Seatpost sizes can be so frustrating
Old 02-21-21, 10:58 AM
b dub
CL Addict
b dub's Avatar
Bikes: '50s Leon Cattrysse - '72 Canadian Tire Company Supercycle - '74 Raleigh International - '83 Nishiki Cresta - '84 Centurion Turbo - '86 v. Herwerden (Chesini) - '87 Specialized Sirrus - '88 Trek 2000 - '92 Schwinn Paramount Series 30
Quoted: 41 Post(s)
Liked 36 Times in 26 Posts
I own bikes with many different seatpost sizes. I have a box of seatposts with various sizes. And I use one of these cheap but accurate digital calipers.
And yet Iím often having the hardest time to figure out the correct seatpost.
Example 1: 1983 Nishiki Cresta. According to most of what I read the correct size is 26.6 or 26.8 (I found reports of both).
But on my Nishiki I canít get a 26.6 post to fit and a 26.4 post fits like a glove.
Example 2: my Van Herwerden (Chesini) Columbus SL frame should fit a 27.2 post but I can only fit a 26.6 post.
And I find it impossible to measure the size on the inside of the down tube.
With both examples I donít believe anything is bend or forced.
Ok, I feel better now 😀
Happy Sunday!
b dub is online now
Old 02-21-21, 11:06 AM
genejockey
Klaatu..Verata..Necktie?
genejockey's Avatar
Bikes: Canyon Endurace, 105; Battaglin MAX, Chorus; Bianchi 928 Veloce; Ritchey Road Logic, Dura Ace; Cannondale R500 RX100, Schwinn Circuit, Sante
Quoted: 2028 Post(s)
Liked 2,005 Times in 1,031 Posts
It took me two Campy binder bolts to realize that my Battaglin needed a 27.4 post, not a 27.2. Luckily, I was able to find an American Classic seatpost in 27.4.
genejockey is offline
Likes For genejockey:
Old 02-21-21, 11:10 AM
plonz
plonz's Avatar
Quoted: 507 Post(s)
Liked 164 Times in 117 Posts
Totally normal experience. It’s hard to rely on stated seat tube spec from the internet. I have a few posts in the parts bin I know to be more accurate and use these as reference posts when buying a new one. Buying used is tricky since you’re still at the mercy of someone else’s measurement. All part of the C&V treasure hunt.
plonz is offline
Old 02-21-21, 11:11 AM
Mr. 66
Mr. 66's Avatar
Quoted: 482 Post(s)
Liked 347 Times in 249 Posts
It sounds like the clamps are a bit pinched. I'm using a Trek 400 that couldn't fit a 26.6-26.8, don't remember, when I bought it. The 400 is a 27.2 post, I did a slight pry and used a trashed steel 27.2 as a ream and with a tad of filing sharp areas, wazam 27.2 post no problem.
I think the 27.2 should happen on the Italian, the others I think should be 26.6
Mr. 66 is offline
Old 02-21-21, 12:12 PM
oneclick
Quoted: 349 Post(s)
Liked 336 Times in 216 Posts
You can get a cheap set of telescoping gauges for $15.
When checking the diameter of the hole, make sure the slot (if there is one) is not distorted; the top corners will be obvious, but sometimes the bottom of the slot can also be bent inwards a bit, and a post that almost goes in won't.
oneclick is offline
Old 02-21-21, 12:41 PM
wesmamyke
Quoted: 190 Post(s)
Liked 27 Times in 23 Posts
The Stein style seatpost sizing rods are really the most useful. They provide a bit more feel for how an actual post would fit.
I had an older set in chromed steel, not aluminum. Those were even better, maybe because they got rid of some of the friction. They had an oddysey sticker on the end, not sure if that's who made them.
wesmamyke is offline
Old 02-21-21, 12:44 PM
bikemig
bikemig's Avatar
Quoted: 4968 Post(s)
Liked 1,458 Times in 966 Posts
I just keep old seatposts around in the common sizes to check. I find this to be more accurate than calipers.
bikemig is offline
Likes For bikemig:
Old 02-21-21, 01:01 PM
DiegoFrogs
DiegoFrogs's Avatar
Bikes: '77 Centurion "Pro Tour"; '67 Carlton "The Flyer"; 1984 Ross MTB (in USA)
Quoted: 131 Post(s)
Liked 30 Times in 23 Posts
Posts at 25.4 mm aren't bad to have around. I've beer-can shimmed one to ~26.0 without trouble and used it that way for years.
