Polishing Aluminum Rims
Bikes: 1987 Pinarello Montello, 1996 Litespeed Classic, 1996 Colnago Master Light, 1997 Litespeed Ultimate, 2006 Opera Leonardo FP, 2006 Pinarello Paris FP, 1984 Pinarello Record, 89-ish Cornelo Profilo
Quoted: 148 Post(s)
Liked 119 Times
Anyone ever used Mother's Polish (or similar) on aluminum rim braking surfaces? I figure it would return the new rim shine to them but will it affect braking performance?
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
I've used Mother's for years, but I have to admit that I haven't used it on the braking surface of polished rims. I would guess that you'll follow up with a cleaner of some sort and wiping with a clean cloth. If you use an ammonia-based cleaner, be aware that this may dull or darken a polished finish. It's never been a problem for me, though.
Not a newbie to cycling
Bikes: Omnium Cargo Ti with Rohloff, Bullitt Milk Plus, Dahon Smooth Hound
Quoted: 356 Post(s)
Liked 323 Times
Don't polish braking surfaces, regardless of what product you use. Clean it if you want, but use something that cleans but no polish (i.e. Isopropyl alcohol).
If you want shiny rims, get some disc brake wheels. Then you can polish the rims to your heart's content. But be careful you're not getting it on the rotors.
Quoted: 1438 Post(s)
Liked 1,092 Times
Most polishes and compounds have a wax-type base so will leave a residue which will likely interfere with braking. It may or may not come off with a solvent like acetone or brake cleaner; silicones are especially difficult in this regard.
Quoted: 604 Post(s)
Liked 1,063 Times
Bought some new Velocity A 23s a couple of months ago, big delay for the polished ones, so took the unpolished aluminum ones. Really wanted polished silver ones, so used Mother’s metal polish on the rims, including the brake surface, before having them built up, Wiped the braking surface with isopropyl alcohol before riding on them, no issues, could have thrown myself over the bars on the first pull if desired. Mothers will work fine.
Tim
Tim
I polish silver rims before building them, but always wipe down the brake surface with alcohol after the build is complete.
elcraft
BITD, I hand polished ( with a rag and my fingers) Weinmann rims with Simichrome. People always asked me why I had steel rims instead of alloy.....
Likes For elcraft:
Half way there
Quoted: 986 Post(s)
Liked 880 Times
Simichrome is my long-time preferred compound for polishing Al. Braking surfaces should be sanded with fine grit paper, not polished.
Bikes: Cannondale tandems: '92 Road, '97 Mtn. Mongoose 10.9 Ti, Kelly Deluxe, Tommaso Chorus, Cdale MT2000, Schwinn Deluxe Cruiser, Torker Unicycle, among others.
Quoted: 279 Post(s)
Liked 207 Times
The brake pads will quickly render the polish moot, especially after the first wet ride. I agree with the later posters, but ultimately, all that polishing will be for naught - your rims will quickly become scored and that dull aluminum/scrapes/residue look will return. But enjoy it while it lasts!
Very Senior Member
Bikes: Giant Quasar & Fuji Roubaix
Quoted: 413 Post(s)
Liked 343 Times
1200 grit and wet sand if you want them to shine. If you're putting polish on and then using acetone or alcohol to remove the polish, all you've accomplished is cleaning the rim.
Likes For Bigbus:
Quoted: 279 Post(s)
Liked 207 Times
This was the tried-and-true method for addressing the DREADED Dia Comp 986 cantilever squeak nightmare! Some brakes simply will NOT comply! Toe in, greased canti posts and everything else fail. Seems to be the combo of the brake pad compound and new anodizing. Scrub through the anodizing to fresh aluminum and you're good.
Quoted: 1163 Post(s)
Liked 442 Times
Tim
Tim
BTW: I ride polished (non-anodized) A23’s on my Flyte SRS-3. I polish the entire rim, including the sidewalls with Mother’s mag wheel polish. They look stunning and the polish application to the sidewalls improves my braking performance as well.
Quoted: 356 Post(s)
Liked 323 Times
Brakes stop you by generating friction as pressure is applied. If you polish it - especially with things such as polish, wax etc. - you reduce friction. There is no way polishing your brake surface will somehow magically make the brakes work better. Maybe if you haven't ridden the bike and you "test" it by applying the brake without moving the bike. In that case, I can imagine that something feels sticky.
The mentioned product (Mother's mag and aluminium polish) is for the rims (on cars and motorcycles) and not for the brake rotors on the mentioned vehicle. I know your rims are rims, but with rim brakes they are also the rotor.
