Rust prevention: A test of popular treatments
Old 10-19-09, 04:41 PM
miamijim
miamijim's Avatar
Quoted: 373 Post(s)
Liked 31 Times in 27 Posts
Sectioned off, and treaded equaly. From left to right:
Synthetic car oil
WD40
Corrosion Block
Boeshield
Liquid Wrench penetrating oil
Loctite Extend Rust Neutrilizer
miamijim is offline
Old 10-19-09, 05:22 PM
Grand Bois
Grand Bois's Avatar
Quoted: 436 Post(s)
Liked 8 Times in 8 Posts
Interesting! I wish you would have included boiled linseed oil.
Grand Bois is offline
Old 10-19-09, 05:24 PM
miamijim
miamijim's Avatar
Quoted: 373 Post(s)
I could do another test. Why boiled?
miamijim is offline
Old 10-19-09, 05:31 PM
unworthy1
Stop reading my posts!
unworthy1's Avatar
Quoted: 732 Post(s)
Liked 305 Times in 251 Posts
boiled linseed oil catalyzes in wood to form a harder resin...but on metal? Some people used it on farm equip and hand tools.
I'd like to see FrameSaver.
unworthy1 is offline
Old 10-19-09, 05:41 PM
southpawboston
southpawboston's Avatar
Quoted: 60 Post(s)
Liked 107 Times in 52 Posts
+1 to testing framesaver. i was thinking of doing a similar test, thanks for doing it!!!
how, and for how long, did you expose the treated metal? did you spray it with water daily or something like that?
excellent experiment! (and speaking of experiments, the scientist in me has to point out that the best "negative" control would have been a section of untreated metal).
southpawboston is offline
Old 10-19-09, 06:01 PM
miamijim
miamijim's Avatar
Quoted: 373 Post(s)
I sprayed each test material onto a paper towel and then wiped the metal down. For exposure I left it on the ground in front of my garage door. Exposure time was ~3 weeks.
I'll try to find some FrameSaver localy.
miamijim is offline
Old 10-19-09, 06:15 PM
c.miller64
c.miller64's Avatar
Bikes: Cannondale Six13 Pro, Cannondale Synapse, Felt IA10
Quoted: 33 Post(s)
Liked 3 Times in 1 Post
Synthetic car oil
WD40
Corrosion Block
Boeshield
If you can find some, give CorrosionX a try.
c.miller64 is offline
Old 10-19-09, 06:30 PM
Grand Bois
Grand Bois's Avatar
Quoted: 436 Post(s)
Boiled linseed oil has additives that make it dry faster. It's not actually boiled. I used it on one frame. It appeared to be working the last time I looked. It was suggested by a very old bike mechanic.
Old 10-19-09, 06:49 PM
awc380
I thought the boiled linseed oil was less likely to spontaneously combust or something...
awc380 is offline
Old 10-19-09, 06:54 PM
Shimagnolo
Shimagnolo's Avatar
Quoted: 2402 Post(s)
Liked 2,044 Times in 1,051 Posts
It may, or may not, be boiled:
https://en.wikipedia.org/wiki/Linseed...ed_linseed_oil
Shimagnolo is offline
Old 10-19-09, 07:04 PM
Sci-Fi
Sci-Fi's Avatar
Quoted: 16 Post(s)
Add Mystic JT6 grease (green tube) to the test.
Which Corrosion Block did you use? Lear, PCT? PCT is good stuff.
Sci-Fi is offline
Old 10-19-09, 07:30 PM
miamijim
miamijim's Avatar
Quoted: 373 Post(s)
No grease as the test products need to be liquid. Lear Corrosion Block:
https://learchem.com/C.B.Page.htm
miamijim is offline
Old 10-19-09, 08:01 PM
Loose Chain
Loose Chain's Avatar
Bikes: 84 Pinarello Trevisio, 86 Guerciotti SLX, 96 Specialized Stumpjumper, 2010 Surly Cross Check, 88 Centurion Prestige, 73 Raleigh Sports, GT Force, Bridgestone MB4
Quoted: 278 Post(s)
Liked 69 Times in 54 Posts
Linseed oil is what we use in 4130 welded tube aircraft frames.
I would think that LPS3 would do well. I think Corrosion X might do well. Don't know what Frame Saver is.
Loose Chain is offline
Old 10-19-09, 08:21 PM
Shimagnolo
Shimagnolo's Avatar
"JP Weigle's Frame Saver", aka "Cosmoline".
Old 10-19-09, 10:41 PM
Jasmijo
Jasmijo's Avatar
Bikes: 2009 Jamis Sputnik, a couple of old mixtes
Cool experiment! Thanks for doing this and sharing your results! I'm going to try to ride through Chicago's wet/salty/slushy/snowy winter this year and I've been a bit worried about how the salt and water are going to just wreck my winter bike. I'll have to pick up some corrosion block to periodically treat my bike with.