I had another in my bin that I thought would fit my Ross MTB (Ishiwata 024 tubing, it turns out). I brought it on a trip from Europe to visit my family - turns out the bike took 27.0 mm, so was much higher quality than I thought! I rode it with the aluminum post + external clamp and returned the next trip with a Cane Creek shim, which was nicely done in aluminum for the price. I had thought the post would fit my Finnish Helkama city bike to replace the galvanized (!) post it came with, but it turned out to be 23.0 mm with a nicely done plastic shim to 25.0 mm. I probably should have just honed the tube out...
I also had a Canadian-made late '80s Peugeot with HLE tubing that took a 23.8 mm post (15/16"!). Luckily the clamp diameter was the conventional diameter, so I was able to reuse the post with a clamp that I got from an LBS for a couple bucks. That's a size that's not so easy to find.
DiegoFrogs is offline
Old 02-21-21, 02:18 PM
3alarmer
Beikforoom Bodhisattva
3alarmer's Avatar
Bikes: old ones
Quoted: 20616 Post(s)
Liked 3,663 Times in 2,689 Posts
...if I had kept on working at the bike co-op here, I was gonna make up a set of seat post sizing rods from all the old seat posts that came through there.
It really is the only way you can get a satisfactory feeling for the fit in a given situation. For myself, I just keep around a milk crate full of old posts in various sizes.
I know this is an inefficient use of resources, but none of them cost me very much to buy.
There is a tool you can buy to set to measure the interior of a tube, and I have a set of those.
They still do not work as well as having around a bunch of seat posts to try in the seat tube.
3alarmer is online now
Old 02-21-21, 02:22 PM
3alarmer
3alarmer's Avatar
Bikes: old ones
...the main problem with the Stein sizing rods is that they only give you a feeling for about an inch near the seat lug.
But if you have access to them, they are a good starting point. If you don't use them intelligently, you will often undersize the post you fit.
Old 02-21-21, 02:54 PM
b dub
CL Addict
b dub's Avatar
Quoted: 41 Post(s)
So if my Nishiki should be 26.6 what do I need to do to increase the size by 0.2 mm? Take a correctly sized old post (which I have) and hammer it in?
b dub is online now
Old 02-21-21, 03:10 PM
3alarmer
3alarmer's Avatar
Bikes: old ones
... not sure if serious, but nicely played. If you have a post that seems to fit, don't try to change the seat tube just based on someone's number on the internet somewhere.
But it's very possible that your seat lug has gotten distorted over the years by abuse and wrongly fitted seat posts. If that's the case, (and you can confirm by taking your caliper and taking a number of measurements of the clamp diameter at different points around the circumference...a distorted seat lug will show up as different diameter measurements), the proper remedy is reaming with an adjustable reamer. Pounding a seat post in with a hammer will only give you the additional issue of a stuck post.
Likes For 3alarmer:
Old 02-21-21, 03:21 PM
b dub
CL Addict
b dub's Avatar
Quoted: 41 Post(s)
Iím glad you got me. Rarely is taking up a hammer the solution to fixing a delicate bike related issue.
I will do some measuring but honestly the current post I have fits nicely. No slipping ever so I donít feel the need to mess with it.
b dub is online now
Old 02-21-21, 04:46 PM
Mr. 66
Mr. 66's Avatar
Quoted: 482 Post(s)
I used a wood shim to straiten the clamp slot on the seat cluster, then I tried ascending sized posts they all were floppy until 27.2. I used a trashed 27.2 to check for burrs and lightly filed at the pinched area of the clamp.
Mr. 66 is offline
Old 02-21-21, 05:29 PM
b dub
CL Addict
b dub's Avatar
Quoted: 41 Post(s)
This is the 26.4 post. Fits perfectly.
b dub is online now
Old 02-21-21, 06:56 PM
nlerner
Quoted: 2138 Post(s)
Liked 1,637 Times in 858 Posts
I’ve also found that posts are not always true to the labeled size. Most recent example is a brand new laprade-style post labeled 25.4mm for a low-end MTB I’m refurbing. Installed it, took a couple of rides, and realized it was rotating when I was looking over my shoulder. Got out the dial calipers, which show the diameter as 25.2mm. Great.
nlerner is offline
Old 02-21-21, 08:41 PM
ramzilla
ramzilla's Avatar
Quoted: 676 Post(s)
Liked 259 Times in 206 Posts
The only question I have is this: Why do so many old bikes that I bring home have missing seat posts? Who is taking these old seat posts? Why are they taking these seat posts? Why, why, why******************************??
ramzilla is offline
Old 02-22-21, 01:28 AM
SurferRosa
SeŮor Member
SurferRosa's Avatar
Quoted: 1635 Post(s)
Liked 1,668 Times in 948 Posts
the proper remedy is reaming.
When is it not, though?
SurferRosa is offline
Likes For SurferRosa:
Old 02-22-21, 01:32 AM
Darth Lefty
Disco Infiltrator
Darth Lefty's Avatar
Quoted: 2267 Post(s)
Liked 941 Times in 621 Posts
Would you believe someone over on MTBR lately started a thread to complain how there are THREE seat post sizes?
Genesis 49:16-17
Darth Lefty is offline
Old 02-22-21, 02:53 AM
oneclick
Quoted: 349 Post(s)
Well, it may often not be.
Consider: the tube starts out straight, presumably the lug does so also, and the framebuilder does a proper job.
If any of the metal later on is not where it started, it's been bent. If steel, the best solution might well be to bend it back - not to cut away the parts you don't like.
And reaming is not without risks; recently there was posted a picture of a frame which had a seat-tube that had rusted through - but in an odd way; you could see that the tube had been reamed slightly off axis and at the bottom of the cut the tube wall was paper thin on one side and full thickness on the other. I bet neither the owner nor the worker noticed. Until later.
oneclick is offline
Old 02-22-21, 06:08 AM
DoubleClanger
Quoted: 8 Post(s)
Try Sheldon Brown. Comprehensive tables of seat post sizes and manufacturer's seat post/down tube sizes.
I found them very useful trying to pi down my 1968 Holdsworth Mistral. Previous owner had a Campa 26.4mm in a 27mm downtube!
Take nothing for granted with pre-owned bikes..
Hope this helps.
DoubleClanger is offline
Old 02-22-21, 09:00 AM
Mr. 66
Mr. 66's Avatar
Quoted: 482 Post(s)
It does look in the picture of the slot that the post has zigzag scratching. It maybe caused by the post sized used. I would use a fine semi circular/flat file the next time you need to service, or if the bugs of concern get to you.
This may be a point of, if it ain't broke don't fix it.
Mr. 66 is offline
Old 02-22-21, 09:17 AM
Charliekeet
Bikes: S-Works Stumpjumper HT Disc, Fuji Absolute, '85 Cannondale SR900, Marin Hawk Hill SE, Giant OCR1
Quoted: 163 Post(s)
Liked 133 Times in 86 Posts
I have that same seatpost - it's been sitting in a box for years I look at it once in a while and decide to keep it in case I ever luck into a vintage Klein, or a Trek 170!
Charliekeet is offline
Old 02-22-21, 12:25 PM
Splendidtutiona
Bikes: '73 Raleigh Competition, Guru Sidero, Soma Groove, Smolenski,
Quoted: 13 Post(s)
Liked 13 Times in 7 Posts
Hope this helps.
Good resource, but be careful, It had my '73 Raleigh Competition labeled as 27.0 seat post. It's a 27.2. I had a 27.2 laying around and should have checked. I guess I have an extra 27.0 Campy seat post if I ever need it...
Splendidtutiona is offline
Old 02-22-21, 12:40 PM
Germany_chris
Germany_chris's Avatar
Quoted: 202 Post(s)
Liked 307 Times in 160 Posts
Let's not talk about the 5 seat posts I bought to find out I needed a 26.6 probably because I didn't know 26.6 existed until last spring then finding a quality post was yet another joy.
Germany_chris is offline
