Wolftooth Roadlink experiences?
Old 06-07-17, 08:49 AM
Jarrett2
Jarrett2's Avatar
Bikes: Steel 1x's
Quoted: 632 Post(s)
Liked 3 Times in 3 Posts
Originally Posted by TimothyH
Based on what you wrote however, I still don't see how the Wolf Tooth was the root or exclusive cause of the dropped chain.
Originally Posted by mstateglfr
I have seen a few 1x setups using the Roadlink(they werent in use, but itd be dumb to have it if it didnt work).
Originally Posted by redlude97
Shimano still doesn;t have a proper clutch RD yet plenty run them without chain drops.
YMMV. If it works for you,
Jarrett2 is offline
Old 06-07-17, 09:39 AM
TimothyH
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times in 469 Posts
Again, my guess is that whomever set up the bike did something wrong or that the bike was experiencing the issues inherent to 1x designs.
Wolf Tooth Components explains their own 1x setups and even use them with short cage derailluers.
https://www.wolftoothcomponents.com/...x-gravel-setup
TimothyH is offline
Old 06-11-17, 11:37 PM
Zurichman2
Quoted: 148 Post(s)
Liked 6 Times in 4 Posts
I bought a 2016 Raleigh Tamland 1 on advice of the Corporate discount here. So I bought the bike for $799 + $48 tax. The bike was shipped direct to me from Raleigh. My LBS wanted $1300 for the same bike. I put the bike together sans the front disk caliper as I didn't know how to do that. I took it to my LBS and he finished putting it together for $75. I then went out and climbed my local mt with it which had a 3 mile climb at 7% grade. I thought I was going to die. I then went to another LBS and he put on a 11 x 36 Sram cassette with the road link and a new chain. I then went out and rode the same mt and oh what a difference. Works for me. I did notice that when I did the first test ride that the shifting did seem to jump more/clacking noise and didn's seem as smooth as shifting as the stock 11 x 32 shifting. The LBS did some adjusting and it rides as smooth now as the stock set up.
Zman
Zurichman2 is offline
Old 06-16-17, 01:35 PM
cellery
cellery's Avatar
Quoted: 59 Post(s)
Liked 31 Times in 12 Posts
To be honest, I find the road link concept to be kind of pointless, unless it's just to save $50-$70. Wolftooth also makes the Tanpan, which allows you to pair your shimano road shifters with a shimano mtb shadow+ clutch rear derailleur. Thereby eliminating a lot of the 'slop' aka chain slap you'll get by running a wide range with a standard road derailleur. It's so much better on gravel (and worth saving your frame from chain impacts) that to me it's a no brainer on price.
cellery is offline
Old 06-16-17, 01:40 PM
cellery
cellery's Avatar
Quoted: 59 Post(s)
Originally Posted by Jarrett2
A friend of mine had one installed (unknown to her) by a LBS to accommodate a larger cassette on her 1x setup. It started dropping chains immediately.
I replaced her DR and that thing with a SRAM Apex1 DR and all good since.
This goes back to improper rear derailleur setup (usually b-tension) and establishing correct chainline at the front ring - no more complicated than that. If you hack together a 1X on a bike that was previously running a 2x, then getting the adjustment right is like an art, and no bike shop is going to get it perfect just by a quick tinker. I've been running the wolftooth stuff for ages and never had an issue once it was adjusted correctly.
cellery is offline
Old 06-23-17, 09:37 PM
XXLHardrock
Bikes: Some old CL beater
Quoted: 40 Post(s)
Liked 12 Times in 7 Posts
I'm using a Road Link on my road bike with a 12-40 cassette and 50/34 up front and it works just as intended.
The device does not make up for lack of capacity of the 105 GS but does put the RD in a position to shift onto the 40 tooth cog. I just can't shift a 50/40 combo.
XXLHardrock is offline
Old 06-25-17, 09:15 AM
BluesDawg
just keep riding
BluesDawg's Avatar
Quoted: 173 Post(s)
Liked 33 Times in 22 Posts
If I'm reading this right, aside from the total chain wrap capacity, you are saying your chain is not long enough to safely shift to the 50/40 combination. I would always cut the chain long enough to accommodate the big/big combination and sacrifice the small/small combination because of the chain wrap limitation.
Neither combination is advisable, but the likelihood of forgetting not to use the big/big combo is much greater and the consequences can be a long walk home followed by an expensive repair. I generally never come anywhere close to using my small/small combination anyway. YMMV.
BluesDawg is offline
Old 06-26-17, 06:48 AM
BNB
BNB's Avatar
Bikes: road, mtb, tandem, gravel, tt
Quoted: 116 Post(s)
Liked 14 Times in 11 Posts
I've put the Road Link on our tandem in order to use an 11-36 cassette with the etap wifli derailleur and it works great. I now want to put it on my gravel bike with the same wifli derailleur but I'd like to get an 11-40 cassette. That's over the spec by wolftooth but I'd like to know if anyone has done this successfully (or not).
BNB is offline
Old 06-26-17, 07:41 AM
TimothyH
- Soli Deo Gloria -
Tinkering: Attempting the ?Impossible? | Gravel Cyclist: The Gravel Cycling Experience
Tinkering: Attempting the ?Impossible? Part 2 ? Lindarets RoadLink Review | Gravel Cyclist: The Gravel Cycling Experience
Note that Lindaretes = Wolf Tooth.