Jasmijo is offline
Old 10-19-09, 10:46 PM
mkeller234
Rustbelt Rider
mkeller234's Avatar
Quoted: 207 Post(s)
Liked 213 Times in 101 Posts
+1, thank you for posting this. The only problem I see with testing framesaver is that it is applied differently than the tested products.
mkeller234 is offline
Old 10-20-09, 12:19 AM
bitt3n
Quoted: 5 Post(s)
it looks like the best anti-rust agent is blue masking tape.
bitt3n is offline
Old 10-20-09, 02:57 AM
mtnbke
Bikes: '92 22" Cannondale M2000, '92 Cannondale R1000 Tandem, another modern Canndondale tandem, Two Holy Grail '86 Cannondale ST800s 27" (68.5cm) Touring bike w/Superbe Pro components and Phil Wood hubs. A bunch of other 27" ST frames & bikes.
Quoted: 109 Post(s)
I don't like steel bikes (too wriggly), but I will say that boiled linseed oil is amazing stuff...
In the Jeepin' community its a staple. You use a power sprayer and completely spray down the underside of your car (using butchers paper and painters tape to mask off and protect the paint near the wheelwels, rockers, and front and rear bumpers).
Its miracle stuff. Even when you drag a differential over a rock the linseed oil stays mastic enough that it just kind of oozes back over the parts that got scratched/scraped.
Some people use linseed oil as spokeprep for the same reason.
mtnbke is offline
Old 10-20-09, 04:13 AM
filtersweep
filtersweep's Avatar
Then you have never ridden a real steel bike.
filtersweep is offline
Old 10-20-09, 05:31 AM
Grand Bois
Grand Bois's Avatar
Quoted: 436 Post(s)
Boiled linseed oil
Boiled linseed oil is used as a paint binder or as a wood finish on its own. Heating the oil causes it to polymerize and oxidize, effectively making it thicker and shortening its drying time. Today most products labeled as "boiled linseed oil" are a combination of raw linseed oil, petroleum-based solvent and metallic dryers. The use of metallic dryers makes boiled linseed oil inedible. There are some products available that contain only heat-treated linseed oil, without exposure to oxygen. Heat treated linseed oil is thicker and dries very slowly. This grade of linseed oil is usually labeled as "polymerized" or "stand" oil, though some types may still be labeled as "boiled."
Old 10-20-09, 08:55 AM
southpawboston
Quoted: 60 Post(s)
i'm intrigued about linseed oil as an alternative to framesaver.
i wonder if it would be possible to spray linseed oil onto the insides of the frame tubes in the same manner that framesaver is applied? can you buy inexpensive disposable paint sprayers with long wands for this type of application?
Old 10-20-09, 09:36 AM
weareoxygen
Free Rider
weareoxygen's Avatar
Bikes: 1960's Schwinn Road
I've heard that SOS pads work pretty good for getting rust off. has anyone ever tried it? it seems to me that it would scratch it up pretty bad.
weareoxygen is offline
Old 10-20-09, 10:24 AM
miamijim
miamijim's Avatar
Quoted: 373 Post(s)
Yes, inexpensive canisters can be bought.
It works well, the amount of scratching is relative to the grade of steel wool, how well and what its lubricated with and the amount of pressure applied.
Originally Posted by Bob Barker View Post
The Loctite Extend Rust Neutralizer, if it's the same stuff as the Duro of the same name, states on the packaging (or used to) that it's not for bare metal, that it only works to neutralize/convert existing rust. Interesting to see an actual test, though. Thanks
You are correct. I thought it would be an interesting test regardless of the inteneted/improper application.
miamijim is offline
Old 10-20-09, 12:40 PM
Grand Bois
Grand Bois's Avatar
Quoted: 436 Post(s)
Linseed oil can be thinned with mineral spirits for spraying. I put thinned linseed oil in a Ronson Lighter fluid container for application through the vent holes. It turned the frame around in all directions to distribute the oil inside the tubes. I ruined a pair of jeans and a t-shirt and even had it in my hair by the time I finished.
Old 10-20-09, 02:10 PM
unworthy1
unworthy1's Avatar
Quoted: 732 Post(s)
the main property of B.L.O. is that it's CHEAP, so if you are shooting an entire underside of a truck that's important, ditto if you're a mfg of coatings and want a cheap extender. For smaller areas (frame tubes) I think cheap is not nearly as important as effective, and I have believed that Wiegle's Framesaver is superior (but a scientific test would be telling). By the time I bought the re-useable aerosol and loaded/charged it, I'd want to be spraying the best fluid I could buy, not the cheapest.
