Chain sitting in mineral spirits - how long is too long?
Old 12-28-20, 08:00 AM
billyymc
Quoted: 273 Post(s)
Liked 123 Times in 56 Posts
So I popped the chain off my gravel bike two weeks ago and dropped it into a container of mineral spirits and a little motor oil mixed (about 10:1).
Then I got busy with work, the holidays, a 40" snowstorm, and forgot all about the chain.
I usually leave it in the mix for a day or so at the most.
Have I done any damage to the chain? Should I replace it? This might be a stupid question - but if there's even a chance I've compromised the chain I'd rather just replace it.
billyymc is offline
Old 12-28-20, 08:08 AM
shelbyfv
Quoted: 2151 Post(s)
Liked 1,973 Times in 1,066 Posts
I'm no metallurgist but I would not hesitate to lube it and use it.
shelbyfv is offline
Old 12-28-20, 08:27 AM
HillRider
Quoted: 1610 Post(s)
Liked 459 Times in 353 Posts
If you used "real" (petroleum based) mineral spirits, the chain can soak indefinitely with no harm. If you used "green" (i.e. water based) mineral spirits long soaking can damage the chain.
HillRider is offline
Likes For HillRider:
Old 12-28-20, 09:42 AM
Iride01
Hits [ENTER] b4 thinking
Iride01's Avatar
Bikes: '20 Tarmac Disc Comp '91 Schwinn Paramount '78 Raleigh Competition GS
Quoted: 2501 Post(s)
Liked 1,192 Times in 873 Posts
If a compromised chain bothers you, then why would you not have just put a new chain on when you took the other off? I'm not sure what devastating thing you fear will happen from a compromised chain.
I'd think that if it measures within what ever acceptable range of wear you go by, then just lube it up, put it on and maybe just check it more often for wear to satisfy yourself it's okay.
Iride01 is online now
Old 12-28-20, 09:49 AM
billyymc
Quoted: 273 Post(s)
You ever have a chain break on you while riding? Let me give you a hint - they don't usually break under moderate power. Break a chain at a critical time while standing and putting out a lot of power for a short burst up a hill and let me know how that goes.
I asked because I didn't know. Thanks for the attitude. It wouldn't be bikeforums without it.
billyymc is offline
Likes For billyymc:
Old 12-28-20, 09:50 AM
billyymc
Quoted: 273 Post(s)
Thanks. I should be ok then. I bought green mineral spirits once and found them pretty useless for anything.
billyymc is offline
Likes For billyymc:
Old 12-28-20, 09:55 AM
HillRider
As I posted above, long soaking in real mineral spirits will do no harm whatsoever. There have been problems reported on this forum with long term soaking in water based "green mineral spirits". The chain was corroded and embrittled and did break under load. As you noted, you want to avoid that.
Old 12-28-20, 10:06 AM
Eggman84
Bikes: 2014 Bruce Gordon Rock&Road, 1995 Santana Visa Tandem, 1990 Trek 520, 2012 Surly LHT
Quoted: 206 Post(s)
Liked 40 Times in 33 Posts
Short of doing a destructive test (placing it on a test stand and applying a force until it fails) no one can conclusively answer whether soaking the chain in mineral spirits (or any solution include humid air) has compromised its yield strength. . So if you have any concern, put on a new chain; cheap insurance against the sort of catastrophic failure you are concerned with.
Eggman84 is offline
Old 12-28-20, 10:18 AM
billyymc
Quoted: 273 Post(s)
Agree. I didn't have much concern before I asked. I have less now.
That said, the chain probably will need replacing just based on mileage / normal wear in the spring anyway. Would like to just get some winter riding out of it.
billyymc is offline
Old 12-28-20, 10:31 AM
Iride01
Iride01's Avatar
And I ask why it concerned you so much because I didn't know? So should I thank you for your attitude?
Chains break from too much power being put on them. If you can't shift to a lower gear and pedal faster, then you'll probably continue to break chains.
Old 12-28-20, 11:01 AM
Gresp15C
Gresp15C's Avatar
Quoted: 937 Post(s)
Liked 463 Times in 309 Posts
I once bought "green" mineral spirits by accident because it was on deep discount so I didn't look at the label. Why don't they just call it something else? Reminds me of when I needed TSP for something, and all the store had was "phosphorus free TSP." What the hell is phosphorus free trisodium phosphate?
Anyway, I've stored chains in mineral spirits indefinitely. I used to take the chain off my winter bike at the end of the winter, drop it into a jar of mineral spirits, and take it back out the next winter. In terms of chemical reactivity, I don't think it's substantially different than oil or even wax.
Gresp15C is offline
Likes For Gresp15C:
Old 12-28-20, 01:09 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds.
Quoted: 1307 Post(s)
Liked 506 Times in 389 Posts
IF the executor of your estate has to deal with it, it's too long.
Bill Kapaun is offline
Likes For Bill Kapaun:
Old 12-28-20, 01:58 PM
rosefarts
With a mighty wind
Quoted: 645 Post(s)
Liked 346 Times in 209 Posts
This is the line of thinking among rock climbers with some gear. Mostly unwarranted but understandable.
Unless you think a broken chain will kill you, ride it.
rosefarts is offline
Old 12-28-20, 03:02 PM
gauvins
Bikes: Custom built LHT & Troll
Quoted: 526 Post(s)
Liked 27 Times in 23 Posts
I don't know, but : (1) I've left a stainless chain + connex master link (which appears to be plated bronze) to marinate in a jar of mineral spirits for something like 6 months, and the master link appeared to have been corroded. Probably a case of two metals differing on the galvanic scale. I've kept the chain but discarded the master link. (2) Motivated by this thread, I've googled something like [mineral spirits corrosion] and came across this entry, which says that concentrated spirits are corrosive.
So, I wouldn't bet the farm, especially if different metals are involved. (the less noble might very well have suffered).
gauvins is offline
Old 12-28-20, 03:21 PM
Kapusta
Cyclochondriac
Quoted: 1845 Post(s)
Liked 1,149 Times in 675 Posts
No, it wouldn't
Kapusta is online now
Old 12-28-20, 03:43 PM
Dave Mayer
Quoted: 772 Post(s)
Liked 125 Times in 84 Posts
I've forgotten chains and other metal bike parts in mineral spirits in containers for months with no effects. Having a university chemistry degree, I cannot conceive how pure mineral spirits could lead to any negative effects.
As far as: 'green' mineral spirits, I've never heard of this. Mineral spirits are solely petroleum-based, unless they've been mixed with some polar molecules including water. This would be the last thing one would want, due to the possibility of corrosion, and the fact that water-based degreasers are inherently ineffective - Chemistry 101.
Hopefully the add-on: 'green' is just some kind of virtue-signaling label, to salve the misguided consciousnesses of a specific class of consumers. As with all lubrication and degreasing products, anything 'green' is expensive and ineffective.
Dave Mayer is offline
Old 12-28-20, 04:42 PM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 2496 Post(s)
Liked 1,032 Times in 669 Posts
It's only too long if the chain is still soaking in the mineral spirits when you want to go out and ride.
JohnDThompson is offline
Likes For JohnDThompson:
Old 12-28-20, 04:49 PM
Bill Kapaun
Possibly the MS had some hygroscopic ingredient that attracted moisture. Ethanol in gasoline is such an animal.
Old 12-28-20, 04:59 PM
HillRider
I believe you misinterpreted that entry, The website is not describing metallic corrosion but the use of mineral spirits as a paint stripper.
Old 12-29-20, 12:02 AM
cyccommute
Mad bike riding scientist
cyccommute's Avatar
Quoted: 3990 Post(s)
Liked 1,435 Times in 887 Posts
I would bet the farm...on the fact that there is no way that the mineral spirits is responsible for any metal corrosion. Metal corrosion needs materials that are polar like water and/or ionic substances. Those aren’t in the petroleum distillates we call “mineral spirits”. You may have had something else in the jar that caused the corrosion but it wasn’t mineral spirits.
When the link you posted said that the concentrated mineral spirits are “corrosive”, they probably meant with regards to skin...although I’m not sure what they mean by “concentrated” since mineral spirits is never diluted.
Stuart Black
cyccommute is offline
Likes For cyccommute:
Old 12-29-20, 09:27 AM
RGMN
Quoted: 184 Post(s)
Liked 116 Times in 82 Posts
I've broken chains on both road and mountain bikes while riding. They always broke while shifting under power. I've been with my riding buddies when they've broken chains. Always when they were shifting, usually under power. I've yet to see someone strong enough to break a chain when standing and putting the power on. Including a guy that weighed 350 lbs at that time (he's now down to 170, and kicks my ass every time I ride with him.) He'd jump on the pedal so hard you could see the wheels and frame deflect. He bent and broke several pedal spindles and a bottom bracket but never a chain. I'm not saying it can't happen, just that my experience both riding and working in several bikes shops is that when someone comes in with broken chain the explanation always starts with "I was shifting and..."
As to the OP questions, I've left chains in mineral spirits up to 4 months with no ill effects. But I have broken chains before so you might want to take that into consideration. But none of the chains that broke were soaked in mineral spirits for long periods of time.
RGMN is offline
Old 12-29-20, 11:39 AM
HillRider
No correlation.
Old 12-29-20, 02:10 PM
spelger
spelger's Avatar
Bikes: yes, i have one
Quoted: 354 Post(s)
Liked 295 Times in 164 Posts
that's what two chains are for.
spelger is offline
Likes For spelger:
Old 12-30-20, 09:40 AM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Quoted: 3501 Post(s)
Liked 714 Times in 490 Posts
I'll let the chemists in the room review the differences, but here you go.. Regular vs Green SDS sheets.
Sy Reene is offline
Old 12-30-20, 10:08 AM
Iride01
Iride01's Avatar
I bought a can of "green" paint thinner once. It was useless for the paint's and stuff I normally used mineral spirits for. So it got thrown out mostly unused. Which definitely isn't being green.
Even paint thinner that isn't marketed as "green" can be a mixture of other stuff and not pure mineral spirits.
