Quickstep Rode Tubeless And Won
Quoted: 741 Post(s)
Liked 412 Times
So I was listening to a recap of the race the announcer said the whole team was on clinchers. I assume he was referring to tubeless given the race was a spring classic and there cobbled sections. Pretty significant that they also won in that setup.
Likes For colnago62:
Thread Killer
Quoted: 3147 Post(s)
Liked 1,712 Times
The team had committed to tubed clinchers for the ‘21 season, but there was some uncertainty around the classics, so yeah, you could be right about tubeless.
https://www.cyclingnews.com/news/bor...yres-entirely/
Likes For chaadster:
Quoted: 1221 Post(s)
Liked 629 Times
"Rode" and "Road" - gotta love English
It was my understanding that quickstep was running tubeless clinchers but they were still using inner tubes instead of full tubeless. Education First was also running tubeless last year with prototype foam inserts.
Remember as a Pro, the best product you ride is the one the Sponser tells you to ride
Likes For Dirk de Chablis:
Quoted: 1461 Post(s)
Liked 1,486 Times
If they're riding clinchers anyway, what would be the disadvantage of setting them up tubeless? Isn't the rolling resistance on tubeless generally better than tubed?
Quoted: 20810 Post(s)
Liked 9,456 Times
Generally, but with the right combination of tire and latex tube, the clincher could eek ahead. Specialized thinks that their Turbo Cottons are the fastest things around and they're so confident in them that their new high-end wheels don't support tubeless and opt for lighter weight, instead IIRC.
Liked 1,486 Times
I assume for races where they run the Rapid Air instead, they use a different wheelset that's tubeless, or are they running those tires with tubes on the same wheels?
The main benefit to Tubs are if you puncture you can still ride on a flat till you can get service, with a clincher the tyre comes off and you're on the rim. All the test will come out in favour of the manufacturer as to who has the fastest tyre, whether it's Conti, Michelin, Pirrelli, Spesh, Schwable and all the tests ore done on a nice indoor rig. In the real world and the road there's too many variables with surface, air pressure, humidity, wind direction and rim profile for a difinitive answer. Anyway Tubs feel better than clinchers and sound better
Liked 9,456 Times
Pfft - I don't know. Honestly, I really don't understand why they say that their Rapide CLX aren't tubeless compatible. I mean, they say that tubeless exerts more pressure and that the Rapide aren't built to withstand that pressure, but I'm not following how they can handle 120psi if it's in a tube but not when it's tubeless.
Forum Moderator
Quoted: 3091 Post(s)
Liked 6,601 Times
Fixed thread title typo
Likes For cb400bill:
Thread Killer
Liked 1,712 Times
That said, there’s a lot of unclear messaging going on just in the article I posted upthread alone, so it’s not at all clear to me that we know what the situation actually is. I can easily imagine that the RapidAir tubeless might be constructed to be more of a poor conditions or perhaps wet weather performer, and the Turbo Cotton clincher the max performance dry tire. However, the article made it seem that the team may not have use RapidAir on the race cobbles, so does that mean they ran tubulars despite the assertions they’re all clincher this season? Or that they ran the Turbo Cotton for that section but will use RapidAir tubeless generally? Or that they ran the RapidAir tubed for the cobbles, perhaps because the new Specialized wheels aren’t tubeless compatible?
Quoted: 6196 Post(s)
Liked 4,810 Times
Tubeless are clinchers too right? I suppose tubular tires might could be tubeless if someone makes them. Never looked, are there tubeless tubulars?
Liked 9,456 Times
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,981 Times
Liked 1,486 Times
They are supposedly less prone to pinch flatting, and sealant can help seal up small cuts/holes like a standard tubeless tire, but they don't need sealant. I've never added sealant to mine, which are now 2 years old, and they hold air fine.
Liked 1,486 Times
I have a feeling if it weren't for sponsor input, pro teams would be on tubulars 100% of the time. The downsides to tubulars (cost, setup hassle, more complicated/impossible roadside fixes) are all negated by having huge budgets, pro mechanics and team cars.
I'd be curious to know if any pro riders actually prefer the Turbo Cotton (with tubes) over a tubular setup. Pro riders probably all hate tubeless because the casings are a little stiffer.
Liked 9,456 Times
Likes For WhyFi:
Liked 629 Times
Also aren't tubular wheelsets lighter than clinchers?
Likes For rubiksoval:
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
