Ovoid Chainrings
Bikes: 2005 Cannondale R5000 1986 Basso Gap(Super Record) 1986 Schwinn Voyager SP 1975 Schwinn Paramount Track Bike 1974 Raleigh RRA
Quoted: 31 Post(s)
Ovoid Chainrings
Someone gave me a 1987 aluminum Lotus not long ago. It has Bio-Pace type rings called, I believe, Ovoid.....I'm not surprised I'm not noticing them much.....And the last few more and more pros use the oblong rings....What is the consensus here?
Quoted: 5766 Post(s)
Liked 2,538 Times
They [B]seem[B] to offer some benefits for lower cadence riders and when climbing. However high cadence riders tend not to be fans,
There may also be some drawbacks relating to FD performance.
In any case, they're like double breasted suits, and come back around every 10-20 years.
FB
Chain-L site
FB
Chain-L site
Quoted: 897 Post(s)
Liked 9 Times
I think the consensus back in the late 80's, when they came out, was that you noticed the oval shape much more on the big ring than the small ring. Sprinters hated 'em, but some time trial specialists liked them. I don't recall seeing anyone riding them who were not paid to use them, so make of that whatever you want.
They were essentially rejected after a few years, but some people (myself included) kinda liked them on the small ring for climbing. My climbing stroke is not the smoothest (especially on steep gradients) so they didn't slow me down at all when I used them.
IIRC, it was concluded that they didn't make very much difference, good or bad, and that they were largely "a solution in search of a problem".
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 524 Post(s)
Liked 977 Times
I have a bike with Bio-Pace and one with Sakae Oval-Tech. I don't notice any difference, good or bad, when riding the big or middle ring. It's too flat around here to be able to judge the 28 tooth small ring. I normally pedal around 80-90 rpm.
Señor Member
Quoted: 1491 Post(s)
Liked 1,088 Times
Sky claims they boost Froome's efficiency by roughly 10%. I don't believe much that they say.
What??? Only 2 wheels?
Quoted: 1222 Post(s)
Liked 645 Times
We're having a ovioid crisis, aren't we? I say ditch 'em.
Real cyclists use toe clips.
jimmuller
jimmuller
Quoted: 378 Post(s)
Liked 1,409 Times
There was a master's thesis done in California on Rotor's oval chain rings. The aim of the study was to disprove any advantage. The research showed zero disadvantage, and advantages ranging from 0 to 5%, i.e. "no downside." I think Rotor actually saw the study and hired the grad student.
I think I saw it in a bike magazine, and that's what I remember. I have a friend who is a very powerful masher, and he runs the Rotors on his bike and swears by them.
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
Quoted: 1627 Post(s)
Liked 630 Times
Also, you should know that in the BioPace line there are at least two different degrees of ovalization, rather mild* and somewhat less mild*. I've had both and I don't really notice the mild ones but can't stand the less mild ones. I've never ridden the Oval Tech line.
*excuse my technical jargon.
Quoted: 1372 Post(s)
Liked 1,748 Times
Try spinning this puppy. At a cadence of 20 rpm and more, the bike actually started to hop...
Bikes: 1996 Trek 970 ZX Single Track 2x11
Quoted: 614 Post(s)
Liked 564 Times
I spent a bit of time, one day in the mid-1980s, test-riding a Ritchey Ultra. It had BioPace chainrings on it. I thought they aided slower-cadence power up hills, but hated how it induced its own uglier motion in the pedaling when the cadence was high and I was on flatter terrain. My own preference: "standard" round chainrings.
They've been coming and going on a 10-20 year cycle since the first chain was installed on a bicycle. If they were really an improvement, they'd stay rather than fading away until the next time they are "invented".
If you are a stomper, you might like them. If you know how to spin, you probably won't. If you do find that you like them, your next purchase should be a set of used rollers. Use them to learn to spin smoothly. Your knees will thank you in the long run.
Quoted: 1946 Post(s)
Liked 2,004 Times
I'm new to the Bio-pace thing but they apparently belong on my Ironman. After a few hundred miles, I don't know if there is a real or imagined difference. I don't think that I would order replacement Biopace rings.
Death fork? Naaaah!!
I like 'em. Whatever the original design parameters were my knees hurt less after 50 miles or so when riding Biopace. And I'm always looking for 130/53 and the scarce 130/40.......
Top
Top
Quoted: 1361 Post(s)
Liked 423 Times
Funny how the Bio-Pace name is usually referred as when talking oval rings. Sort of like Xerox is to photocopiers.
Only ones I've experienced are Shimano's and then until this year, the '87 edition of Suntour's Ovaltech. Immediately noticeable but soon becomes fluid and routine feeling. I'm also enjoying fixed gear bikes and possibly there's a correlation in that bio physio sensation though having them or not makes no difference to me.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,102 Times
Bikes: '84 Peugeot PH10LE
Quoted: 397 Post(s)
Liked 55 Times
I have a biopace middle ring on a front triple on my '84 Peugeot road bike. I can't really say any thing pro or con. It's just there and is the most-used front ring. I put the triple ring on about 30 years ago.
Jon
Jon
Quoted: 741 Post(s)
Liked 818 Times
I had a 90s (?) Bianchi Forza with Biopace rings several years ago. I was cleaning it, and noticed that the rings weren't round. I saw the Biopace sticker and Googled it, learning the story. I rode it for a year or so, until a car hit me and killed the frame. I transferred everything to a Nashbar frame, but finally sold it. I was a low cadence gear masher back in the day, try to spin lower gears, high cadence now. Now I might feel a difference, but not back then.
Extraordinary Magnitude
Quoted: 2607 Post(s)
Liked 1,694 Times
I find it interesting that some people SWEAR ovoid chainrings kill your knees, but there's lots of people (Top included) that find the ovoid rings are kinder to their knees.
I have 2 small BioPace rings and a round large on my 87 Schwinn High Sierra. I don't really notice the difference on the 38- but it's a marked difference on the 28. I had the SR OvalTech rings on an 88 Trek 400 for a while. I recall that I actually liked them.
I recall some post here a long time ago- a bike newb completely upset that his chainrings weren't round- he discovered it while riding and thought he broke something. It is weird to look down and see it- especially if you don't know what you're doing.
Commence to jigglin’ huh?!?!
Quoted: 71 Post(s)
Liked 5 Times
I like the "avoids" rings myself, have run shimano 105 (88 trek 560) and 600 tri color (89 fuso fr1) and always feel good on climbs or hammering but really little to no difference vs rounders. When they are part of stock builds I have always left them as is. Never given me any knee problems.
