Are there any regular bolt mount dual pivot brakes?
Old bikes, Older guy
Location: Fiscal Conservative on the Lefty Coast - Oregon
Bikes: A few modern, Several vintage, All ridden when weather allows.
Quoted: 250 Post(s)
Liked 166 Times
Hi folks,
I have a 76 Eisentraut Limited with the original Galli brakes. Even with Kool Stop orange pads, they don't stop as well as I'd like. I have both dual pivot Shimano 600 Tricolor & late model 105s, but of course they're both recessed bold mount. Any suggestions or inputs?
Thanks & regards,
Van
Thanks & regards,
Van
Remember: Real bikes have pedals.
...and never put a yellow tail on a Red, White and Blue kite!
Likes For Marylander:
Quoted: 3359 Post(s)
Liked 3,637 Times
Yes, these are your best option, depending on your reach requirements ^^^^
Also, you may not be able to find those brakes with nutted hardware, but you can buy the appropriate parts directly from Tektro at this link here and perform the conversion. It's pretty simple
Quoted: 250 Post(s)
Liked 166 Times
OK, dumb question: will the Tektro kit work with either of my Shimano break sets?
Thanks again,
Van
Thanks again,
Van
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,054 Times
Quoted: 930 Post(s)
Liked 1,291 Times
I'm wondering why your brakes don't work well. Have your replaced the cables and housings with new lined housings and coated cables? That is a common reason for excessive friction (and poor braking) in the system. Have you taken the calipers apart and lubed the pivots?
Crawlin' up, flyin' down
Quoted: 1025 Post(s)
Liked 2,525 Times
I have done exactly this on a 1978 Eisentraut (nutted R539s front and rear) and a 1965ish Cinelli (R539 front, R559 rear, both nutted; (Italians did weird things with brake clearances BITD) . Excellent choice, especially if you swap out the original pads for some Kool Stops.
I run mine with Campy 10sp brifters, The combo works very nicely. I am a large person (255#) and most of my rides are hilly, and I have zero problems with this set-up
Bikes: many
Quoted: 1444 Post(s)
Liked 1,392 Times
Whatever you do, don't discard those Galli brakes. Someone will want them.
Quoted: 4510 Post(s)
Liked 6,377 Times
Are you confident they are set up properly? I have a 75 Limited with Campagnolo Record brakes and first gen Dura-Ace levers. It stops just fine, as fine as 40yo single pivot brakes will. If you're used to modern dual pivot brakes, I suspect you'll be disappointed.
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
If you can find just the long center bolt for the front, that’s all you really need. They used to be available on eBay for around $5, but I don’t know if they still are. Anyway, use the front brake in the rear and it doesn’t need any modifications other than swapping out the nut. Then replace the center bolt on what was previously the rear brake with a long replacement bolt and use it in the front.
Pay careful attention to how the brake you’re modifying is constructed. There’s probably a set screw or two that needs to be loosened to disassemble the brake. If it feels like a lot of force is required you’re doing something wrong. It’s probably not stuck. It’s being held 8n place by a set screw.
My Bikes
My Bikes
Bikes: Gitane Course, Paris Sport, Peugeot AO8, Peugeot Bretagne, Peugeot Premiere 85, Peugeot Premiere 86, Peugeot ANC Halfords Team Replica, Peugeot Festina Team Replica, Motobecane Grand Sport, Motobecane Super 15, Raleigh Pro Race, Raleigh Stratos, BSA
Quoted: 117 Post(s)
Liked 427 Times
The nutted Tektro brakes work very well - I've got a Raleigh with the 559's fitted (needed the extra reach as the 27" wheels were replaced with 700c) and they stop it very well. The levers are Weinmanns.
For information SJS Cycles have conversion bolts in stock: -
https://www.sjscycles.co.uk/brakes/j...ut-conversion/
Quoted: 250 Post(s)
Liked 166 Times
Thanks for all of the feedback
Sorry for the slow slow response. Things have been a bit hectic around here.
I’m going to follow Andy K‘s advice & try to use my tri-color calipers.
Thanks again,
Van
FIW: The was recently reassembled with new brake cables after adding decals & graphics. The brakes work well considering the vintage, but with the hills here & my declining grip, I was looking for something better.😮 Cheers
Van
Just a quick shout that you'll need to swap the brake shoes right>left when moving front>back/back>front. Basically reorienting the shoes so the open end of the shoe holder faces the rear of the bike i/o the front of the bike. Otherwise you risk the shoes self-ejecting under hard braking.
Fuggedaboutit!
Fuggedaboutit!
Quoted: 250 Post(s)
Liked 166 Times
