Help me keep my chrome from getting worse???
Quoted: 399 Post(s)
Liked 274 Times
Hullo - hope everybody here is well...
I've just spent the past couple of days working on my poor baby's too long neglected chrome with alu foil & brass brushes, water, vinegar, & WD40; & as I expected - some of the problems are not being nice. It also spent a night wrapped in Evaporust soaked rags too, but there's pitting that will not go away. For now I'm just going to hit it with a little wax & ride...
But I did spend some time investigating alternative solutions on the interwebz & ran across this do-hickey...
https://www.amazon.com/dp/B009XF0H0G...v_ov_lig_dp_it
anybody here ever seen anything like it - let alone used & can critique it?
TIA...
TIA...
So it goes.
Bikes: A few. Quite a few.
Quoted: 432 Post(s)
Liked 639 Times
TIA...
TIA...
Likes For PilotFishBob:
Quoted: 586 Post(s)
Liked 612 Times
I find stuff like this fascinating so thanks for sharing it. I have seen videos on youtube where vintage watches are repaired with a similar technique. The watch case is carefully polished and prepared and then plated with nickel. The results are extraordinary.
52psi
Quoted: 790 Post(s)
Liked 802 Times
Well how cool is that?
Quoted: 4512 Post(s)
Liked 6,386 Times
TIA...
TIA...
Slather it on, let it dry, repeat slather and scrub with brass bristle brush, repeat as needed until results stop improving.
I get great results with it and plenty of elbow grease.
I use it. It's a nickel plating I think, not bluish like true chrome - but it does the job, as long as the touch-up spots are small. Surface prep is critical, it will either not adhere or flake off easily if that's not done well. Pictured is a Weinmann bolt I did, before and after. I didn't fully remove the rust pitting and it shows, but overall a big improvement. I also used it to cover some chrome loss on the headtube lugs of my '70 Raleigh Competition - from more than a foot or two away it's undetectable. My main goal is rust prevention, but aesthetics are important too. I purchased directly from Caswell.
So it goes.
Quoted: 432 Post(s)
Liked 639 Times
Quoted: 399 Post(s)
Liked 274 Times
Appreciate all the suggestions...
I'm sitting here looking at a bottle of Chrome Polish and a tub of Paste Wax, and trying to get enthusiastic about scrubbin-n-rubbin for a few hours. My real problem is that each time I go through this, it comes back sooner and worse, so I'm looking for a Silver Bullet to solve my problem. Refinishing is several years down the road and that Caswell thingy caught my eye.
@PilotFishBob - am I correct that it seems like you are using it for very small areas? Do you think 2 or 3 square inch patches would be possible with it?
Thanks again
Thanks again
Half way there
Quoted: 986 Post(s)
Liked 880 Times
That Caswell kit plates with cobalt to mimic chrome so there may be some color differences. I'm not sure about being able to plate directly over chrome. Typically you would have to first strip the chrome down to the nickel or copper base and then replate. Certainly check with the manufacturer before you invest the money. There is no magic bullet when it comes to deteriorated chrome other than viewing distance.
I've been experimenting with nickel plating to restore old sewing machines. Preliminary test pieces came out very well and I'm looking forward to doing some "real" parts. The one thing that is essential is that the parts have to be polished very well in order for the finished product to look well. Any pitting or sanding marks will be magnified by the plating.
Good luck. If you buy the kit, please post your experience using it.
So it goes.
Quoted: 432 Post(s)
Liked 639 Times
Thanks again
Thanks again
Caswell also has larger-scale kits for going beyond just using the brush anode method. I've heard good things about those but a little much (and too pricey) for my purposes. https://caswellplating.com/electropl...ting-kits.html
Quoted: 399 Post(s)
Liked 274 Times
Well I have my bike's chrome about as shiny as its going to get this time around. So as soon as I get the wheel done, its gettin' ridden. And I am definitely getting one of those little Caswell platers and will do some practicing so that I'm hopefully able to use it on the next periodic chrome refurb. Thank you PilotFishBob for your info about it.
Which leads me to my last(?) question on this subject...
I think I mentioned earlier that what's really been pissing me about my chrome corrosion(?) is that it gets worse, sooner after each treatment lately. So...what does this sub-forum think about clear-coating in place of polishing in a desperate attempt to stay prettier, longer?
Thanks again everybody...
Likes For IAmSam:
Liked 6,386 Times
I had a an old Honda motorcycle with lots of chrome that needed polishing to stay looking good. I would clean the chrome well and then use Nevr Dull on it. It would keep it looking good for a full season - even after several washes.
It's a polish/cleaner impregnated cotton. Rip off a piece, wipe on chrome, allow to dry to a haze and wipe off. It can be found at most auto parts places. I've even seen ott at Walmart.
Bikes: miyata 83 1000,84 1000,83 610,88 ridge runner ,Schwinn 84 high sierra,88 Cimmeron,86 Passage,84 Stumplumper ,83 Mt Whitney,83 Trek 850,Merckx Century,PX10, RB1,XO 1 XO 4,bunch of stuff like that
Quoted: 57 Post(s)
Liked 51 Times
wax
Instead of clear coating just use paste wax.It totally stops rust , easy to apply, protects paint and chrome ,lasts years....I havent used that particular brand of electro plating but I use to work in a shop that had those small brush type plating kits for copper silver gold and nickel.If you prepare polish and clean the metal you can get professional results..but you cant plate over chrome very well.Always did copper first then nickel on highly polished metal and multiple coats.Sometimes copper silver then gold,Clean metal with lacquer thinner and no fingerprints.Buff with jewelers rouge
Likes For homelessjoe:
