Best setback seatposts?
Callipygian Connoisseur
Quoted: 564 Post(s)
Liked 350 Times
I can tell you, the VO claim of 30mm setback is a stretch. Take a look at the design. The cradle which supports the seat rails is a curved design, so while technically it may provide 30mm of range, when the saddle is positioned as far back as it can go, the angle is pointing the saddle nose up by about 30 degrees. It’s definitely not possible for anyone to ride with the nose sticking that far up. Not even close. Bringing the nose of the saddle down to anything even remotely rideable moves the entire saddle forward, shortening the setback.
I bought a B17 and realized immediately that I needed a lot more setback because of the short rails on the B17. I bought the VO thinking it would get me there. It’s a total fail. While I cannot claim to have specifically measured, IMO the VO barely offers more than my 20mm setback Zipp seatpost when the saddle is in a level position. As a result, both the B17 and the post are sitting on the shelf.
I’m gonna take a look and see what Nitto has to offer.
-Kedosto
Edited to add: You’re gonna want to stick with a clamp design which is adjustable from the bottom. I tried the B17 on a 25mm setback Specialized post that adjusts from the side, but the stiff leather skirt of the B17 blocked the clamp/adjustment Allen head, nixing that idea.
-Kedosto
Quoted: 4790 Post(s)
Liked 3,917 Times
Thanks for the idea! I do like the Thomson hardware. So carbon and custom are both options. And thanks to you and Timothy for the support. I believe defending my fit to people who do not know me, my riding, my body geometry, my bike, or it’s geometry is not an attractive proposition.
Ben
Quoted: 1854 Post(s)
Liked 661 Times
Thomson used to sell replacement parts.
Liked 661 Times
I've used the FSA K-force SB25 on all of my bikes for over 10 years. They work great and you can also get a 32mm setback model. It has a 2-bolt rocker style clamp that permits very small changes to the saddle angle. I always shop around to find a source that's selling for far less than MSRP.
The normal setback for most posts is 20-25mm. Needing a 25-32mm setback has nothing to do with a frame being too small. Smaller frames are often made with steeper seat tube angles that may require more setback on the post. The saddle rails also play a part in the need for a post with more setback.
Builders (like Ti cycles, near Portland) can custom make you a seatpost precisely to your needs.. best is of course going to cost more..
Quoted: 350 Post(s)
Liked 122 Times
I was looking at solutions for greater setback without changing the seatpost. I came across old threads about the M2racer Power Module which gives you an extra 4cm of setback, but the company closed a long time ago.
So then I came across the Rinsten Spring from Ukraine, but made in China. It's a simple U shaped rail made out of spring steel which is supposed to serve as a form of suspension. Looks like you can get up to maybe 8cm of setback, but you'll get a lot of bounciness if you're that far back. Supposedly reviewers say it feels pretty good, but some people worry about it being too bouncy, or about too much lateral deflection and torsion. This might also cause the clamp to slip backwards. I thought maybe if you stuck a piece of TPU or rubber block between the upper and lower rails, you'll get some dampening. If you also clamp the open ends with a second set of clamps, you might get less torsion.
Here is a video:
It goes for $60, but there are some similar products on ebay or Amazon from Chinese sellers for $20, although I don't know who came first. One difference appears to the the angle between the upper and lower rails. Rinsten claims 8 degrees. Superimposing the product images, I estimate the Chinese versions are probably 10-12 degrees, so you might have problems not being able to level the saddle if you run out of tilt adjustment on your clamp. The smaller angle of the Rinsten might have a better chance of leveling. Rinsten started as a Kickstarter campaign, and they claimed that the first batch was bad and had to be tossed. I guess from poor manufacturing tolerances, probably non-parallel rails or spacing. So I don't know if the version from Chinese sellers would have a similar problem. Rinsten claims that their next batches were closely watched and checked for quality control.
Rinsten also seems to have only partially shipped units to the campaign backers. The latest update says in order to ship to the remaining backers, they need to sell 3 units for every 1 backer. But I guess if you're buying one from their website, they're probably happy to ship it to you.
https://rinsten.com/
One reviewer on Amazon for the Chinese version says it snapped while riding.
Oh, I found a thread on Bikeforums where someone tested a prototype of the Rinsten, but it broke after 800 miles.
Although the kickstarter page says they're testing different materials and doing stress tests, so the production version might use a different material than the prototype.
https://www.bikeforums.net/general-c...le-spring.html
I was thinking about using this on my Brooks because I'm 2-3cm too far forward. But I have sprung B17 Flyer Imperial, which already has some tilting deflection from the springs, in addition to my thudbuster, so I would only use these additional U springs on an unsprung saddle.
But anyway, if I were to use this, I'd set the clamp as far forward as possible and then back it off to achieve the desired setback, as the main purpose for me is for the setback and not for the suspension.
Above: Rinsten
Below: Chinese variations on Amazon and eBay
Here is a video:
Above: Rinsten
Likes For tomtomtom123:
Cycleway town
I made my own, an aggressive copy of the '80s style layback BMX seatpost.
Likes For Kedosto:
Liked 3,917 Times
I spaced out in my previous post. (Guilty - didn't read most of this thread.) I have one of those steel Nitto posts. Best production post I have ever owned or ridden by a lot. They are gems. Beautifully built, very well thought out and a joy to set up and use. Bought it earlier thi8s spring to have a post I trusted completely on a wild gravel ride that would also mean the clamp would be well away from the seat's ti rail bends. After that ride, I pushed the seat forward an inch to reset the bike to a fix gear. So I have been fooling with that post a lot. And what a joy!
$160 vs $55? If the $55 post works for you, you will probably never regret it. Spend the $160 and you have a post for a lifetime. Worth it? Can't answer that. Now, my Peter Mooney finally has a post as good as the bike.
Ben
Ben
Likes For 79pmooney:
Liked 661 Times
I’m glad you guys came back to this post with the wire solutions! I have tried an S 84 in a few situations and I like as much as Professor Mooney does. These wire spring devices suggest a solution to the stoker saddle for my ongoing tandem build, if coupled with a damper. If my favorite stoker isn’t happy, I’m not happy.
My need for setback: somehow I do not feel in balance on a bike unless my sit bones (widest portion of saddle) are about 27 cm back from a plumb line to the BB. I can only achieve this with Brooks products or my old Ideale 92 with a deep seat tube angle (71 degrees on my ‘50s Rudge) or a high-setback seat post. It’s better with the long rails on Selle AnAtomica or Specialized saddles, and not so good with the Rivet design, at least the one I bought.
I don’t think my frames are all too small though some are a little too French (high seat tube), but life has trade-offs. High seat tube angle today is 73 degrees in my size, and I know that requires a 30 or 35 mm seatpost setback. Many very desirable light vintage machines, like my Masi and Mondonico frames have angles greater than 75 degrees otherwise they fit well. And no, not all of those builders’ products were custom; such angles represent The Way They Thought Things Should Be. But it doesn’t usually work for me at least at my current level. If I finally become ready for stage racing maybe that will change (lol!).
Quoted: 550 Post(s)
Liked 325 Times
I broke the first one in 3415 miles shrinking from 185 to 154 pounds and finished that ride standing.
I replaced it with a higher grade bolt which broke in 1690 miles dropping to 140 pounds over that distance and had my wife pick me up.
I was using a saddle with carbon rails although that was not prohibited.
