Adapt a non disc Topeak Explorer
Quoted: 67 Post(s)
Liked 83 Times
Is there a good way to make a non disc Topeak Explorer rack fit, that doesn't involve stacking nuts and washers? I would really prefer to not have to buy another, virtually identical, rack.
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,995 Times
So in the end you haven't provided much information so who knows. However what I do know is many modern bikes don't need the disc rack. If you need the offset then use spacers and longer stainless steel bolts but who knows.
What is not fitting or have you even tried? If you haven't tried, why not? What bike do you have, do you have pictures or any useful info you can provide?
Quoted: 67 Post(s)
Liked 83 Times
Anyhow, yes I tried. The standard Explorer does not fit my Jari 1.5. Topeak makes a disk model. I want to know if anyone has adapted a standard model. As stated, I would like to not just use janky ass washers and nuts. If someone has come across this issue in the past, I would appreciate it if they could inform me of the dimensions of whatever parts they used.
Clark W. Griswold
Liked 3,995 Times
Good lord.
In the end I would recommend using a spacer and a longer bolt. No "janky ass washers and nuts" just a longer spacer of the size you need (just cut it down and one single spacer) frequently used for fenders and racks all the time. Beyond that just get the correct rack you need for your bike.
Not trying to be difficult or nasty just being realistic.
Likes For veganbikes:
Good lord.
give more than just year and model of your bike and rack. attach some detailed photos, otherwise posters will be commenting based on wee, tiny photos from websites.
Miles to Go
I have adapted many racks to fit many bikes, and it's different every time. This is the point Veganbikes was making - There is no way to tell from a distance without specific information.
Likes For timdow:
I'd suggest setting it up using "janky ass washers and nuts" first, then measure them to determine the size of spacer you need. You may find the rack needs to be bent a bit. That bend may be a bit of offset. That might minimize the spacer(s) needed. You may also find that it just doesn't fit to your saisfaction. You won't know until you try.
Likes For staehpj1:
Quoted: 67 Post(s)
Liked 83 Times
but do take some clear, well positioned photos if you really want some suggestions, as noted many of us have improvised stuff, but we aint mindreaders, so you've got to do your part to show what is going on.
As mentioned, this is just being realistic.
Likes For djb:
