What's the difference between a track frame and a road frame?
What are the differences? I know there's gotta be a few, and do they make a big difference in riding?
Fixie Infamous
Bikes: 2007 CAAD Optimo Track, 2012 Cannondale CAAD10, 1996 GT Force restomod, 2015 Cannondale CAADX
Quoted: 54 Post(s)
its aaaallllll in the geometry my man..... alllll in the geometry.....
Ths Hipstr Kills Masheenz
Bikes: tirove
and the stiffness vs. lightness of the design... and in the dropouts(security vs quick tire changes)... and in the brake drilling (track bikes don't need it)... but yes geometry for handling and body position is number one.
Headtube angle, seat tube angle, bottom bracket drop, chainstay length and wheelbase, brake drilling, track ends (instead of dropouts), and fork rake
Of course, even track frames vary.
Bikes: Pegueot UO8, Tommaso Augusta
track frames for the street, and road frame to be converted, right? That the correct use right?
Goes to 11.
Bikes: 2015 Soma Double Cross
Track bike geometry is implemented for maximum power, with little thought given to comfort. When riding on the street, there are benefits and disadvantages to track bikes, all relative to riding a converted road bike:
Pro
Agile, quick steering
Tall bottom bracket offers excellent pedal strike clearance
Con
Harsh ride
Unstable handling at low speed
Very limited clearance for larger tires/fenders
Steep seat tube angle makes proper bike fit problematic for distance riding
Fortunately, most fixed gear bikes that you'll buy in bike shops and from internet dealers have evolved from strict track geometry to a style that's more a hybrid of road and track. You still get the tall bottom bracket, but you also get slack headtube and seat tube angles, as well as wider tire clearance.
Pro
Con
Harsh ride
Bikes: Brooklyn Machine Works Gangsta Track, Bianchi Pista Concept 2005, Cannondale CAAD9, Klein Fervor
Bikes: 2014 Trek Domane 5.2, 1985 Pinarello Treviso, 1990 Gardin Shred, 2006 Bianchi San Jose
Quoted: 62 Post(s)
Liked 28 Times
1979 Colnago Pista
Notice the angle of the head tube versus that of the seat tube. The head tube is steeper, more vertical.
On this road bike, the head tube and seat tube have the same angle. This is typical of road bikes.
On the track, there is no need for tire clearance or even brakes.
And it would make no sense to ride this on the street except the bike is so damn cool it would have to be done at least once.
Road bikes will have more trail which improves stability and steering. Chainstays are generally a bit longer, too.
bike geometry
https://www.bikecyclingreviews.com/Frame_Geometry.html
Don Walker on Track Bike Geometry
https://www.urbanvelo.org/issue3/urbanvelo3_p44-45.html
There is a very noticeable difference in handling. I did not find the aggressive geometry of a track bike comfortable or practical for street riding. Track bikes are not very versatile, being designed solely for the track. They do look pretty cool, though.
bike geometry
Old fart
Quoted: 3590 Post(s)
Liked 3,400 Times
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1331 Post(s)
Liked 764 Times
As a general statement, that is true. However, there is a significant variation in both road and track frames, and plenty of overlap. My old custom built steel crit racing frame has tighter geometry, more toe overlap and rides harsher than my Soma Rush steel track frame. You can buy a compromise track frame like the Soma Rush, which combines the best aspects of road and track geometry. I've ridden the Rush 65 miles with only one brief stop w/o discomfort, but could still ride and race it on the track if I wanted to.
Elitist
Quoted: 1386 Post(s)
Liked 92 Times
- Road Bike
- Track Racing Bike
- Street Fixed Gear Bike. (Also called a "track bike" because track racing bikes were the first in recent years to be adopted for this style of riding. This genre is also diluted with conversions and other bikes with "street" geometry.)
About which of these 3 would you like information?
Bikes: Civilian Le Roi Le Veut, Kazane Track, Ciocc Designer '84, Serotta Colorado AL 25th anniversary, '85 Guerciotti Pista, '84 Trek 660, Volume Credence
Old fart
Liked 3,400 Times
Bikes: Mark V Pro Frameset, Fixed Statebike
WAIITTTTT A SECONNDDDDD,
Your... brake...
Idk whether thats the smartest thing ive ever seen, or just plain mediocre...
on another note, if i would try to ride this in Chicago id probably get robbed the moment I stepped outside.
Your cog is slipping.
Bikes: Nashbar SSCX