Likes For CargoDane:
Liked 442 Times
Quoted: 356 Post(s)
Liked 323 Times
I know, you're telling it as if it is a fact: That smoothing-out your brake surfaces and covering it with something that is supposed to make a surface as slick as possible so dirt and brake dust won't stick to it, somehow makes your brakes work better.
Cleaning dirt off your pads is a good idea, regardless of whatever else you do. Just like removing polish, oil from the road and so on from your brake surfaces is also a good idea. Both the cleaning of the pads and the softer pad itself improves performance, regardless of whatever else you have done to reduce friction. However, if you hadn't reduced the friction, your clean and soft pads would work better.
However, you seem happy with your choices.
Liked 442 Times
Cleaning dirt of your pads is a good idea, regardless of whatever else you do. Just like removing polish, oil from the road and so on from your brake surfaces is also a good idea.
Quoted: 356 Post(s)
Liked 323 Times
I wonder if you mostly use the rear brake when coming to a stop?
I ask because it doesn't take much pressure (friction) to make the rear tyre skid, so back there you don't apply much force compared to using your front brake to stop as quickly as possible (both, but the point still stands).
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3884 Post(s)
Liked 6,478 Times
Half way there
Quoted: 986 Post(s)
Liked 880 Times
The differences in friction and wear levels of the tested surfaces seem rather independent of the presence of textures but primarily seem to be caused by the differences in local surface roughness, i.e. whether the sliding surfaces are polished or ground. Both sparsely textured and untextured polished surfaces showed substantially lower friction coefficient and less wear of the counter surface than did the ground surface. Thus, polishing is the obvious way to decrease friction and wear in these types of contacts. The increased friction found for denser surface textures indicate that introduction of a texture might even drain the contact from mixed towards boundary lubrication.
https://www.diva-portal.org/smash/ge...1.pdf;Surfaces
Likes For Moe Zhoost:
Liked 442 Times
Liked 442 Times
I realize that you believe braking performance to be improved after polish; however this is just a perception that won't stand up to real testing. The fact is that metal surfaces are polished to reduce friction, and friction is what generates the braking force. There are plenty of studies that confirm this. Here's a quote from one:
I’m mot sure what to think about the 44 page scholarly article you provided. Looks like an interesting read. Not bike specific though so the takeaway for me is inconclusive. I got caught out in an absolute downpour last summer and I guess I shouldn’t be surprised that I had such a difficult time pulsing my brakes to squeegee them off. For now I’m gonna stick with my claim that these particular rims brake better in most conditions when freshly polished with Mother’s mag wheel polish. The grip with these pads; https://www.ebay.com/itm/193331590060 (inexpensive pads I have been using for the past 2 years) is enhanced a bit with no squeals or grabbiness. I forgot to mention that I do an intermediate step after (2 or 3) rounds of Mother ‘s mag wheel polish using Meguiar’s Cleaner Wax which concludes when my little paper towel squares aren’t so black any more. If I’m feeling like perfecting the shine a bit more still I use one round of Meguiar’s High Tech paste wax. These last 2 steps don’t seem to hurt the braking any and they seal the bare aluminum so that in a light rain, water beads up (for a while at least).
Likes For masi61:
Quoted: 356 Post(s)
Liked 323 Times
Hmm, then there isn't really any reason as to why you'd perceive the braking to be better on polished rims.
Quoted: 356 Post(s)
Liked 323 Times
Yeah, you might be right. I like the feel the way I do it for these particular polished rims. I’ve got them braking really well most of the time, not grabby but positive braking. I have Dura Ace 7700 dual pivots which are not as powerful as 7800’s. I have a bike with Dura Ace 7403 dual pivots (which I did a full rebuild on) and man they are some powerful rim brakes paired with ordinary Tektro aero brake levers.
Since you don't believe in friction is what is making your brakes work, what do you think is causing you to come to a stop?
Liked 442 Times
It doesn't matter if it's bike-specific: Friction is what causes you to stop when you apply brakes. That's also the reason brakes can get really hot. Have you tried some silicon lube on your rims (please don't!). It makes most of the friction go away.
One of these days I am going to give Velocity a call and ask about their polished rims. I thought I heard that they sub them out to a Harley Davidson motorcycle polishing shop. I purchased a set of the Aileron disc specific rims in polished for a disc bike that I really need to finish. Running a bike with these I think would look cool and also afford me the luxury of not worrying so much about the state of my rim brakes and sidewalls, LoL.
