Rust around bottom bracket
CL Addict
Bikes: '50s Leon Cattrysse - late 50s Raleigh Lenton Sports - 1960/61 Raleigh Lenton Grand Prix - '72 Canadian Tire Company Supercycle - '74 Raleigh International - '83 Nishiki Cresta - '84 Centurion Turbo - '86 v. Herwerden (Chesini) - '87 Specialized Sirr
Quoted: 85 Post(s)
Liked 96 Times
I’ve been cleaning up this 1983 Nishiki Cresta.
pictures before.
I have soaked the entire frame in Evapo rust for about a day and a half.
Then I dipped just the bottom bracket in a smaller bucket with the Evapo rust for one more night.
This is what it looks now.
What should I do next? I’m not too concerned about the paint since this area will be mostly covered up by the crank. Carefully sand it? What should I apply on the exposed spots?
pictures before.
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,181 Times
^^^^ It looks like just flaking paint...I would sand off the flaking paint, primer and find a spray color at an automotive parts store and spray away.
Best, Ben
Best, Ben
Voltaire
Voltaire
CL Addict
Quoted: 85 Post(s)
Liked 96 Times
Quoted: 1372 Post(s)
Liked 1,751 Times
Were I faced with the situation, I would clean/sand the offending areas and then apply nail polish in as close a match as I could find(brush is included in the polish bottle). That should do a bit to satisfy the eye and to protect against oxidation.
There are times, of course, when more attention should be paid, not just to the outside, but also to the inside...
Quoted: 331 Post(s)
Liked 332 Times
Remove flakes first
You should wire brush all the loose paint / rust off before you apply evaporust. If left too long evaporust will attack the paint. Follow the instructions on the tin. Many suppliers claim a primer isn't needed but I seriously have doubts about that.
Bikes: Numerous
Quoted: 1678 Post(s)
Liked 3,097 Times
I, too, would have removed the bubbled chipped paint before the evaporust treatment. At this point though, it still looks good, and just finish the job as recommended above. This is a great example for people who are afraid of buying a steel bike because it will apparently rust away to dust. Your bike is 38 years old and has many years of good life in front of it. I like the bath tub!
CL Addict
Quoted: 85 Post(s)
Liked 96 Times
I will remove the flakes, sand it, then just dip it in Evapo rust again.
Bikes: 1972 Fuji The Finest | 1990 Bianchi Giro | 1999 LeMond Buenos Aires
Quoted: 151 Post(s)
Liked 303 Times
If you don't care about color match, I used some black rust reformer primer. I could only find in spray, so I sprayed into a small glass jar to use for brushing on. Seemed to work ok, put on several light coats then sanded after a couple days drying time. Took the sanding like a champ. Then I top coated with some Duplicolor lacquer touch up paint that was a close match, but that stuff already flaked/chipped in spots as others have experienced too.
CL Addict
Quoted: 85 Post(s)
Liked 96 Times
Good plan. After a few hours soak, remove and maybe scrub with like a nylon brush to remove any loose black Evaporust stuff. I found I needed multiple soaks/treatments for some pitting, as the black surface coating seemed to slow/stop the reaction and it didn't really remove all the rust. I soaked overnight on each tube and found the remaining rust pits when I was done soaking. At that point I just used Naval Jelly in several applications to get the rest off.
