are there something like cleats with straps, bound and fixed to other shoes
hello
are there something like of cleats with straps, bound and fixed to other shoes,
so I can use cleats on most of any non-cleat shoes.
I was using toe clip pedals too
but, maybe I haven't mastered how to fully utilize effectively, they were more wobbly than I expected.
belows are similar idea is applied in other genre of sports activities
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
Just be cheap cycling shoes if you don't want to commit to clipless.
Quoted: 645 Post(s)
Liked 797 Times
So you want to be able to fasten cleats to essentially any pair of shoes, making the shoes usable with...toe straps? Are you talking about old-style cleats or "clipless" cleats? The problem as I see it is that cleat positioning is a big deal - effecting efficiency, knee happiness etc - I can's see how you can get consistent cleat positioning without actually attaching them to the sole of your shoe.
Is the goal so you can cycle "cleated" and then be able to remove the cleats to walk?
Likes For Litespud:
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
I know of no such product. I'd imagine that in order to secure them tightly enough to not move around and to release from the pedals predictably, they'd be uncomfortable. I don't know the issue you're trying to resolve, but I'd recommend looking at the many "casual" shoes that are available with recessed cleats.
coincidentally, I was able to get these normal looking outsoled clipless shoes today but still I eager to get above mentioned conversion strap thingy.
Likes For Quintessentium:
On Your Left
Liked 2,433 Times
I've seen clipless sandles
Likes For GlennR:
I use my dear bike for daily purpose too and if I have such thingly it’d so useful, without unscrewing and installing pedals everytime I need either one of them.
of cleat position repositioning problem, I’m not that athetic, so I don’t worry a lot about it while I may be able to remember where the cleat usually have been about.
Anyway, thank you for many thought. 😄
Quoted: 645 Post(s)
Liked 797 Times
exactly. That’s what I want.
Likes For Litespud:
there are pedals with plain platforms on one side and SPD-style clips on the other, so you can use regular shoes without cleats while maintaining the option of cleated bike shoes. Another possibility (and I think I’ve seen these for Look-style road pedals) is an adaptor with a plain platform on top and a cleat on the bottom - they clip into the pedals, converting them into platform pedals. Clip out the adaptors if you want to ride clipless. I’ve never seen these for SPD-style pedals, but if you were any way handy, these would be pretty easy to fabricate.
anyway, that was not too bad idea, but it makes me b still need to wear a bit pricey clipless shoes sadly:
thank you very much for caring thoughts 🤩
Quoted: 2952 Post(s)
Liked 3,106 Times
Then I got these pedals for my CX bike when commuting: https://rideissi.com/pedals/issi-flip
They're pretty good for riding around with regular dress shoes if I just want to casually ride to work and bring my shoes and jersey/bibs for a longer/harder ride home. Not expensive and might be what you're looking for.
Likes For caloso:
Guest
Liked 3,270 Times
https://www.amazon.com/Corki-15-Clip.../dp/B01JM5SYGK
LBKA (formerly punkncat)
Quoted: 2208 Post(s)
Liked 960 Times
In a situation like this I would likely try to find a comfortable shoe that rides well with platforms. For instance, Vans and Shimano "DX" are a whole lot like being strapped in. They just fit well together.
Take a look at Power Grips. https://www.powergrips.com/ Depending on how they are adjusted/installed, they will securely hold just about any shoe to a pair of toothed flat pedals with easy in and out. I've used them daily with a pair of heavy soled work boots and sneakers - not so well with leather soled dress shoes.
hello
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
I would think that what you are thinking of would need to be really tight fitting in order to have the needed control over the cleatl. And even then I think you would lose many of the benefits of clipless or toe straps.
I cannot see how this could possibly be preferable to running a set of quality flat pedals.
Quoted: 405 Post(s)
Liked 430 Times
There used to be a one-piece plastic platform / toe clip thing that snapped into a Look clipless pedal. I remember seeing them on bikes in bike shops that came with Look pedals. In fact, that's the only place I've ever seen a real one. I assume they came with the bikes to make them easy to test ride.
--Shannon
--Shannon
Quoted: 3450 Post(s)
Liked 420 Times
Just good old fashioned pedals with toe clips work quite well with regular shoes for some casual riding and/or commuting. No need to over think it.
For using with casual shoes only its probably advisable to pick a larger size set of toe clips than the ones you would have normally used with cycling specific shoes.
EDIT: Actually, even modern SPD compatible cycling shoes are quite chunky compared to cycling shoes intended for toe clips. Old cycling shoes were very slim.
Likes For AnthonyG:
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,995 Times
If I need clipless then I want a good cycling shoe and if I want to just wear regular shoes than I want a good platform pedal with adjustable or at least replaceable pins. I don't need or want to adapt regular shoes for clipless or clipped pedals. It is just not a good idea.
If you are saying "I am not that athletic" then why bother with clipless pedals in the first place? Having some clunky weird strap on on your feet isn't going to be a good clipless solution. Go ask a professional bike fitter if they recommend some jenky cleat mount for a sneaker. You want that cleat in the right place, it has nothing at all to do with "athleticism" it is all about putting your foot in the right spot for your pedaling and being more efficient and also comfort. Having something that slides around and moves a bunch isn't good for you in that situation and could be dangerous while clipped in.
If I need a bike to do both clipless and platform I would just get the Shimano PD-T8000 or Crank Brothers Double Shot or Mallet DH (if I was using their cleats). Otherwise I would go with a Crank Brothers Stamp (in large for my feet) or Issi Stomp XL or Spank Pedals or one of the many other options in a large platform with replaceable pins (just avoid fakes and knock offs)
Quoted: 9 Post(s)
I found the opposite
https://www.modernbike.com/kool-kovers
there is the one I saw the other day https://www.amazon.com/Fly-Pedals/b/...bin=Fly+Pedals
LMK how well they work and I might buy a set too.
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
2 sided pedals.Something like Shimano PD-T8000, PD-M324, EH500, or PD-A530
This is a crucial question about your philosophy of pedals. Some people seek the highest efficiency of clipless. I'm kinda retro and use toe clips and straps, because they're comfortable and ergonomic. I tried Look clipless for a couple years, but I came back to the old school toe clips.
On mountain/gravel bikes, I'm 100% for platform pedals with spikes.
I think these might work for you. It's a platform with a cleat that that clips in to your clipless pedals:
the adapted side keeps facing down whenever I put my feet away
