Likes For Mr. 66:
#1977
Quoted: 823 Post(s)
Liked 1,395 Times
I didn’t feel like paying that much for the Dos Eno either, so I scored a deal on a used one. SS is a different animal from fixed and from derailleur geared bikes, too. I will have to adjust to it, I think. That said, it manages to feel like a reliable and durable piece of equipment while still feeling light. I have an associate who has ridden a standard White Industries freewheel for many years who loves his. The sealed bearing construction and the general quality of this unit far outstrips the usual Shimano units I’ve experimented with in the past. I like it and think it will work for a long time.
#1978
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3870 Post(s)
Liked 6,461 Times
Route the front brake cable all the way under the bar tape like you've done with the rear. Route the rear cable outside (in front of) the front cable, then on around the non-drive side of the head tube, then back under the top tube to its cable stop. It still won't be "perfect," but it will be a lot better looking. I've done something similar with my Paramount.
And make sure you have the stem height exactly where you want it before beginning.
Good looking frame. Congrats on the new wheelset plan.
#1979
Quoted: 767 Post(s)
Liked 1,898 Times
Had this light knocking around for a while. It came with another bike I bought, and I've been using it as a household flashlight. It's bright enough for me to be seen, so I set out to mount it on my Peugeot wet weather utility bike. The Soma Lucas Mini rack has these nice mounting points.
So I took a chunk off of a piece of aluminum bar stock, drilled it, and threaded it for a 6 x 1mm bolt.
So hot today, I spent about 30 minutes in the garage and sweat right through my t-shirt. But, I've successfully bolted more stuff to the old beater, and will hopefully stand out that much more when I need to.
#1980
Hump, what hump?
Bikes: See signature
Quoted: 337 Post(s)
Liked 227 Times
Flushed and rejuvenated a RX100 STI today. It helps to flush from the bottom.
#1981
Quoted: 7346 Post(s)
Liked 2,452 Times
How long did that take? I did it a few years ago. It took a few weeks and repeated flushes. But it worked.
#1982
Hump, what hump?
Quoted: 337 Post(s)
Liked 227 Times
I honestly thought it was toast.
#1983
Quoted: 339 Post(s)
Liked 631 Times
Here is a 1986 Fuji Sundance I found in the back room at the Bike Exchange as a frame/ fork. It was the first year that Fuji made mountain bikes and I think it's a classic.
I did my usual clean and clear coat of the frame. The paint was very good for a 33 year old bike with few scratches and very little fading.
Rubbing out the paint with white polishing compound does wonders for the finish, removing ground in dirt and lots of scratches and other marks.
I kept the 3 x 6 gearing of the original. I found a set of bull moose bars in the bin and some 1.75 x 26 tires to further stay with the original specs. The cranks are Sugino SA with steel chain rings and should be bomb proof. The freewheel is a Shimano hyperglide and I used old Shimano thumbies as I couldn't get any Suntour thumb shifters. It has the original front derailleur and a Mountain LX rear.
Altogether a pretty sweet ride. It should sell quickly at the shop.
#1984
Bikes: '72 Fuji Newest, '79 Fuji Royale Gravel Grinder; '84 Schwinn High Sierra BMX Cruiser; '97 Huffy Tremor BMX
Quoted: 33 Post(s)
Liked 134 Times
#1985
Liked 2,452 Times
I have made progress on my gravel bike, a 1971 Raleigh Super Course. I have a tall Technomic stem and mustache handlebars. It will have fenders and dynamo lighting.
#1986
Quoted: 823 Post(s)
Liked 1,395 Times
I have been working on this 1973 Raleigh Competition, which involved scrubbing away decades worth of dirt, treating frame and fork with Evapo-Rust and bronze-brushing the rust and loose chrome from the fork. When that was done, I had about 25% chrome remaining, so I broke out the gloss black Rustoleum and covered the ruined areas while transitioning to the original dipped-looking black. Some J.P. Weigle's framesaver, some careful spot sanding of rust, some Meguiar's polish and the last of a bottle of Armor All paint protectant spray and I got the finish looking about as well as it's gonna look. I had to spread the seat lug back out to its proper shape, then buy and use a brake cylinder hone to clean out the corrosion inside the seat tube before the 27.2 mm post fit correctly. I lost some of the original tiny loose balls in the headset, but discovered the caged bearings left over from the top half of a cheap Tange fit the upper race of the T.D. Cross headset like they were made for it, so I used that up top with the original small bearings in the lower race. The T.A. bottom bracket cleaned up beautifully, too, and after comparing its spindle to a Nervar unit, I think I can use this as-is with a set of Nervar Star cranks and get the chainline I seek.
Likes For rustystrings61:
#1987
Liked 2,452 Times
I volunteer at the bike coop on Monday evenings. Yesterday, the forecast called for heavy thunderstorms. I wanted to minimize my getting-wet-ness, and my Raleigh International, my only bike with fenders, has a bum wheel I've been meaning to replace. I realized that since I've put 650b wheels on my Lemond, I have spare 700c wheels. I took the rear from the Lemond and put it on the Raleigh. The Lemond had Campagnolo wheels, so the indexed shifting shouldn't work. But hey, it works.