-Tim-
TimothyH is offline
Old 06-26-17, 08:19 AM
unterhausen
Randomhead
Liked 3,697 Times in 2,518 Posts
1x on the cheap suggests no narrow-wide chainring, which would have helped a lot for chain drops. I tried 1x before the advent of narrow-wide, you really need something to keep the chain on. It _usually_ works without, but always falls out at the most inconvenient time. I keep looking at doing 1x on my gravel bikes, and I am not able to get the gearing to work.
I pretty much just stick with SRAM 10 speed because you can use mountain derailleurs with road shifters. Not sure how long that is going to work now that they have messed it up for 11 speed.
unterhausen is offline
Old 06-26-17, 09:23 AM
BluesDawg
just keep riding
BluesDawg's Avatar
Quoted: 173 Post(s)
Note that Wolftooth does recommend considering a chain guide for some applications to ensure the chain stays on.
"Due to the lack of a clutch mechanism on Shimano road derailleurs, secondary chain retention (front derailleur or chain device) may be needed, especially for rough or off-road use."
SRAM 10 speed MTB rear derailleurs work perfectly with SRAM 11 speed road shifters. Both are Exact Actuation, unlike the 11 speed MTB which are X-Actuation.
Old 06-26-17, 02:22 PM
BNB
BNB's Avatar
Quoted: 116 Post(s)
Thanks! Looks like I'd need to order a 46 chainring too. Makes sense and I've already learned the cross-chaining happens; usually while oxygen deprived ...
BNB is offline
Old 06-27-17, 02:19 PM
TimothyH
- Soli Deo Gloria -
LoL.
-Tim-
TimothyH is offline
Old 06-27-17, 05:03 PM
redlude97
Quoted: 1975 Post(s)
Liked 232 Times in 173 Posts
a FD as a chain guide is usually a <$5 solution, which is not used most of the time because of vanity IME
redlude97 is offline
Old 04-18-18, 04:41 AM
darrenh83
Found a post on riding gravel - it sums up my issues exactly. I've had a couple of scary descents with a dropped chain (scratched the hell out of the cranks) and just yesterday managed to get the lower pulley wedged with the chain when it dropped. I'm taking the punt on the roadlink in hope that less B screw adjustment will give more chain tension. Thoughts? Silly idea?
ridinggravel.forumchitchat.com/post/installed-roadlink-having-issues-8117461
I only installed it to give me a little more chain tension as the chain has been dropping off the bottom of the chainring on bumpy roads. Regardless, when I installed the RoadLink, it really didn't change anything as far as shifting or hitting, or losing, any gears.
So my problem is dropping chains - I think mostly because of a lack of spring tension on the RD.
darrenh83 is offline
Old 04-18-18, 08:57 AM
redlude97
you could try to increase tension by moving the cage pulley, i did that for awhile on a 1x shimano setup
https://www.parktool.com/blog/repair...icle-section-3
Old 04-22-18, 07:30 PM
darrenh83
Thanks - that'll be plan B for sure.
For now I've wound the B screw back a few turns as there's still clearance - I've only got a 32
overhaul#article-section-3[/url]
Old 04-23-18, 11:43 AM
scotch
purity of essence
scotch's Avatar
Bikes: 2018 Giant Trance 2, 2019 Trek Farley 7, 2017 Jamis Renegade Exploit
Quoted: 37 Post(s)
Liked 26 Times in 11 Posts
My LBS installed a Deore XT 11-40 on my Jamis Exploit (50/34 up front). All it required was the Road Link ($20) and a slightly longer chain. Pulls through all gears, including big/big (not that you'd wanna do that). Shifting is pretty spot on.
scotch is offline
Old 04-23-18, 01:03 PM
TimothyH
- Soli Deo Gloria -
^^ That's crazy right there. I love it.
You are going to surprise a lot of guys when you spin up a wall while seated.
What is it in gear inches?
Hot. 10/10. Would ride.
TimothyH is offline
Old 04-23-18, 05:50 PM
mstateglfr
Sunshine
mstateglfr's Avatar
Quoted: 10963 Post(s)
Liked 7,490 Times in 4,189 Posts
I have often wondered where the weight of a larger cassette plus compact crank is heavier than a subcompact crank and smaller cassette.
Also, where the cost of a larger cassette and compact crank is compared to a subcompact crank and smaller cassette.
Thats impressive for sure- i have the roadlink shifting an 11-36 and its apparently not even close to its limit looking at that!
mstateglfr is offline
Old 04-24-18, 07:30 AM
carlton
Bikes: canondale silk trail--92 schwinn criss cross--sun atlas x type--fugi odessa--2018 trek domane ALR5 disc
Quoted: 47 Post(s)
Not my bike but with 700x38 tires and 175 cranks it would be 23" on the bottom, 124" on the top. 11-32 would be 29" low, 124" high.
carlton is offline
Old 04-24-18, 11:45 AM
redlude97
What RD? I've gotten 6800 and 8000 medium cages to work with an 11-36 without a road link
Old 04-24-18, 03:37 PM
mstateglfr
Sunshine
mstateglfr's Avatar
I have one connected to a 5800rd.
Old 04-24-18, 06:00 PM
redlude97
Medium cage? Did you attempt without the roadlink first? I've found and others that shimano is very conservative of max cog size, usually at least 4T
Old 04-24-18, 08:13 PM
mstateglfr
Sunshine
mstateglfr's Avatar
Yeah its a GS model. Couldnt clear the 36t cog. Ive read it sometimes matters how the frame geometry is, whether a too large RD fits or not.
Im thinking about upgrading to the new Ultegra with clutch. Its made to fit 34 so mine should work without the roadlink, and itll reduce possible chainslap.
Downside is the look, but whatever i guess.
