That’s not the problem. When riding at slower speeds, the up track right side crank can hit on the banking in the turns on steeper tracks. I’ve seen this happen to a track rider that liked to use 175mm crank arms and really tall gearing.
Quoted: 4792 Post(s)
Liked 3,918 Times
Ben
stanzela
Singlespeed & Fixed Gear
15
06-02-11 08:01 AM
Broom Wagon
62
07-21-10 05:29 AM
