Tubus Lowerider install
Old 02-28-21, 07:17 AM
sloar
Bikes: they change so much I'm tired of updating this
Quoted: 1212 Post(s)
Liked 1,127 Times in 427 Posts
Doe this look angled too much? Not really sure how to get it level. Thanks
Semper fi
sloar is offline
Old 02-28-21, 07:18 AM
sloar
Other than being sideways.
Semper fi
sloar is offline
Old 02-28-21, 08:06 AM
djb
Quoted: 2736 Post(s)
Liked 970 Times in 793 Posts
get yourself a bunch of spacers and experiment and use the front mounting part to mount rack to fork. Spacer use is generally ok strength wise, I've used them without issues on a few bikes.
You should be able to find some images of this rack on LHT's online to give you the idea.
djb is offline
Old 02-28-21, 08:19 AM
BobG
Quoted: 318 Post(s)
Liked 117 Times in 82 Posts
Better now?
BobG is offline
Old 02-28-21, 08:26 AM
djb
now I see the problem, someone has thrown a spanner in the works.
djb is offline
Old 02-28-21, 09:01 AM
elcruxio
elcruxio's Avatar
Bikes: 2011 Specialized crux comp, 2013 Specialized Rockhopper Pro
Quoted: 862 Post(s)
Liked 336 Times in 223 Posts
Yea you've apparently used the wrong mounting point in the rack. You're supposed to use the front two holes to attach rack to fork and the triangular rear mount is used for fenders. Why is the rear mount used for fenders? Well on top of using the front mounting holes on the rack you're supposed to attach the rack on the rear fork eyelet and that blocks it from fender use.
Of course how it's supposed to be done doesn't really matter all that much and there's room for personal preference. But to get the horizontal bar level usually requires one to attach the rack front mount to the fork rear eyelet
elcruxio is offline
Likes For elcruxio:
Old 02-28-21, 09:16 AM
sloar
Thank you, much better now.
Semper fi
sloar is offline
Likes For sloar:
