New Yokozuna cables have rendered my front brake useless......
GO, Mordecai!
So I just had my LBS install the Yokozuna Reaction full brake/shifter cable and housing kit, and while yes, I've seen improvement on the shifting side (very nice, crisp almost instant shifts), My front brake has become a total bear to engage. It is very very stiff, and takes a lot more force to squeeze the lever. I'm running Shimano Ultegra levers.
My shop mechanic says that these cables are just not flexible and the short front brake cable is the cause for the new resistance when trying to brake.
Has anyone else experienced this with these cables or others?
Any recommendations on a good cable I can use up front for the brake while I leave the rest of the cables alone? I'm trying to become better at braking by using my front brake more, but man, this isn't helping me learn.....
Thanks
Thanks
Bikes: Salsa Fargo Ti, Cannondale CAAD9, Carbonello Fixed Gear, Specialized Epic Disc
Quoted: 39 Post(s)
Liked 16 Times
I would check the routing of the cable yourself. Sometimes even good mechanics screw up, although his blaming the cables makes me think he was just looking for excuses. Check for kinks, uneven cuts and frayed cables and even too tight bar wrapping. Good luck!
Bikes: 1984 Miyata 710, 2010 Scott CR! Team
Sounds to me like who ever installed them screwed up. Mine work fine.
Rigid yes, but haven't heard of them inhibiting braking performance. May want to try posting in the Mechanics forum as well.
GO, Mordecai!
GO, Mordecai!
So I just released the cable from the brake and when there's no tension on the cable, it's still almost impossible for me to clamp the brake shut with my hands even. Then when I take the housing out of the spot where it connects at the top of the brake so that the brake doesn't have any cable/housing tension on it at all, then and only then can I freely clamp the brake shut. There is definitely A LOT of tension coming from the cable and it's pushing hard agains the brake, making the brake be very difficult to clamp.
Interesting. I'm surprised the brakes even release from the rim. How are the rear brakes?
Try unhooking the cable housing from the brake itself and straightening out the cable so it doesn't have that bend in it and give it a squeeze. If that solves it, then you might need a longer cable run to smooth over the bend/kink. If it doesn't solve it, then there's something else rubbing. Could be that the cable started to unravel inside the housing when it was fed through. Maybe there's something going on with the housing or inside the shift lever. In any event, your mechanic shouldn't have given it to you in this condition. You might want to consider finding a new LBS.
GO, Mordecai!
The resistance comes when I seat the cable/housing into the big step-down ferrule that's seated in the brake caliper. It's quite a hard bend that this very tall ferrule creates and trying to bend the Yokozuna housing into this little junction creates all that force exerted on the caliper. It's basically pushing the caliper to the side and keeping that constant force, making it very very difficult to have the calipers close when braking.
Should I try a longer housing, then?
I see you're in NYC. I was at Toga for this install, and I've always loved their shop. But this case really hasn't been good. Any recommendations for any places that might be able to do it right?
pan y agua
Quoted: 1451 Post(s)
Liked 731 Times
The housing on your front brake is cut a little short. The housing is supposed to come straight up out of the brake, and then begin to bend above that.
In the pic your housing appears to exit the brake already at a bit of an angle.
That said, it doesn't appear to be short enough to be causing the problem you're describing.
You could get lost and die.
You could hit a tree and die.
GO, Mordecai!
Do I need the ferrule if the cable width matches the opening of the brake caliper? I believe that stiffness of the ferrule is also adding to how much the cable has to bend to get into the brake.
John Wayne Toilet Paper
Bikes: BH carbon, Ritchey steel, Kona aluminum
I'm guessing your mechanic routed the cable through your brake lever incorrectly. It would be hard to do, but possible I suppose.
Roadie
The front brake housing is a bit too short, The C7s are VERY finicky about housing length and routing.
Yokozunas are some pretty serious cables. My guess is the mechanic at Toga has probably never routed a Reaction cable system before. Even so, by the looks of it, all four of those cables look pretty short to me for any cable system. Is your steering restricted? I'd also be concerned that the rear derailleur cabling in the back is too short as well.
GO, Mordecai!
Might run down to NYC Velo or Sid's this weekend and see if I can get it sorted with whatever leftover cable I have.... Disappointing.
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times
Housing length is more importent to get correct with yokozunas. Because they are so stiff you can't over under length them like you can with standard housings.
I have installed tons of them. Your front housing is too short.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
GO, Mordecai!
Thank you so much for this info, Psimet. I'm going to go to the shop today and tell them it's not right. They need to either do it right or reimburse me because I'm going to have to go to another shop to get it done properly.
GO, Mordecai!
So I went to the shop and naturally they told me the same thing: These cables are just stubbornly stiff and that's the cause of the tightness. I told them that I'd talked to people who had actually installed them and used them and that they said that my situation didn't sound right. But they didn't know what to do. So I told them to swap in another cable that they know will work so that I can at least have a working front brake for the time being. They obliged, free of charge and I was on my way soon after.
It's not my ideal situation, because I've got a sort of mismatched cable setup going on now, but the brake feels better. I'm bummed about not being able to get the Yoko's to work up front. Though I have no idea how much difference in stopping power I'd feel if I had gotten the front brake installed right.
If I really want to get them working, maybe I'll try another shop that has been recommended here in this thread, but for now, I'm tired of fighting to get this cable working... especially now that I have a functioning brake.
Bikes: 2012 Scott CR1 Comp
First time I installed the yokozuna's I made the same mistake, just a tad too short. The brake cable housing is serious pita due to the stiffness. I ended up having to take a pair of needlenose pliers and shape the part that goes into the brake lever so that the housing would go in at the correct angle and not interfere with braking, or move around when the brake lever is engaged.
It takes some doing, but I do like the crispness of the braking as opposed to standard dura-ace housings.
Didn't you say you had extra housing? Why didn't they try to use a piece a couple of inches longer instead of using a different type?
GO, Mordecai!
Pretty sure they were convinced that it wasn't possible.... Not going to give the last of my housing to someone who doesn't know how to install the stuff. I'd rather take what he can give me and go to a shop who has done Yokozuna cables before and have them use up the last of my cables.
Bikes: MTB: Stumpjumper FSR, Road: De Rosa King 3
I'd definitely find another shop for any future mechanical needs. The length needs to be more exact, but it's not rocket science. Anyone who's charging you to install them should be able to manage it. Especially after you go back and tell them what the problem is and how to fix it.
Or else they shouldn't be in business.
stole your bike
+1
Definitely too short. I botched this up the first time I installed the Yokozuna housing as well.
When I unhook the cable housing for the brake and there is no tension on the cable, the cable slides through very easily when I engage the brake lever. No resistance.
I used to go to Toga years back and got tired of having to go back with repairs they messed up.
Are you referring to the one on the East side? I thought that was a Specialized concept store they got involved with...
I like pie
I like pie