#1988
ambulatory senior
Quoted: 1954 Post(s)
Liked 3,658 Times
#1989
Liked 2,452 Times
Yes, it's a 3x10 drivetrain. I'm not sure the left brifter is really meant to shift a triple, but I made it work. The brifters are 105, the front derailleur is Ultegra, and the rear derailleur is Sora. The rear hub is currently a Campagnolo Record, originally 9-speed, and it's a Miche 10-speed cassette. How's that for a hodgepodge?
#1990
Quoted: 4510 Post(s)
Liked 6,374 Times
Likes For merziac:
#1991
Eccentric Old Man
Quoted: 248 Post(s)
Liked 173 Times
Evidence based around here!
#1992
The 197x (really I have no idea what exact year it's from) Chiorda Mixte. Anyone who keeps tabs on the "Your Catch of the Day" topic may recall seeing me post this poor abused bike rescue two weekends ago. I couldn't resist making this bike my #1 priority to refurbish, because let's face it, it would be embarrassing for a bike that looked like this to be seen in your yard wouldn't it? And I kinda felt sorry for it. But what a disaster it has been to work on. Below is how the bike looked when I bought it two Saturday's ago.
So far I've removed the poorly matched rear rack, the saddle and seatpost, both wheels, the handle bars, the brake calipers, and the peculiar Simplex rear derailleur (more on that later). Scrubbed the ancient blue spray paint off of the frame elements with a wire brush that were never meant to have paint on them. Scrubbed the blue spray paint off of the brake calibers, derailleur, hubs, spokes, rims, handlebars, cassette, crank arms, pedals, chain (Yes, some idiot painted the chain even!). The previous owner informed me, and all evidence seemed to validate, that the bike was already blue when they bought it, they replaced the tires, tubes, rim strips, brake pads, gear shift cable and housing, and rear brake cable and housing. The cables were easy enough to visibly see looked new, and lacked any blue paint. I had to strip the tires from the wheels regardless to first scrub the blue paint, and then to wire brush as much rust off as possible, was them, dry them, and finally hit them with a RustOleam Clear Coat, which gave provided the chance to validate the condition of the inner tubes and rim strips, which were all fine thankfully. While putting the rear wheel back on the bike though I noticed something was really odd looking about the Simplex derailleur scrubbing away blobs of dried grease discovered that one jockey wheel had no teeth left and the other had only about a third of its' teeth remaining... just great.
So next on the agenda is the removal of the headset as it rather consistently feels like it has a bad bearing when the handlebar is turned. And yes, the fork has been rotated a hundred and eighty degrees back to normality. Presently taking a break from this project as the new jockey sprockets are on order from overseas and not likely to show up for at least two weeks. Since had to order those, well, I figured "why not" and also ordered a new seatpost tube, as the one it came with, which I presume is original to the bike is all of about six inched long... which basically only gives the rider about two inches of safe height adjustment variance, how dreadful. And since I ordered a new, more normal modern length seatpost I figured, well why not a quick release skewer for the seatpost too?
All in all, I think this bike, even with a blue spray can paint job, is actually going to look rather sharp when all is said and done. Can't wait for all the parts to arrive and see if what I'm envisioning for the finishing touches will look as good in reality as my imagination is telling me it will.
#1993
What happened?
Quoted: 1835 Post(s)
Liked 292 Times
Had some help and then took it out on a shakedown run last night. Still making adjustments.
#1994
ambulatory senior
Liked 3,658 Times
Starting to sort this out. Bar ends and a more upright stem.
#1996
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,178 Times
Where did you source the decals?
Ben
Voltaire
Voltaire
#1997
Shifting is fun!
Bikes: Yes, please.
Quoted: 2193 Post(s)
Liked 4,587 Times
Cleaned up the Méral. I'd bought it for mrs non-fixie because she wanted "something special". Thought this might be a good candidate.
The paint is in pretty good condition, but the original hearing aid beige is so not special that I am considering painting it.
#1998
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
I put away the Ironman and the two Treks, and will be riding Panasonic for the forseeable future. '72 World Voyageur and '92 Paramount PDG 5. These two have been on the shelf since April, so needed some tuning up. The Paramount is my only indexed bike so will be somewhat of a treat. The WV has a Spirt fd and a Cyclone rear. A great set.
#1999
Quoted: 339 Post(s)
Liked 631 Times
Something a little different
It is a mid 80's Phillipe , A small boutique builder that I had never heard of. I am going to build it up with all french parts if possible.
#2000
Liked 2,178 Times
Xiaoman1 ...
Ben ....
Here is the link ... easy to use after some practice. Good, quick service. Even sent some extras for mistakes.
https://doityourselflettering.com/vinyl-lettering/
Regards,
JD, Dallas
Ben ....
Regards,
JD, Dallas
Hung them all on the back wall as well as the joists in the ceiling.
...Best, Ben
Voltaire
Voltaire
Likes For xiaoman1:
