Oil or grease old school brake cables
Old 04-02-12, 04:32 AM
TurbineBlade
Kid A
TurbineBlade's Avatar
Liked 5 Times in 5 Posts
Hi, I have some housing I'd like to use (brake) that is the old, unlined stuff. I know that oil or grease must be used on it, but what is the best way to do this and should I use grease or oil? So I insert the inner wire, then pull it partially back out and pour oil in?
I have a tub of auto wheel bearing grease, but I'm thinking that may be too heavy (it's like the park grease). I also have a thing of chainsaw bar oil, and probably some 5W-30.
Thanks!
TurbineBlade is offline
Old 04-02-12, 04:41 AM
bobdell
Boeshield, triflow, something that leaves a residual lubricant after the carrier fluid evaporates. Dri-slide was an excellent cable lubricant but I haven't seen it around in a long time.
Grease is too heavy. Oil will seek the low spot and also attract dirt.
bobdell is offline
Old 04-02-12, 05:15 AM
bradtx
Bikes: Cannondale, Trek, Raleigh, Santana
Quoted: 308 Post(s)
Liked 3 Times in 3 Posts
TB, Search for graphite lubricant.
Brad
bradtx is offline
Old 04-02-12, 07:08 AM
BobLoblaw
Dough Mestique
I greased my brake and shifter cables for a decade until someone told me grease slowed down my shifting. I switched to oil for five years. No difference except my cables rusted in the rain. So now I am back to grease for the past ten years, and as it did before, it works fine.
Get a blob of grease on your fingertip and run it down the length of the cable, then install the cables.
BL
BobLoblaw is offline
Old 04-02-12, 07:10 AM
HillRider
Quoted: 2026 Post(s)
Liked 1,096 Times in 742 Posts
Why?
HillRider is offline
Old 04-02-12, 07:27 AM
Hendo252
Bikes: 1983 Trek 620, 2010 Roubaix
FWIW Dri-slide (AKA Bike-Aid) molydisulfide grease is still available and would be excellent for the OP's situation...
https://www.lubritek.com/bike-aid_lube
Available on Amazon and elsewhere.
-Tom in SoCal
Hendo252 is offline
Old 04-02-12, 07:49 AM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3590 Post(s)
Liked 3,401 Times in 1,935 Posts
If you're installing new cables, just grease the cable before sliding it into the housing. If you need to lubricate cables in situ use a cable lubricator:
Slip it over the cable and snug it down over the housing, attach a spray can of your preferred lube and fire away.
JohnDThompson is offline
Old 04-02-12, 08:33 AM
Homebrew01
Super Moderator
Homebrew01's Avatar
Quoted: 1173 Post(s)
Liked 927 Times in 612 Posts
Grease always seemed to work well for me. Smear a little down the length of the cable before inserting.
Homebrew01 is offline
Old 04-02-12, 08:43 AM
FBinNY
Quoted: 5793 Post(s)
Liked 2,585 Times in 1,433 Posts
Grease is probably the best choice for unlined housing. Smear it down the wire then thread into the housing.
You can also use a very heavy oil. If your bottle has the right nozzle, put it to the end of the empty housing and squeeze in what feels like a decent amount, then threading the wire from the same end will push it in and spread it.
Older unlined housing is usually used with older brakes and non-indexed derailleurs. These had stronger springs than modern light action stuff so cable friction is correspondingly higher, and light lubes won't cut it.
FB
Chain-L site
FBinNY is offline
Old 04-02-12, 08:53 AM
JonathanGennick
JonathanGennick's Avatar
Bikes: Priority 600, Priority Continuum, Devinci Dexter
Quoted: 685 Post(s)
Liked 55 Times in 37 Posts
I am not the expert Frank is, but I will note here that Shimano had pre-greased the cables that shipped with my bar-end shifters. Presumably then, Shimano favors grease.
JonathanGennick is offline
Old 04-02-12, 05:18 PM
HillRider
Campy does too and pre-greases the shift cable housing that comes with Ergo brifters. However, both use a light relatively low viscosity grease.
Old 04-02-12, 06:40 PM
Scooby214
Saving gas on my commute
Scooby214's Avatar
I am also of the "grease the cable" camp. I find that smearing a very small amount down the cable works well enough for me.
This also works for the accelerator cable on an old VW Beetle. I've learned the hard way that it's not fun to have your Bug's accelerator cable freeze up.
Scooby214 is offline
stephr1
General Cycling Discussion
12
07-16-19 04:52 PM
boshk
Road Cycling
4
05-19-17 02:28 PM
rossiny
Bicycle Mechanics
14
12-18-15 12:38 PM
Gege-Bubu
Bicycle Mechanics
7
05-18-13 08:04 PM
R88
Bicycle Mechanics
17
06-01-12 07:33 PM
