What kind of Falcon is this?
Old 01-08-21, 04:36 PM
Senior Ryder 00
Old bikes, Older guy
Senior Ryder 00's Avatar
Location: Fiscal Conservative on the Lefty Coast - Oregon
Bikes: A few modern, Several vintage, All ridden when weather allows.
Quoted: 124 Post(s)
Liked 32 Times in 24 Posts
Hi folks,
I was given a strange, weathered, old Falcon road bike, serial #: X30822. It was translucent red with foil labels, but is now badly faded. The frame and lug work is very nice wrap around seat stays, but no tubing decal. The drop outs are either stamped or machined with a derailleur hanger on the rear DS drop out. It has Campagnolo Valentino shifters & derailleurs, Weinmann 999 center pulls, Pivo stem with what looks like GB bars and a unique, unbranded 5 arm cottered crank. The wheels appear to be replacements. The rear is a cheapo with a 3 piece steel hub laced to a chrome steel rim. The front is a Mallard SF hub with a chrome Rigida rim. Both are 27 X 11/4.
Dont know much about these bikes except that the co-op where I volunteer have one of the Eddie Mercks labeled ones. The frames look the same to me, but theirs has a mix of older Campagnolo drive train parts with the same brakes.
Does an
yone know what level this bike is? Im not so much interested in the value, but would like to find a home for it. Falcon fans or collectors out there???
Thanks and regards,
Van
Remember: Real bikes have pedals.
...and never put a yellow tail on a Red, White and Blue kite!
Senior Ryder 00 is offline
Old 01-08-21, 05:08 PM
randyjawa
randyjawa's Avatar
Quoted: 1013 Post(s)
Liked 738 Times in 454 Posts
I think it is a Falcon Black Diamond, their entry level model, or close to it, in those days.
randyjawa is offline
Old 01-08-21, 05:28 PM
juvela
juvela's Avatar
Quoted: 2410 Post(s)
Liked 674 Times in 543 Posts
Hello Van and thank you for sharing this cycle.
1971 was the final year for this generation of the bicycle's Atom model 440 pedal so the bicycle is unlikely to be later
the Campagnolo Valentino gear ensemble launched about 1968 so that brackets a date in the other direction
the original wheelset was likely comprised of Normandy Sport large flange alloy quick release hubs paired with Weinmann alloy wired rims of size 27 X 1 1/4
level appears to be one up from the base
it is possible the frame may have a three-tube Reynolds 531 plain gauge tube set
there appears to be the residue of a frame tubing transfer at the top of the seat tube facing forward; it may have indicated such a tubeset
do not think it could be higher
it is an honest and worthwhile product - well worth doing a mechanical service on it
the Falcon marque evolved from an earlier entity called the Coventry Eagle
juvela is offline
Old 01-08-21, 09:24 PM
ramzilla
ramzilla's Avatar
Quoted: 675 Post(s)
Liked 258 Times in 205 Posts
Falcon bikes were a cut above their Raleigh cousins. Most all of them were built with high quality Reynolds 531 tubesets, That's a nice one. The only ding I've got against it is the cottered crankset with stamped chainwheels. Otherwise, that's one hell of a nice frame. Prices for Falcons are all over the place. But, that one is probably worth at least a couple of hundred dollars. Be good. Have fun.
ramzilla is offline
Old 01-09-21, 02:10 AM
randyjawa
randyjawa's Avatar
When I first commented on model, I suggested Black Diamond. I did not notice the rear drop which might be early Campagnolo. If so, then the bike is above the black diamond model.
Is the bike a worthy bike to restore? Yes, in my opinion. That is the sort of bike that I choose to restore (and ride) these days.
As for cottered crank sets - not the best for our modern world but more than serviceable and dependable. They are a wee bit difficult to remove and you need to know what to do to install properly but they are pretty and work just fine...
Old 01-10-21, 12:34 AM
juvela
juvela's Avatar
Hello once again Van,
checked with the Falcon catalogues available online and your cycle falls in a time gap between the available years
there is an undated one which looks to be mid-1960's and the next later one is 1973
your machine falls somewhere between these two
at this era the manufacturer offered four drop bar tenspeed models
top-of-the-line was model 76 which was an all Reynolds frame paired with an all Camapgnolo Nuovo Record road ensemble
next down was the model 94 which was the same frame paired with a less costly kitting
next down is the subject cycle which is termed a model 92 and has the three-tube Reynolds 531 frame
the base model of the range is the Black Diamond
juvela is offline
Old 01-12-21, 09:51 PM
Senior Ryder 00
Quoted: 124 Post(s)
juvela
randyjawa
Hl folks,
Thanks for all the great info on the Falcon. Further research indicates that it is a Model 92. The remnants of the Reynolds decal match the one used on bikes of that vintage have 531 straight gauge main triangle tubes. The seat post measures 26.4 which fits with that tubing. The things that are still strange to me are the crankset, Pivo stem and the handle bars. I pulled back the tape on the bars and found that they were poorly finished.
This is a big frame; ST = 24.5/62.5cm, TT = 23.5/60cm. Surprisingly, I was able to ride it with reasonable comfort with the short stem and only 1 of the seat post showing. I normally ride a 56cm square frame. I really like the style and workmanship on this bike, but need to find one in my size.
By-the-way, is anyone familiar with Terry top tube cable housing clips. These are neat, spring type clips that hold tight w/o screws. Pix attached.
Thanks again,
Van
