What mastermind came up with this?
I was on a ride yesterday and noticed my tire going flat, it was on smooth pavement so must have been a bit of glass or something. Bummer! but I ride with patches, spare tube, and tools so only a minor inconvenince. My bike is "tubeless ready" but I never really looked much farther into converting to tubeless because I'm not really sold on trusting a fluid to seal my tire. I got the bike flipped up and noticed some milky fluid bubbling out of the tire. So they were running tubeless, and also my lack of trust in the fluid to seal a puncture proved valid lol. It was a tiny slit ~3mm - see pic below. As I mentioned I'm not that knowledgeable on tubeless but know that they are supposed to seal so I started pumping the tire but the fluid was still spitting out. Oh well, I have a tube so I'll put that in.
I fought to get the tire off and couldn't believe what I saw. These tires have an integral tube. They dont seal themselves, I cant repair them, I cant patch them, I can't put a tube in to get me home. Get a flat with these tires and you're either walking home or waiting for a ride. Perhaps a plug kit would have worked but still, who thought designing a tire like this was a good idea?! It must have been some big cost saving measure vs. doing a proper tubeless setup or a normal tire with tube to supply a bike with these. Luckily I was only 5km from home and was riding with my GF so after about 40 minutes on the side of the trail trying to figure out what to do, I ended up using her bike to ride home to get my truck to circle back and pick her and my bike up.
Also now I'm grounded until I get new tires, and in this market of anything bike being in short supply at inflated prices I'm likely going to have to take what I can get instead of getting what I want. What a PITA!!!
Small slit in tire
Small slit in tire
Bikes: S-Works Stumpjumper HT Disc, Fuji Absolute, Kona Jake the Snake, '85 Cannondale SR900
Quoted: 219 Post(s)
Liked 217 Times
I guess your bike should have come with the kit Giant describes in this video?
Giant Bicycles: How to fix a flat on an ERT tire
Quoted: 6193 Post(s)
Liked 4,808 Times
Sort of like it's own rim strip built in. Not so much an inner tube. I don't know what to think of them, but if you look at the comment in the reviews it's suggested that there is a one year warranty. What circumstances that covers I have no idea.
https://www.giant-bicycles.com/us/crosscut-at-ert-2019
So you've been tubeless and didn't know it. Or at least you are somewhere inbetween and need to treat it as tubeless with whatever sealant additions and other PM that requires.
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12768 Post(s)
Liked 7,682 Times
That's what I thought at first, but nope
INTEGRATED AIR CHAMBER
Inflating a tubeless tire can be tricky for even the most experienced rider. With the integrated air chamber holding the air, pumping up an EasyRide tubeless tire is a snap! Adding Giant tubeless sealant into the chamber before inflation also helps avoid punctures and flats, so you can enjoy the ride with less worry!
Likes For LesterOfPuppets:
Likes For hsuBM:
Bikes: everywhere
Liked 7,682 Times
You might need some fresh tubeless goop. I'd just go with 2 oz in that tyre.
How long have you had the bike? Here in the desert we have to top off tubeless goop every 3 months, but in wetter climes I hear of people going 9 months before adding goop.
If the cut is too big to seal, Giant has a baconstrips style plug kit. I imagine any tubeless tire plug kit would work, however.
Then when you've worn out these tires you can get some tubed ones if you prefer.
Bikes: Giant Anyroad
Quoted: 44 Post(s)
Liked 33 Times
What a drag. I'm not sure if you tried this, but sometimes spinning the wheel can help seal a small puncture or at least turning the wheel so the puncture is at the bottom, where the fluid is. Otherwise for a bigger hole you will most likely need a plug kit. Giant has a video on their website. Your tire should be salvageable. Good luck
Likes For Reynolds:
Quoted: 3352 Post(s)
Liked 1,056 Times
Unlike car rims bicycle rims have spokes. Tubeless bike tires and wheels seem like kind of a dumb idea.
