"Dork Disk"
Bikes: 1987 Schwinn Mirada, 1989 Trek 420, 1995 GT Timberline, 1979 Schwinn Super Le Tour, Co-Op DRT 1.3
Quoted: 103 Post(s)
Liked 85 Times
"Dork Disk"
Howdy folks
Was riding my old mtn bike in the forest preserve today and the yellowed, brittle old "dork disk" finally crumbled to pieces and basically fell off. Now, I know dork disks are deeply uncool in these parts, but apart from that, is it worth my while to replace it? If I go on and ride without it, am I risking some sort of catastrophic failure where the chain skips off the biggest sprocket and gets entangled in the spokes, locking up the wheel and sending me over the handlebars? Thanks for your advice as always.
Quoted: 206 Post(s)
Liked 460 Times
If your rear derailleur set screws are properly adjusted, you have almost no worry of your chain wrapping up in your wheel, which is why lots of people remove them. That and they're ugly.
Likes For krakhaus:
Quoted: 1943 Post(s)
Liked 2,164 Times
If the rear wheel locks up you won’t go over the bars.
Do you need one on a mountain bike? It depends how you shift. If you end up forcing downshifts and overstressing the drivetrain a chain plate can pull apart and/or you can pull the rear derailleur off and it is possible to drive it into the spokes, more so with a steel frame without a separate hanger.
If it is too catastrophic, it may not help.
But if you anticipate and have good shifting technique, you don’t need one.
John
John
Likes For 70sSanO:
Quoted: 20 Post(s)
Liked 28 Times
For me, I don't like dork disks for aesthetic reasons. They are only useful for people who don't maintain their bike or know how to shift. After cleaning my bikes, I check the alignmenet. Every 500 miles, I check the limit screws to make sure the chain can't go over the biggest cog into the wheel.
For all the people who want to keep the dork disk because they think it's safer, the OP just threw a wrench into that logic... The Op's DORK DISC is what failed! What if it broke a spoke?! I never kept a dork disc on long enough to fail, but now I have another reason to remove them.
Quoted: 114 Post(s)
Liked 119 Times
I've seen said disks that were just slightly larger than the diameter of the largest cog, black colored and somewhat discreet. I'm assuming the disk occupied enough space so the chain wouldn't fall into the hub.
Quoted: 1079 Post(s)
Liked 1,019 Times
Anyone who's worked in a shop long enough has seen the effects of a rear der in the wheel. the disc won't stop it from happening in some situations but I've seen it help. My kids have them on their bikes and I knew that the oldest had bent her hanger on a MTB ride when I heard the der rubbing on the disc which did keep it out of the spokes.
On the other hand I don't have a wheel on any of my bikes that has one.
All Ass No Gas
Location: Azusa, Ca "Everything from A to Z in the U.S.A."
Bikes: 1988 Peugeot St. Laurent, 1974 UO18 Peugeot, 1985 P16 Peugeot, Roadmaster Ground Assult Mtn. Sport, Schwinn Traveler, 1986 Iseran Peugeot, Junet Mixte
Quoted: 50 Post(s)
Depends on Bike
I think it depends on the type of bike and year it was made. On Vintage bikes I think they look awesome. Kept clean and shiny they add to look of the bike. But the plastic ones once they've yellowed are plain ugly. As far as spacing, in my exp. especially with vintage bikes they are there to provide protection. The "dork disc" was not flat and provided protection from overshifting which is very easy to do on friction shifting.
Likes For cyclingarri:
Happy With My Bikes
Quoted: 882 Post(s)
Liked 2,304 Times
A shiny, 40 year old "dork disk", reflectors and "turkey levers" or anything else that would have been ripped off and trashed being still intact makes a survivor bike a little more special IMHO.
Tortoise Wins by a Hare!
Quoted: 1549 Post(s)
Liked 941 Times
^^^ Yes. Some dork disks, oops I mean pie plates, will never break... and removing them would wreck the look of the bike.
Quoted: 339 Post(s)
Liked 631 Times
When I rebuild bikes(usually from the 70's and 80's) I always put spoke protectors on them, I also put reflectors on the spokes, pedals, and front and rear on the frame. The bike exchange requires them on all of our donation and sale bikes. Throw the chain into the spokes and you will ruin about half of the spokes on that wheel. Ride at night and you can get a ticket if you don't have reflectors and lights. A bike is almost invisible at night without them and anytime you hit a car or it hits you you loose big time, says someone who spent 2 weeks in hospital with 2 broken ribs, a punctured lung , and a bruised kidney after colliding with a car. there is nothing uncool about safety.
Likes For capnjonny:
Quoted: 667 Post(s)
Liked 529 Times
Did a 3 day ride on the GAP trail. At the end of the second day my buddy's 35 year old bike threw the last of his already busted up dork disc. At the start of the third day he jammed the chain in between the spokes and freewheel when pumping up a steep hill in traffic. Luckily some guy stopped with a truck full of tools or I think we would still be on the side of the road trying to get that chain free. People from the Pittsburgh area are super nice.
I don't have a single bike with a dork disc, but honestly have to wonder why sometimes.
Quoted: 1135 Post(s)
Liked 1,727 Times
I just replaced the dork disk on a Bridgestone, someone got smart removed and then munched the chain torching all of the elbow out spokes. New spokes and now Dork on.
Sounds better than Dork off.
