Wobbling crank
Wobbling crank
Hello everyone
I bought this cheap bike with a wobbly crank/shaft?
I would like to fix it myself however I am not sure how to determine the exact parts I need to buy in order to do so. I watched some YT videos but I am still a little bit confused cause there's many different types of shafts and I am not even sure what part need to be changed.
I could just go to bike shop (I actually went, and the diagnosis was that the shaft needs to be changed £50). But I like doing stuff myself anyway and as I have some spare time I though it would be a nice thing to know how to do.
I am attaching close-up photos. I also have video of it wobbling but I cant post it here ;/
If any one would be so kind to let me know what tools and parts I should buy in order to do it I would be very grateful!
Stay safe,
Stay safe,
Quoted: 2026 Post(s)
Liked 1,096 Times
What make and model of bike? What make and model of crank?
Park Tool's web site has a large number of tutorials on all aspects of bike repair so see if you can find the type of crank you have there.
Likes For HillRider:
There are no photos attached.
Two wrongs don't make a right but three lefts do! Unknown
Quoted: 1609 Post(s)
Liked 2,590 Times
assist
Quoted: 1074 Post(s)
Liked 295 Times
That’s a square taper cup&cone BB.
I’d try to tap the lockring loose, screw in the NDS cup a little and tighten the lockring again.
Anything beyond that, odds are you’ll be spending a fair amount of the quoted price on tools before you’d get the job done.
Likes For dabac:
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
Is it one arm wobbling on the spindle, or the whole assembly (both arms and spindle) that wobble together as a unit?
If the former, the arm has worked loose on the spindle. Unfortunately, that often means that the arm has been damaged and needs to be replaced. You can snug up the retaining nut or bolt and see if it stays tight. If you're lucky, it will and you're home free. If it keeps loosening up, you'll need to replace the arm.
If the latter, the bearings are out of adjustment. @dabac's suggestion above can tighten it up again, but it's also possible that the internal parts have become damaged. If, after tightening the adjustment per dabac's suggestion it makes unpleasant noises, binds, or otherwise doesn't behave as expected, you'll need to open it up and inspect the parts for damage.
Likes For JohnDThompson:
Liked 2,590 Times
A friend got one of these to get some exercise. At 260, he bent the spindle pretty quick. Some bikes are cheap for a reason.
Likes For curbtender:
Liked 295 Times
Likes For dabac:
I think it was the entire unit that was wobbling. As suggested I tightened it up. I only had a wrench and a flathead screwdriver but it worked just fine! Must've just loosen over time.
I've saved £50 for now. We'll see for how long it will stay like that If it'll go back to being loose I will open it up and see what's the root problem!
Thanks!
Thanks!