Likes For rydabent:
SE Wis
Quoted: 2746 Post(s)
Liked 3,390 Times
I wonder if an auto plug would work as well?
https://www.autozone.com/tire-repair...E&gclsrc=aw.ds
Likes For dedhed:
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,204 Times
So just how long have you been rolling around on these tires?
Tubeless tires do require maintenance in the way of fresh sealant.
About every 3 months, I used a syringe to remove the old sealant (just to find out what's left) and I replace with fresh sealant.
Although I will say.....
1. Being unable to get the inside of the tire does stop you being able to apply a patch for larger holes.
2. I bet your rims are nice and clean.
Barry
Barry
Inflate and ride it, see if it seals.
FWIW the bike is a 2020 Giant Roam 1 that I bought new at the end of May and I live in Canada near Toronto. I don't know which system I'd prefer yet so I'm not really opposed to a PROPER tubeless setup and I don't mind maintenance, I'm usually looking for something to tinker with on my bike anyway.
Quoted: 219 Post(s)
Liked 217 Times
Wow, what a failed system. "emergency" repair only then buy a new tire.
Your tires and rims may be tubeless ready, but used a tube. This is perfectly possible. But don't bash "tubeless" because you had a flat - you didn't have a tubeless setup.
First, you can get a flat with any setup, like you can slice the entire tire with tuebless. Second, a tubeless setup uses a sealant that seals small leaks. Obviously with a tube in there, this isn't working. If you have larger holes, there are patchkits and other fixes for tubeless. You also can take a spare tube with you. How far you want to go with spare and repair stuff depends on how far from civilization you go and what territory.
Have it set up properly before you judge it.
Likes For trailangel:
No. No it didn't.
Yes I mentioned I'm aware.
I'm not, I'm bashing this system.
Also aware of that, not a proper tubeless setup anyway.
Ummm.... thanks? Very helpful.
Also mentoned I'm aware of that.
There's no tube in there.
I said I had a patch kit with me.
Yup said I had one of those too.
Please READ the thread.
Likes For Ryan_M:
Quoted: 1188 Post(s)
Liked 1,154 Times
Tubeless plug kit for bikes (the brown snot strings are much smaller)
Finish Line Sealant in tire.
ERT seems to combine the worst aspects of tubed and tubeless systems and none of the advantages. Some engineer somewhere needs a good paddling.
Likes For Trevtassie:
Possibly, not sure if the "tube part" would have stretched enough to meet the inside of the tire as it's only meat to span and seal to the rim. Either way I didn't have a knife with me. However, I may be able to trim that entire rubber piece out and put a tube in to get me riding again until new tires arrive. Thanks for the idea!!!
Quoted: 6963 Post(s)
Liked 10,961 Times
I suggest that you get it set up as proper tubeless, maintain it properly, and enjoy. Tubeless isn't right for everyone...But if it is appropriate for you, it's really quite useful.
Not a newbie to cycling
Bikes: Omnium Cargo Ti with Rohloff, Bullitt Milk Plus, Dahon Smooth Hound
Quoted: 356 Post(s)
Liked 323 Times
If the inner diameter was a problem, you could cut the dead "tube" thing lengthwise I gather. and sort of use it a full-width liner.
Liked 4,808 Times
So is the tire trash? Seems that now knowing you had a tubeless set up you could just put it back on and start doing what you'd do for tubeless tires. Or was the puncture too big for sealant to do it's thing? Of course you are going to have to get more sealant and other stuff if you do use it.
Cutting out the whatever you call the almost an inner tube thing and installing an inner tube will probably work if it doesn't leave a rough edge. But that smacks of being overly obsessed with frugality to me.
That's a truly horrific design. It's like a tubular clincher. This seems like it was done purely to enable the tires to be sold as "tubeless" and easy to setup. The drawback is that it's difficult to patch, and if it gets any sort of cut the tire is basically trashed.
There are plenty of tubeless patch kits, but honestly, my advice would be to trash the tire and never look back.