Likes For Mr. 66:
Quoted: 20 Post(s)
Liked 28 Times
Quoted: 94 Post(s)
Liked 151 Times
As far as reflectors, I always recommend replacement of missing reflectors on the front and rear of the bike as well as reflectors in the spokes front and rear. These items are required to be mounted on all new bicycles by the federal CPSC and for good reason. I can see not putting them on a vintage bike that never had them that will never be rode at night or in bad weather.
I don't have dork discs on my bikes, however, check carefully the adjustment of the RD.
I had to remove the cassette once as the chain fell between it and the spokes and I couldn't remove it by hand. Fortunately it happened on my front door.
They're ugly, they make noise, some of them are crap, but they serve a function.
I don't have idiot dork discs on my bikes. I have spoke protectors. A rare but occasional missed shift can score the outer spokes and they will eventually break from fatigue. After an overhaul years ago I forgot the Spoke Protector and at a busy intersection I missed a shift and dropped my chain. A few rides latter a spoke broke. When I went to replace it that 8 others had been cut so I replaced them all.
The limit screws were properly adjusted.
Quoted: 20 Post(s)
Liked 28 Times
These two statements are mutually exclusive. The limit screw prevents the derailleur from going beyond the largest cog. If it is set correctly, the derailleur cannot physically get the chain over the cog.
Quoted: 339 Post(s)
Liked 631 Times
Another thing about spoke protectors , (lets not be hatters and use some slur to name them eh?)
You have to use different kinds dependent on the spoke count and whether you have a freewheel or free hub. There are different sizes depending on the largest cog and also different materials used. On entry level bike boom models you had chrome steel (along with steel rims), on higher end vintage bikes you had Aluminum disks. You might also see disks with aluminum centers and plastic on the outside. These all have a round hole in the center that fits over the freewheel hub.
Another type has a larger hole in the center with at least 2 types of attachment. These can be used on freewheels or freehubs. the first type has tabs that attach directly to the hub flange. a second type has tabs that slide over the individual spokes. These Spoke protectors are different depending on whether the wheel has 32 or 36 spokes.
On really extreme wheels with ridiculously low spoke counts I have never seen protectors. They may exist but the bike shops remove them before sale.
Actually, I get most of my reflectors and spoke protectors from a high end bike shop. They never use them. The kind of customers they get probably don't do their own repairs so when they trash a wheel with the chain in the spokes they just go in to the shop and buy a new one. when you are spending thousands on a bicycle you can afford it and for the bike shop it is guaranteed business.
Bikes: 1965 Dilecta Le Blanc, 1956 Royal Nord, 1972 Raleigh Sports, 1972 CCM Turismo,1976 SuperCycle Excalibur, 2014 Salsa Vaya, 2017 Felt DD70, 2019 Giant Lafree and others
Quoted: 351 Post(s)
Liked 588 Times
Yellowed plastic I discard. Chrome beauties on vintage bikes I keep.
We are what we reflect. We are the changes that we bring to this world. Ride often. -Geo.-
Likes For browngw:
Clark W. Griswold
Quoted: 4335 Post(s)
Liked 3,958 Times
At least for modern bikes they are designed as trash they frequently cause more problems then they are worth (plenty of builders coming to me say "warranty, warranty:" and I pull of the plastic disc and problem goes away). If you take care of your bike and make sure your derailleur is properly adjusted it won't go into the spokes and if you hanger or derailleurs bends or breaks that little cheap plastic disk ain't gonna do much to help you. A bike should be well maintained anyway and if you are not doing that you will have many more problems that a plastic disc cannot solve. A well maintained bike is a happy bike and a happy bike is a happy rider and a happy rider is all right with me : )
Some of the vintage ones however can be quite nice as browngw has shown us. That Sekine one actually gets my heart a tiny flutter.
Bikes: 1986 Cannondale SR600
Quoted: 20 Post(s)
Liked 7 Times
My limit screws were set correctly.
When the chain comes off the chainrings, there's enough slack that the rear derailleur doesn't track the rear sprockets closely as normal. In this event, even with the limit screw set correctly, the chain can easily walk off the sprocket.
That incident was the last straw, having already replaced the 8 spokes after a similar incident a few years prior. The spoke protector I'd found had a nice ledge on it, so of the chain goes past the large sprocket, it rides up on the ledge rather than down into the gap behind the freewheel.
Luckily these derailment events always seemed to happen to me at low speeds - I've never had one happen when the chain getting caught up and locking up the rear wheel would cause a real safety issue. Since putting in a third-eye chain watcher and the spoke protector, nearly 20 years ago, I haven't had a problem since.
Clark W. Griswold
Liked 3,958 Times
There was one time I was coasting along slowly checking out a then new construction area. I started to backpedal a little to set things up to trackstand for a longer look, and in the process, the chain decided it wanted a closer look at the hub flange. It was long enough ago I don't remember whether I'd hit a bump at the wrong instant, or if my chain had just gone slack from losing engagement with the chainrings, but however thins unfoded, it severely gouged out 8 spokes.
I'm not cool enough to ride without a dork disk.
As long as they are not yellowed or broken plastic, I use them. If they are properly installed, and the right size, they don't look out of place to me. I'm very careful with my dérailleur limit screws, but it's extra protection, so I have one on all my wheels. I've even acquired a small stash of spoke protectors since a few home mechanics I know save them for me.
The majority of riders I know that have thrown a chain into the spokes say their limit screws were properly adjusted.
One of my bikes has a yellowed plastic spoke protector that says "28 tooth max". If I change my freewheel to a 34 tooth low gear, where do I find a nice, classy protector to accommodate? Are there thickness differences? How about axle/hug hole size?
