What kind of tubes do I need for H2 Comp?
Old 10-14-23, 03:09 AM
DreamRider85
DreamRider85's Avatar
Quoted: 378 Post(s)
Liked 24 Times in 14 Posts
I'm illiterate to specs sometimes. I got H2 Comp Hybrid Tires. They are 700 x 35 Bontrager. But when I try to order tubes, there's so many different nuances to the sizes. Just don't want to order the wrong one.
DreamRider85 is offline
Old 10-14-23, 04:43 AM
wolfchild
Quoted: 4227 Post(s)
Liked 2,488 Times in 1,286 Posts
Tubes in 700 x 28 mm - 32 mm size will fit your tires.
wolfchild is offline
Old 10-14-23, 07:09 AM
biker128pedal
biker128pedal's Avatar
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 270 Post(s)
Liked 447 Times in 266 Posts
You sound new. Get butyl rubber tubes. Make sure the valve type is the same. Also get a patch kit, tires levers and a pump.
biker128pedal is offline
Old 10-14-23, 07:23 AM
delbiker1
Mother Nature's Son
delbiker1's Avatar
Quoted: 853 Post(s)
Liked 1,437 Times in 819 Posts
IME, cheap tubes are just that. A quality tube is more up front cost, but well worth it. For butyl, the usual tube material, I prefer Continental and Vittoria. but I use latex tubes mostly. For those I have Vittoria and Challenge. You need to get tubes that are labeled as 700C and with width of from 32-38mm. Rema patch kits, IMO, are the best for repairing punctures.
delbiker1 is offline
Old 10-15-23, 05:57 AM
Homebrew01
Super Moderator
Homebrew01's Avatar
Quoted: 1173 Post(s)
Liked 927 Times in 612 Posts
Yes. Schrader or Presta valve ? Get whatever you have now.
Homebrew01 is offline
Old 10-15-23, 12:39 PM
Iride01
Iride01's Avatar
Quoted: 6196 Post(s)
Liked 4,810 Times in 3,318 Posts
Tubes usually will have the range of tire sizes they fit marked on them. Different brands do it in different ways. Some more confusing than others. And 700C rims are very close to the same diameter as 27" rims, 622mm vs 630mm. So some of those boxes are real confusing with how they show you the information.
Knowing the ISO size of your tire frequently helps. https://www.sheldonbrown.com/tire-sizing.html
Then sometimes you can make better sense of the info on the tubes package. Sometimes a tire width is at the end of one size range and the beginning of another size range. They'll both fit. I'd pick the larger size range, unless for some unusual circumstance such as internal width or internal profile of my rim made it seem too big.
Do get what type valve stem your rim was made for. Usually presta or Schrader. If your rim has a profile to it for making it aero, then know what length stem you need. Nothing really wrong with getting them too long. It just looks odd.
Iride01 is offline
